Question about Whirlpool Calypso GVW9959K Top Load Washer
Dropped a plastic piece into soap dispenser
The plastic tube that lifts fluid into the spray head on a pre wash bottle fell down through the soap dispenser grill. How easy is it to open the machine to retrieve the tube before running another load?
  • 15,935 Answers
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
How do I get a plastic cap dropped down in the back of soap dispenser? I have a front load LG Model wm2450h*a.
take top off, follow shute, remove hose, fish out cap. check out appliancepartspros.com for video on your model how to remove top
Apr 06, 2016 | LG Washing Machines
How can I get a laundry cap out of the drain where you put the laundry soap, bleach and softener?
Can you see the cap?
Is the soap tube a separate piece that you can remove?
What's the year, make and model?
A local repairman would be able to solve the problem, as a last resort.
Nov 30, 2014 | Kenmore Washing Machines
Fill soap dispenser
the dispenser has a pump actuator jus tlike a spray bottle you either lift it up out of back of sink or loosten a nut that holds it you should be able to lift pump with a plastic stem out and pour soap into hole and reverse procedure if you can send a picture that would help goood luck
Aug 21, 2014 | Plumbing
The soap dispenser door will not open. How do I remove the top of the washer to access the soap dispenser? I know that the blue plastic piece for the fabric softener lifts up when I try to pull open the...
To remove top: Remove the bottom screw from the plastic clips on back of the washers top. next, stand in front of machine and, using the palms of your hands, sharply push the top back about 2 inches, allowin you to lift the top off.
Dispenser issue: you may have to drill a small hole in the plastic top of the dispenser to allow you to push the offending part down while pulling on the drawer. seal the hole with silicone or foil tape.
Feb 20, 2011 | LG WM-2277HW Front Load Washer
Soap dispenser doesn't pick up soap
Make sure the clear tube is inserted into the pump head properly.Make sure the tube is not kinked. try filling the bottle full of water and try pumping the water out first. Sometimes the dispenser gets an air lock and takes a bit of continuous pumping to get it to work
Feb 24, 2010 | Price Pfister Marielle Kitchen Faucet with...
Inoperable Soap Dispenser
if the balls fell out you need a new head,sorry.
Jun 20, 2009 | Price Pfister Marielle Kitchen Faucet with...
Price pfister soap dispenser will not work
Replacement parts can be found on amazon. Click here Watkins Hand Soap Made Naturally Since 1868 and take a look. I hope this was helpful. Cheers
Dec 13, 2008 | Price Pfister Marielle Kitchen Faucet with...
Foreign object in soap dispenser
Unplug machine from power, do not restart it until you get the plastic cap, as you can cause more damage.
Try first using a long stick to reach the object at the end of the drawer, inside the hose, be careful not to hole the hose or brak other parts inside the drawer.
If it does not come out this way, I am afraid you will need to take apart the back , and probably also the top panel.
You need to access the hose starting from the detergent drawer and ending into the pump, once the hose is lose on both sides you blow compressed air inside the hose.
If you do not start the machine the pump cannot be damaged.
If you start the washing machine with the object inside, in the best case it will malfunction because hose is obstructed. In worst case you burn the pump as the hose get obstructed.
If machine is less than one year old this maintainance can be covered with guaranty,
If you need to call in a repairman you can use the number listed at the end of the user manual.
Regards
Aug 31, 2008 | Frigidaire ATF6000ES Front Load Washer
Water Leaking really bad from the Dispenser area
Disconnect the plug from the outlet. Remove the top of the washer panel by removing the 2 back hex screws then sliding it back to lift it off of the washer. Take off the front control panel by removing the phillips screws holding it in place. Remove the dispenser drawer. Check the dispenser housing for clogs or lime build up at the bottom of the dispenser housing. Or the drain hose (large black hose attached to the front of the drawer housing) to the washer may be crimped or clogged.
Aug 14, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Model F7441980 Hoover Dual Action Spin Scrub Wide Path
You will have to replace the tank, and it will come with the soap dispenser attached.
Mar 30, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Whirlpool Calypso GVW9959K Top Load Washer Logo
78 people viewed this question
Dan Webster
Dan Webster
Sal De
