Question about Miele Novotronic Premier 500 Front Load Washer
Miele premiere nova needs new electric panel
I moved into my home 7 years ago and have been using a miele front loader  which was here in the house. the technican came out and told me that i need a electric panel probably because my machine wasnt level it has just over 4,000 hours on it the call out charge can be used toward a new miele which is about 900 euro the panel plus vat and the call out charge is close to 385 euro. should i gamble and get it fixed or is the machine worth fixing . i would hate to fix it and i have another problem as i am not sure how old the machine is? thankyou, the techbican told me 10,000 hours is the life expectancy of the miele but he said it is up to me
    Genius:
  • 2,920 Answers
I would go for the repair as you still have 6000 hours left on it that you can use up plus if he repairs it the life expectancy could be extended another 2000 hours..i would consider that before buying another machine and let him repair this one
Posted on Jan 30, 2009
Check drain light, fusing all the sockets in the house
Do you mean it blow the fuses in the house?
Must be an electric problem with it. Something is overloading the unit perhaps electric shorting in a switch. Ask an electrician, that is safest if you do not have experience with electricity.
Jul 29, 2017 | Miele Novotronic Premier 500 Front Load...
No power on my 1918
check the power cable and the connection on the back... Also check to see if the control boards on the control panel have any scorch marks.. and check if any fuses are blown.. have you tried another appliance in the same socket?
Aug 07, 2008 | Miele Novotronic Premier 500 Front Load...
Brushes on miele 562 machine
Your question is not very clear but I will try to help you. If you need the brushes for the electric motor need to be replaced, you can google parts replacements for your machine, or go to the Miele Company on line and request the parts for your particular model.
Dec 28, 2012 | Miele Novotronic Premier 500 Front Load...
Miele front loader rubber door sela has small tear
No.
At the beginning of every cycle water enters appliance via top of door seal this is connected to the inlet water supply
Jul 05, 2010 | Miele Novotronic Premier 500 Front Load...
I haven't used the miele novotronic washing machine in our other house for a year and noticed when i tried today the water was only dribbling into soap tray-thereis enough pressure in water feed so feel...
hi,
More than likely the problem is actually the inlet valve which only partly allows water to flow into the unit. you would need to remove the lid and replace the inlet valve which is on the left hand back corner of the unit. Valves are available from Miele
Jun 07, 2010 | Miele Novotronic Premier 500 Front Load...
Washing machine not spinning
Hi there are 3 possible causes.
1. Out of balance load (drum is divide into 3 sections if weight i one section is greater then 1.25kg than another section appliance will not spin)
2.Carbon brushes ( Normally good for at least 10 years)
3. Vent ( Y - Piece) from drain pump blocked.This requires front panel to be removed.
If the machine detects a fault then an indicator light will flash,(rinse light for motor circuit).
Apr 22, 2010 | Miele Novotronic Premier 500 Front Load...
Tripps electric when heating miele w989i
you may have a faulty heating element or the wire going to the element has broken off and is touching the casing of the unit. if you are confident and able to remove the front panel you will see the heating element under the drum.
Sep 27, 2009 | Miele Novotronic Premier 500 Front Load...
Wate rleak Miele premier 300
I have exactly the same problem with my new Miele washer dryer - and my kitchen is soaking wet. Have you found a solution ?
Jul 28, 2008 | Miele Novotronic Premier 500 Front Load...
Miele Premier Novo Washing Machine
Open drain door at bottom front left of machine. Pull yellow tab that is there. This is the manual door opener.
Jul 15, 2008 | Miele Novotronic Premier 500 Front Load...
The conditioner part of the drawer is still blocked. Take the drawer out and turn it over, on the bottom of the drawer you will see what looks like a blanking plug, it's about 1" or so in diameter. Carefully, prise off the plug with a flat blade screwdriver, and you will find lots of sludge blocking the syphon path. Remove syphon and and run hot water through until you can see daylight through the syphon hole where you just removed that blanking plug. Re-fit blanking plug giving it a little tap home. This should sort it.
Jan 07, 2008 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic Premier 500 Front Load Washer Logo
323 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
