Question about Kenmore 45981 Washer
Kemore error code three dashes
What does three dash error code mean?
  • 1 more comment
  • luxordevco Jan 31, 2009
    no blinking just three dashes- tried to "Unlock) controls by holding button for three seconds- DNW. Was getting the popular F11 code- I replace the main module and now get the three dashes. Thanks
    dont see anything refering to three dashes- please help
  • luxordevco Feb 03, 2009
    Please review and advise the three dash error code- Thanks
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Would it be possible to to place back the old/original main module? This is to confirm that the 3 dashes would be replaced back with the F11 code.
I am tempted to think that the new main module is faulty too and even worst since it can not even display error codes. This tell us that the logic circuitry fails and can not run the built-in diagnostics..
Alternately, you can review the replacement; how the connectors are plugged in, the wires and if the board is properly grounded.
Good luck and thank you for using FixYa.
Posted on Feb 03, 2009
    Sergeant:
  • 250 Answers
3-333 communications failure between the Foreign Interface
and the machine.
Press 0 and start button at same tame.
Enter 6789 and select confirm. Select dc 131 NVM read/write.
select input number an type:
752-002 0 = Foreign Interface disabled 1 = Foreign Interface Enabled
759-015 1 = Addition Device (Auditron) 2 = Subtraction Device (Debit card)
if you want to see current value select "read"
Posted on Jan 31, 2009
  • 916 Answers
3 dashes is a door lock error code. Try resetting the washer and see if the problem goes away. Unplug it overnight and try it again in the morning.
    Sergeant:
  • 326 Answers
The connection is not connected properly open the unit that again remove all the connecting wires and reconnect it properly.as negative to the negative and positive to the positive.as the dashes what you r getting are not any error codes that can be manually resetted.its wrong connecting wire sign. just make it proper.
    Genius:
  • 2,035 Answers
Did you test the replacement board on the washer before replacing it , it could the new board is defective get check the board from the place where got the replacement part ,if possible get it exchanged and then install on the washer and check if your same error ...
Good luck...
  • Kenmore Master
  • 19,396 Answers
Three dashes is not an error code, Sears Kenmore codes are of type F -- , try to reset the appliance by cutting power for ten minutes, if it stays the same way it may be a faulty control board.
You can find parts and schemaitics entering your model number here.
    Scholar:
  • 191 Answers
I think this will help you.
F/11 SERIAL COMMUNICATION ERROR
Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
Possible Causes / Procedure
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted upside down. The wires should be to the left when facing the MCU connectors.
For all the diagnostics and disassembly proceedures please click here to download the service manual for your unit.
  • 132 Answers
    Top Expert:
  • Kenmore Master
  • 77,499 Answers
Please explain what 3 dash means, does it blink, pause and then blink again, if so this is a code
  • yadayada
    yadayada Jan 31, 2009
    asking for more info so i could help.
What does error code mean on the dash board of a 1998 Buick Regal?
What is the error code? Most auto parts places will read the code from the computer for free.
You may need to "jump" your car to start it, depending on how long it's been sitting.
May 22, 2015 | Buick Cars & Trucks
Tip
XBox360 error codes (Three Red Lights of Death, Red Ring of Death, X-Clamp)
Hi.
XBox 360 error codes are displayed with flashing lights in the ring of bi-color LEDs located around the start button, like in the picture below:
They are often called lights of death. The technical name from Microsoft is Light codes.
LEDs located around the start button can be green or red. When they get red it means that there is a problem.
When the XBox is operating normally The leds will be green. The number of green segments indicates the number of controllers connected to the Xbox.
Here a working Xbox with one and four controllers connected to the console:
If the lights are red instead of green, then there is a problem. Here the four common error codes:
A: The code in picture A, with only one red segment on and flashing on the fourth quadrant, means that there had been an hardware failure. The internal component failing is often not specified.
The light code is accompained by an error message on display, telling a numeric code that can better address the cause of the fault. The best thing to do is contacting Microsoft to find out the reason for the code. Depending on the code you may also be asked to perform a secondary error code retrieval procedure.
In the Example above E74 means that there is an hardware fault on video connections or GPU.
B: If the first and fourth quadrant LEDs are on, that means that there had been overheating. Internal fans, CPU and board must be tested.
C: General hardware failure. This means that the console detected an internal failure, but no error code is displayed on screen. Call Microsoft to get instructions on detecting secondary code or sending the console for repair.This error code is commonly called Three Lights of Death.
D: The last error means that there is a problem with the AV connection to the monitor or TV. The code is not displayed if you use HDMI connection, in that case you get an on-screen error code. Test using different cables. If that does not fix the problem, this error means that the XBox Gpu is fried. This error code is commonly called Red Ring of Death or RROD.
In the near future I plan to publish a new article explaining how to troubleshoot secondary error codes. In the meanwhile, if you need more support, you can ask a question to our experts or contact Microsoft.
Regards.
on Apr 08, 2010 | Microsoft Xbox 360 Console
What does error code 63 from dash mean on a 08 mazda 3 mazda check light on dash reads error code 63
Don't know the code error but you can take it to your nearest parts store and they should be able to hook it up to there code scanner. They normally will do it for free. I would call them first to be sure they offer this test. Auto Zone will usually do it as well as Napa. I hope this helps.
Mar 08, 2015 | 2008 Mazda 3
P0421 CODES AND C1201
C1201 error code means that you have some problem in engine control system.
Possible causes for P0421 error
  • Warm Up Three Way Catalytic converter deterioration or malfunction
  • Exhaust system leaks
  • Loose front or rear HO2Ss
  • Faulty front heater O2 sensor
  • O2 sensors harness is open or shorted
  • O2 sensors poor electrical connection
The P0421 code means that the vehicle's control module has detected that the three-way catalytic converter is not working properly (is not as efficient as the factory is expecting). Replacing the oxygen (O2) sensors may sometimes fix the code, but in most cases the catalytic convert needs to be replaced to fix the problem.
Apr 24, 2014 | Toyota Avensis Cars & Trucks
F24 error code
Hello there
  1. Turn the oven off and wait three minutes before turning it on again if "F -24" or "F-25" is displayed. These error codes mean the keys on the control panel were pushed or touched for longer than 60 seconds. Leaning against the oven or hanging objects in front of the controls can cause these error codes to appear.
  2. 3 Press the "Oven Off" key to clear the display and reset the oven if an "F" followed by two numbers is shown on the display. Wait three minutes, and turn the oven on. This type of error code indicates a problem with the signal received by the electronic control board.
  3. 4 Write the error code down if an error code displays more than once. Thermador recommends calling a service technician if an error code reappears.
Dec 04, 2010 | Whirlpool Kitchen Ranges
Have error code 33 on dash what does it mean 08 model r1
Error Code 33 means that there is problem an
Open circuit detected in the
primary lead of the cylinder-
#1 ignition coil.
• Open circuit in wire harness.
• Malfunction in ignition coil.
• Malfunction in ECU.
Hope this helps
Mar 02, 2010 | 2008 Yamaha YZF-R1
Xbox error code 05 & 07
error code 5 means the hard disk drive is not locked "retail bioses require a locked hdd
error code 7 means hdd timeout
im going to assume the hard disk drive is going bad or you did something wrong.
Nov 05, 2008 | Microsoft Xbox Console
PANASONIC UF-8000 ERROR CODE E03-20, copy function not working.
Error code E3-20 Main Motor Rotation.
Loud clicking sound fuser unit drive gears cracked not driving
Apr 01, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Sylvania zv420SL8 error code E4
The error is actually a catch all for three problems or a better way of putting it three problems can generate this error Sylvania requires that you call them with the error code to get an answer on which of the three errors it could be, However I can tell you from working on these units that the issue has to do with recording laser power.
Oct 09, 2007 | Televison & Video
Kenmore 45981 Washer Logo
51 people viewed this question
Sal De
fordexpert
Robert Rankin
