Question about Palm Z22 Handheld
My screen goes blank every time I try to access the "memo" menu and I have to do a soft re-set to to turn it on again. Any suggestions?
  • marge May 11, 2010
    How will I restore my data to the handheld?  The hotsync function just says handheld to desktop and not the other way so I'm afraid that if I erase everything and then do a hotsync that the then blank handheld will override and erase all the data on the desktop.  Will it?
  • 115 Answers
I would do a hard reset...but after you are sure have backed up your data, as it will wipe back to factory settings....
1...While holding the power button, use the tip of the stylus (or a similar object
without a sharp tip) to gently press and release the reset button inside the hole
on the back of your handheld.
2... Wait for the Palm Powered™ logo to appear, and then release the power button.
3... When you see the message that warns you about erasing all of the info on your
handheld, do one of the following:
• Press Up on the 5-way navigator to finish the reset and show the touchscreen.
• Press any other button to do a soft reset.
Posted on Jan 31, 2009
My co-worker has a nextbook and whenever she tries to go in to read her book(she was already half way through) the screen goes blank/black. Any suggestions??
Hi
Could be a number of reasons, check if in battery saving mode. Check in settings menu times for screen time out. Inactivity time out or battery low on power setting.
Jun 26, 2014 | Computers & Internet
Kocaso M1066 won't get past the first blank white startup screen. Suggestions?
Memory could server me wrong, but on some tablets you have to hold down the reset button and the power button at the same time in order to get a complete reset. I think this one might fall into that category. The following sequence works with other models of the same manufacturer, so give these a go if the first suggestion fails.
The button to hold down is the menu button next to the home button. With it powered on hold down tthe menu and power buttons until it goes off, then release the power button and then hold it again while holding the menu button. An android with an exclamation and triangle will appear. Tap the power button and the menu for reset or updates appears. Select factory restore and follow instructions then select reboot at next screen.
Hope they help,
Gill
Jan 28, 2014 | Tablets & eReaders
Lost my internet, wont load so need settings please
  • Navigate to your cellular provider's website or call its customer service line. Access the "Support" section of the website or ask for the technical support division. Find the "Access Point," "MMS" and "Wap Gateway" settings and write them down.Power on the HTC phone and then press the soft key on the left side to bring up the main menu screen. Scroll down through the menu and highlight the "Settings" option. Press the square button at the center of the phone to access the settings menu.Choose the "Connections" option from the settings menu. Scroll down through the new list that will appear and choose "GPRS." Highlight the "New" option and press the center button. Choose "Connects To Internet."Scroll down to the "Internet" heading and choose "Change." Key in the Access Point that you wrote down earlier. Scroll down and press "Done.Navigate back through the menu to the "GRPS" option. Press "New" again, and this time, choose "Connects To Wap." Choose the "MMS" option. Key in the MMS settings you wrote down earlier.Return to the main menu screen and then select "Messaging." Highlight "MMS" and press the right soft key to bring up a second menu. Choose "Settings," and then choose "MMSC Settings."Press "Edit" and enter in the "MMS" settings again. Scroll down to "WAP Gateway" and enter in the information you wrote down earlier.Power cycle the phone by turning it off and then back on to complete setting up the WAP settings.
  • Oct 01, 2010 | HTC Cell Phones
    How can you record an incoming call
    To create a voice memo follow the steps below:
    1. While in standby mode, press the left soft key for Menu
    2. Select My Stuff
    3. Highlight Audio, using the navigation keys
    4. Press the left soft key for Options
    5. Select Record Audio (2)
    6. Press the center navigation key to begin recording
    7. Press the left soft key to Stop recording
    8. The audio recording is automatically saved
    To Access My Recorded Voice Notes On SGH-a707? To review a voice memo follow the steps below:
    2. Select My Stuff
    3. Select Audio
    4. Highlight the desired voice memo, using the navigation keys
    5. Press the left soft key for Options
    6. Select Play (1) to review the voice memo
    Apr 03, 2010 | Samsung SYNC SGH-A707 Cellular Phone
    Cannot select or delete a memo item.
    I had this happen and the way I got around it was to delete the memo entry from the desk top and then set hotsync so the desktop to overwrite the handheld and force the new memo data into the z22.
    I don't know what the root cause is. The problem is a corrupted data file but no idea what causes this other than something that can interrupt the writing of the file data. It might happen again as all this does is fix the error not the cause. Having said that I had this happen a few times within a short time then have never had it since (a few years).
    Aug 31, 2009 | Palm Z22 Handheld
    How to put cell phone to speakerphone mode
    Manual:
    http://www.cellphones.ca/upload/manuals/samsung-sph-m300-manual.pdf
    From Page 39 of the manual:
    Selecting Options (right softkey) during a call displays a list of
    features you may use during the course of a call. To select an
    option, press the corresponding keypad number or highlight
    the option and press . The following options are available
    through the Options menu:
     (1) Key Mute/Unmute allows you to mute the microphone
    on your phone so the caller is unable to hear any sound.
     (2) Turn Speaker On enables the speakerphone feature.
     (3) Set Whisper increases the microphone to its maximum
    level. During a call turn on Set Whisper when speaking
    softly or when the caller cannot hear your voice clearly.
    This mode is useful in meetings or public places.
     (4) Call History checks your call log for Outgoing, Incoming,
    Missed, and Recent calls. You can also erase the logs from
    this menu.
     (5) Contacts accesses the Contacts menu.
     (6) 3-Way Call allows you to talk to two different people at
    the same time. (For more information, see “Making a
    Three-Way Call” on page 189.)
     (7) Messaging accesses the Messaging menu options.
     (8) Voice Memo allows you to record incoming audio from
    your conversation. (For more information, see “Managing
    Voice Memos” on page 135.)
     (9) Tools accesses the Tools menu options.
    Manual:
    Mar 21, 2009 | Samsung SPH-M300 Cellular Phone
    JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
    You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
    Feb 04, 2009 | JVC LT-32P679 32 in. LCD TV
    Cannot access main menu or pages screen
    I think I can help with your issue. I have an LMS 334c and have had a few issues in the past. Called the factory (this answer is not listed any where in your manual) and they instructed me to "Soft Re Boot" my unit and it would put everything back to factory settings. Try this anytime it does not respond for whatever reason.
    Turn the unit off.
    At the same time press the Pages and Power button. Hold both down until you see the square box come up in the screen. You should have your factory settings again. May need to try a few times.
    Lowrance said it works just like a computer, ever now and then it just tries to disect to much information at one time and hangs up.
    Good luck. James Cantwell
    Nov 03, 2008 | Lowrance LMS-330C GPS Receiver
    Blackjack II blank start screen
    Hi dogbyte,
    For some reason, certain Windows Mobile (Standard) devices don't like "list" format for the Start Menu.
    Give this a try:
    1) Remove the battery for 1-2 minutes. (This allows any cached memory to clear)
    2) Power the device back up.
    3) Before openning ANY other apps, navigate to Start > Settings > Display > Start Menu Style
    4) Change this value from "List" to "Grid"
    5) Click Done twice, then click the Home key.
    6) Give the Start menu another try. (Does this resolve the issue?)
    Another forum suggested that Windows Mobile seems to be a little picky about which application appears first on the Start Menu. If you have any custom applications installed, it's possible WinMo's start menu just isn't playing nicely.
    Hope this helps!
    Apr 10, 2008 | Samsung BlackJack II Smartphone
    CH-DVD 300 Blank Screen
    This is almost the same problem for me...Please provide a solution
    Aug 16, 2007 | Cyberhome CH-DVD 300 DVD Player
    Palm Z22 Handheld Logo
    79 people viewed this question
    Top Palm Computers & Internet Experts
    Michael Vincent Cruz
    ray gallant
    Raj Patel
    Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
