Question about Makita 10" Dual Bevel Sliding Compound Miter Saw
Not cutting square
Have adjusted the maximum with the fence but still significantly off square
  • david smith Feb 03, 2009
    when im cutting any timber on a bevel at a 45 degrees (2 pieces of timber) they dont end up at a 90 degree can anyone help me reline the bevel
    President:
  • 2,976 Answers
You might have an adjustment on the swing arm itself, for fine tuning the cut. If you still have the manual, it should give details.
Posted on Jan 30, 2009
Can this saw be adjusted if it cuts out of square? And if so, how.
Hello, yes this saw can be adjusted.
To calibrate the table, use a framing square up against the rear fence and see how the blade tracks. To adjust this: loosen the bolts holding the rear fence down and move the fence until it is square with the blade track and tighten.
To adjust the bevel: use a speed square to check for 90deg and 45deg on the blade. Using the 13mm bolts found at the pivot point on the trunnion you can adjust the 90 and 45 degree angles.
Mar 12, 2016 | Hitachi 8.5"" Sliding Compound Miter Saw...
My craftsman miter saw cuts but it is not a straight cut.
Here's an old dude trick that might help.
Safety first! UNPLUG THE SAW.
- Take a framing square and set it against the fence. It should be flush with the fence on both sides of the blade. If not, slide the square to one side and pull the blade down into full cut position, then slide the square against the blade and fence to check for square. If square, slacken the bolts on the other half of the fence and align it with the correct side.
- A bit of messing about should have it lined up just fine.
- If it is off vertically, there should be some alignment possible.
Patience and safety.
You'll get it.
Oct 08, 2015 | Craftsman Saws
Square up fence to blade
with the tool unplugged from power . u need a good square drop the blade down to cutting position place thesquare against the fence then slide it up to the teeth on the blade making sure u are against the teeth . if not square in the zero position on the scale undo the fixing bolts for the fence and adjust till the square shows no gap between fence and blade teeth . retighten bolts and check . plug in and make a cut . or u could just make cuts and move fence till get it right . i should add with straight edge make sure the fence itself is straight across its face. with one piece fences they can get bent. good luck.
Aug 14, 2011 | Makita 10" Miter Saw LS1030N
HAVE OLD MAKITA 2708 TABLE SAW HOW DO I SQUARE THE BLADE
Hi rjames16,
Are you wanting to square the blade to the rip fence, to the miter fence or does the blade show runout?
To square the rip fence to the blade, lay a combination square or engineer's square along the blade with the short leg against the closest end of the fence and even with the near end of the blade. Slide the square along the blade so that the short leg is even with the far end of the blade. Loosen the lock knob and move the far end of the fence until it touches the leg of the square. Tighten the lock knob. Recheck and adjust the fence until it is perfectly square to the blade.
Adjust the miter fence to the blade in a similar fashion except that the short leg of the square will lay against the miter fence. Adjust until the long leg is aligned with the blade. The instructions for these adjustments are in the owner's manual.
You can download a copy at this website: http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=604
Copy and paste this entire address into your browser and a page will open with 2 Adobe documents. One is for the owner's manual, the other for the parts breakdown.
If you have blade runout, remove it from the saw and lay it flat. Check for warping and if warped, replace it.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 30, 2011 | Saws
The blade is not sqare to the front of the table, with the fence next to the blade there is a 1/8 inch differance. how do i adjust the blade or the motor/shaft
you don't adjust anything but the fence if I understand the question correctly. You are using the fence for a straight cut and there is a gap, if so on the back of the saw UNPLUG SAW FIRST you will find a schematic about hhow to adjust the fence but all you have to do is loosen the 2 bolts where the arrows are I believe they are 10MM and lift the guard out of the way then gently run the fence next to the blade and "push" the fence square to the blade and tighten the bolts, usually it takes a couple times (I always recheck it). Now if the blade set at 0 degrees is not square you reset the angle from the front. Let me know if you need more help
Feb 25, 2011 | Dewalt DW744X 10" Portable Table Saw
Rip fence is out of alignment..what do I need to do?
This is the fundamental problem with rip fences on table saws. I don't know what kind of rip fence you have, but most rip fences are adjustable for squareness. However, unless you have a very nice (and expensive) rip fence, they often don't self-align when you move them anyway. If you have the type that clamps at the front and the back of the table, the problem can be overcome by making sure the rip fence is straight before you clamp it in place. The easiest way I have found to do that is to use an adjustable square. Put the front of the rip fence where you want it, then set the adjustable square so that it matches the distance from the miter slot in the table to the fence. Then move the square to the back of the table and move the back of the fence to meet the end of the square. Now clamp it in place and check the front and the back one more time. It's tedious to do this every time you adjust the fence, but you can get a perfectly aligned fence this way. This method assumes that your blade is parallel to your miter slots, which is adjustable too, but you have to get underneath the saw to do that. good luck, Al K
Jan 14, 2011 | Saws
Promblem with Makita 1013 ajusting blade to cut square
Just found your problem, what you need to do it unplug tool and get a good square. Set the blade at 0deg. and then put the square on the left side of the blade to check it. If it is out of square you would need to loosen the fence bolts (13MM) and adjust the fence, snug bolts on the left side and move your square to the right and recheck and then snug the bolts there, I always recheck the fence to ensure it is square and not moved before tightening the bolts fully. If the head is out there are bolts on the pivot that need to be adjusted and again recheck. If you go to Makitausa.com you can download an owners manual with instructions on what to do. Let me know if you still have problems.
Jan 06, 2011 | Makita 10" Dual Slide Compound Miter Saw...
Adjust angle of band saw blade to align with fence
Typically the fence is attached to the table and the table can be angled to create a bevel.
Using a square, align the table so it's square to the blade. Assuming your fence is square to the table vertically, you're good.
With most bandsaws I have worked with, there is a positive stop (typically just a bolt - the head acts as the stop) underneath the table so when you tilt the table, you can return it to flat without having to re-square everything up every time. Once you've got things square, make sure to adjust the positive stop too.
Be aware you may still have to compensate for drift with your fence, though.
If this answer was useful, please vote. Thanks!
May 23, 2010 | Black & Decker 14" Hd Multi Cutter Saw
Need to calibrate my dw708 sliding compound miter saw. How to adjust the slides for a true cut. The blade is square.
i use a framing square off of the back fence with the blade down. when it is square, i check the other side of the fence and loosen the screws on the plate with the degree increments and set it to zero
Nov 21, 2009 | Dewalt 12" Beveling Sliding Compound Miter...
Dw703 beval adjustment
User manual for adjusting your saw here.
When you set it up, make sure you check for square to the table, square to the fence, and check square for toe-in or at a 45 deg. angle across the blade from the corner where fence meets table, like you would check a radial arm saw. (hold a framing square with one leg against line of fence/table and other leg against blade and inclined 45 to both table and fence. Make sure all three are dead square.
I never found any way to compensate for the play in the blade itself. It seems like the manufacturing tolerances are a little too loose.
You may need a heavier plated blade. You may simply need a different saw. Those Dewalts are great workhorses, and I love the design, but it's my experience that when you're trying to miter hardwoods of any substantial size there's a little bit of drift in the cut as the blade comes through the wood.
You can try cutting at a slower rate.
I've found that makitas are a little more solid through the cut, though I don't like the general ergonomics as much...
Kind of a pain, isn't it?
Well, good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 04, 2009 | Saws
Makita 10" Dual Bevel Sliding Compound Miter Saw Logo
248 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
