Question about Canon ES75 Camcorder
Sony CCD-FX310 Camcorder how to adjust tracking
I have a sony CCD FX310 that I borrowed from a friend. It will load the tapes fine but when I play them, it is not very clear. Is there a way to adjust the tracking on these?
  • 10,594 Answers
Sony camcorders has no tracking control for user.
I think video head is dirty / clogged. Put good quality video head cleaning tape in camcorder and check.
Its almost 15 years old camcorder.
Posted on Jan 30, 2009
I have a Sony Handy CAM 8 CCD-FX310. It will eject, but when you place a cassette in the slot and gently push it closed, the top will not retract down. it makes a slight spinning noise and then ejects...
I had the same problem with a Sony FX410, not much different than a FX310. With my camera all i had to do was to push the top down with a gentle push, it would engage and play and record normal. Don't force it hard, just a light pressure to help the cradle down. Most of these Sony cameras are crappy when it comes to loading the tape, most if not all the Sony's i've had end up with this problem, no matter what model you have. I've taken my camera competely apart and could not find the problem for not pulling down the tape, don't know if it can be a sensor or what, i never could find anything broken or loose or misalign, i oiled all the joints and moving parts with a light dab of thin oil, it worked fine except for that darn cradle not pulling down the tape.
Another thing that causes this is when the tape is to tight? In other words the tape should have a slight **** in it, i once ran into this big problem when the tape would not load and the camera kept ejecting it over and over. It was when i tried a new tape that i noticed how well it loaded yet the other tape wouldn't load. So i pulled out the tape and poked that little hole on the back right below the left hand pick up reel, i then turned the reel with my finger and gave it some slack, not much just enough to see the tape a little loose. I then reloaded the tape and it worked like a charm, seems that if the tape if to tight the camera won't accept it as the reels need to adjust back and forth for a few seconds, its that wacky sound you hear when you load a tape, seems like it has to adjust the tention inside the take up reels. Hope this might help you some?
Oct 08, 2010 | Sony Video Cameras
Play back of video recorded on a different camcorder
sir,
you must have run a dry run before recording them in blank tape
Jan 11, 2008 | Sony Handycam CCD-TRV87 Camcorder
HELP, I have borrowed an older camcorder from a friend. A sony Hi8 CCD-TR101 handycam. My child put the tape in backwards and now it wont eject. What should I do??
Tape can not be inserted backward in.It is impossible to to insert cassette inside video wrong way.
If it is not ejecting its eject switch might have got broken by physically pulling its cassette compartment outward before closing last time.
Its mini switch is very fragile in all sony models. so only way is to take to technician to bring it out.If i were you,I would buy used one from ebay at lower price than repairing.
May 07, 2010 | Sony Handycam CCD-TR87 Camcorder
Sony CCD-TRV85. Tape Stuck - C31:22.
my guess is that there is a problem with the tape. Does it work with other tapes? Or haven't you tried?
Aug 23, 2009 | Sony Handycam CCD-TRV37 Camcorder
Sticky 8mm sony tape
need to go to an AUTHORIZED SONY REPAIR SHOP to get it fix , these camcorders are very delicate and needs to be tune and realign by a SONY EXPERT TECHNICIAN , thanks AJ
Jun 12, 2009 | Sony Handycam CCD-TR87 Camcorder
Problem with sony ccd tvr208
CCD-TRV208E is analog Sony Handycam and I think tape was recorder on Digital Handycam.
Digital handyacam model starts with letters DCR-xxx so locate a digital handycam to get tape recordings.
I got this idea when you said, only getting crackling noise and blue screen.
Jan 31, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
Why wont it play LP taped tapes?
Tracking is very sensitive on hi-8 tapes in LP mode. This recorder will record and playback in LP mode. It is however recommended that if you record in LP mode that you use the same camera to play it back, that it was recorded with, or you might have problems.
Also from what I can find online, the TR427 is just an video8 camera not a Hi-8 so if you are trying to play Hi-8 tapes on it, it won't play right.
Nov 03, 2017 | Sony Handycam CCD-TR427 Hi-8 Analog...
Sony ccd-fx310
My camera won't play back.  Occasionally, if I ffwd it will show the picture otherwise its a blank screen.  Any ideas?  I've tried cleaning the heads a few times now
Dec 04, 2007 | Sony Handycam CCD-TRV37 Camcorder
Sony Handycam CCD-FX310
Record in slow mo mode, then playback in fast forward mode ;) Problem solved. You'll see the video in normal speed.
Oct 20, 2007 | Sony Handycam CCD-TRV37 Camcorder
Canon ES75 Camcorder Logo
1,313 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
