Question about Toshiba gigabeat S MP3 Player
Gigabeat Will Not Turn On - Battery Flashes Then Goes Dead
My Gigabeat has been working fine. But all of a sudden it will not turn on. When I press the power button the battery indicator flashes (and looks empty). This would typically tell you the battery is dead and needs to be recharged. I then try plugging it into my laptop via USB cable to charge, but the same thing happens. The battery flashes for a few seconds and then the unit turns off. I cannot get the unit to charge anymore. I tried switching the hold on and off - nothing. I tried switching the master slide thing at the bottom and still nothing. please help.
  • 2 more comments
  • Anonymous Dec 30, 2007
    I am having the same problem. Tried connecting to a A/C mains and after an overnight charge (more than 8 hours) I pull out cable and my gigabeat cannot be powered on. My switch on the bottom is set to 'Battery'.
  • Anonymous Jan 29, 2008
    Same thing with mine!
    I have charged it overnight with A/C adapter, and when I unplug it I get nothing. The battery is set to on. I have flipped the battery switch, still nothing. I have tried charging it overnight two other times - nothing.
  • Anonymous Feb 28, 2008
    i have same problem as everyone
  • Anonymous May 02, 2008
    my s60 had a prob of chargin such that it used 2 flash da screen once n go off again,,, dis prob continued 4 dat entire day..da next day howevr i managed 2 charge it via da power supply i got a new prob it just went off n doesnt seem 2 turn on at all, no flashing screen, try da soln below, hope it works
I called and they told me,i have the same problem, to just turn the battery switch ( bottom thing) off and charge it over night via wall outlet. hope it helps im trying it as i type so i wouldn't know...
Posted on May 19, 2008
I have gone and bought a new battery and still get the same problem. SOmething tells me there is somethign worse internal...
Posted on Oct 15, 2008
The battery has discharged to far for it to be charged via the USB cable. Use the included power supply to plug it into a wall outlet and let it charge there for a few hours.
Posted on Aug 03, 2007
Display on mp3 player shows "Magnavox" and then shuts off
MP3 players are so cheap nowadays, so Id recommend getting a new one instead.
Aug 09, 2009 | Toshiba gigabeat MES60VK Digital Media...
MES60VK Gigabeat - Dead
There is a switch on the bottom left side of the dock connector of the player. Flick the switch to the right and it should work. The switch is the battery cutoff switch. It is there so it will charge only. I have no idea why Toshiba though this was a good idea, but they put it there.
Nov 08, 2008 | Toshiba gigabeat MES60VK Digital Media...
i'm thinking the hard drive is messing up... you know when i dropped my gigabeat S30 it wasn't working n it was freezing and the video files weren't playing at all. it would freeze when i turn on or play video. then i turned it off and then back on using the battery switch. it said "contact the manufacturer for repair" with a yield sign. i really thought i killed it...but i still had my hopes high to fix it myself somehow n i really thought it was from the hard drive. so i took it in my hand and gave it a shake on my palm. like i actually hit it on my palm for once n then i turned it on and it worked =D fineee.... i was so happy n now it still works fine ;)
i hope that helps
May 26, 2008 | Toshiba gigabeat S MP3 Player
Memory Dump/ Not Turning On
first prove the nod32 antivirus for see what is the situation of your memory. after this write for indicated of stay of your memory.
Mar 16, 2008 | Toshiba Gigabeat S30 MP3 Player
have you only been charging it with the usb cable?
try plugging it into a ac adaptor, (make sure the button is in the off position at the bottom)
and it should hopefully restart, then turn it to the on when it's loaded, and leave it plugged in till it's completely charged
that might work
Feb 26, 2008 | Toshiba gigabeat S MP3 Player
Battery is dead
Identical problem - working only with power cord.
Wont power on battery or usb cable.
I actually opened player and check every single option.
(I am experienced electronic - tech.)
Result: battery is fully charged (768 mA/ 3.97V on bench)
Battery switch on bottom fully functional. (switching on/off 3.97V
comming from battery)
USB supply 5.0 V in perfect order.
There is no "EASY" fix for this problem.
It is either problem with firmware (low possibility)
or semiconductor on logic board (practically not fixable on DIY basis)
I bought my Gigabeat 60Gb for $ 70.00 used on Ebay so
I will live with this problem.
Feb 04, 2008 | Toshiba gigabeat MES60VK Digital Media...
Toshiba gigabeat MES60VK (60 GB) stopped working
There is a little battery cut of switch at the bottom of the device. You can unbend a paper clip and switch it off. Then switch it back on after a few seconds. Plug it back into the usb cable to charge it. It should work ok now.
Dec 26, 2007 | Toshiba gigabeat MES60VK Digital Media...
Gigabeat has froze completely
Turn off the battery with a toothpick or pencil then turn it back on. You can do this on the bottom side.
Aug 09, 2007 | Toshiba gigabeat S MP3 Player
Gigabeat 40GB screen frozen
well, it would be really easy to take off the battery. The battery is simply plugued with a little 3-pin wire, u just pull on it and put it back in. Now to open that gigabeat, its pretty easy. I even got some images for u. Go at this website (its for the F10 and u have the F40, but its the same thing):
Mar 24, 2007 | Toshiba Gigabeat F41 (40 GB) MP3 Player
Toshiba gigabeat S MP3 Player Logo
567 people viewed this question
Top Toshiba Audio Players & Recorders Experts
James DuPont Jr
James DuPont Jr
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
