Question about Intertherm P3RA-060K Air Conditioner
Intertherm central unit heating side not working right
When I turn on my heat the green light on the thermostat comes on and the unit cuts on but the air is barley warm and then after 45 minutes or so the green light goes out and the air is cold coming out....not sure if the heater coils are not coming on or what?
  • kountry_boy_ Jan 30, 2009
    I dont see any ice. It has a emergency heat on it but when I flip it over to it there doesnt seem to be any difference. When I flip it over to that after the green light goes out all you feel is cold air.
    I dont see any ice. It has an emergency heat but when I flip it over to that it doesnt seem to make any difference. After the green light goes out and I flip it all you feel is cold air.
    President:
  • 1,214 Answers
I am assuming this is a heat pump? (Typical when the t-stat has a green light.).
Please confirm
If a heat pump, is the outdoor unit frozen up? There can be some frosting, but it should not be a block of ice.
If there is an emergency heat switch on the t-stat, can you flip that to emergency heat? Do you get heat then?
Pleas advise and I can help you troubleshoot this problem further.
Posted on Jan 30, 2009
  • Mark Egan Jan 30, 2009
    OK. We've got some troubleshooting to do.
    First of all, how comfortable are you in working with and troubleshooting electrical circuits?
    If your good to go with it, then turn off the power to the furnace, and gain access to the controls. Locate any fuses in the control panel. Remove and test each one. Replace any that are failed (and be prepared to replace them n the event there are short circuits inside the furnace.).
    Let me know what you find, and do not power anything up before we talk again.
Intertherm furnace burner comes on, but blower does not. If I turn thermostat off then back on until it clicks the fan will then come on. It does not do this all of the time, just now and then.
Furnace burner and heat element are not the same. I think the fan time delay, a sensor that turns the fan on when this sensor senses heat, is shot and needs replacing, for a furnace type heat ( gas heat)
Aug 08, 2017 | Intertherm E3EB010H Electric Furnac
Heating eleament keeps kicking on and off.
The thermostat contacts are sticking...replace the thermostat!
Jan 14, 2013 | Intertherm Heating Cooling System 15kw...
Bosch Worcester boiler, central heating not working
boiler may need more pressure in system pressurise to middle of green between 0.5 bar and 1.0 bar
Feb 22, 2009 | Bosch Logixx WFT 2806 Front Load...
Central heating HVAC blows cold air -
is there a light or source of heat near t stat or low battery in tstat
Jan 04, 2009 | Intertherm P3RA-048K Air Conditioner
What's the deal? Wont shut off or respond to thermostat. . .
Red= power........White=heat.............Green=fan.................(grey)-(yellow)=cool .....these are the connectons. Disconnect these wires from the thermostat and know that red/power is the only wire that send power to the thermostat, and the rest sends it back to the unit to call for whatever,, red--to . white for heat... red to green for fan .... &red to grey for cool! OK! Turn all your power on, and use a jumper wire from red / green for fan and see if the fan comes on! Then move the jumper wire from red to green , to red / to white for heat and the fan , wait for 3 minutes before removing and going to the next step. Then red /to grey for cool and check if the outside comes on. Either you have a wire touching past the insulations and making a connection, a bad thermostat ,oe excessive wire lead touching the next connection.Thank you very much!
Nov 05, 2008 | Intertherm Heating & Cooling
Intertherm heating
My heating unit is blowing cool air. The thermostat will start the blower when the unit is turned on at the thermostat, but the air isn't hot. But,when I turn the unit on at the furnace/blower using the "Fan On" button, I can see the heating element heat up. After the blower starts the heating element does out. What could be the problem?
Oct 29, 2008 | Intertherm P3RA-048K Air Conditioner
Elec. intertherm FURNACE
It would help if I knew what type of system you have, lets start with the thermostat. If you disconnect the wires to it, does the heat turn off? I have seen thermostat wires pinched inside the wall, thus bypassing the thermostat controls altogether and it would run constantly. If you send a reply, tell the type. Wall furnace, central unit, heat & cool, gas, electric or heat pump. If you dont know tell me how many wires you have at the thermostat and the colors. You should know this, as you have changed it.
Jan 05, 2008 | Heating & Cooling
Intertherm heat pump
FIRST YOUR OUTSIDE UNIT PROVIDES HEAT BY USING A REVERSING VALVE TO CHANGE THE REFRIGERANT FLOW.THERE IS NO HEAT STRIPS OUTSIDE SECOND YOUR EMERGENCY HEAT TURNS ON ELECTRIC ELEMENTS INSIDE YOUR AIRHANDLER UNIT.IT SOUNDS LIKE SOMEONE HAS WIRED YOUR UNIT WRONG OR HAS THE THERMOSTAT SET IMPROPERLY.WHEN THE HEAT PUMP CANNOT SATTISFY THE SETPOINT THE THERMOSTAT IS SUPPOSED TO TURN ON YOUR ELEC. HEAT UNTILL THE LOAD HAS BEEN REACHED AND THE HEAT PUMP CAN CONTINUE TO MAINTAIN IT.
Nov 28, 2007 | Heating & Cooling
Intertherm to Honeywell thermostat
Typically if you have a yellow wire in the "y" terminal blue is used as common or "c". As far as your jumper from rc to rh, that will depend upon what type of heat you have. If all of your heat and cooling come from your packaged unit outside, yes you will need the jumper. If this does not work maybe you have a bad breaker or transfomer.
Oct 12, 2007 | Intertherm P3RA-048K Air Conditioner
Intertherm P3RA-060K Air Conditioner Logo
220 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
