Question about Copystar CS-2030 Copier
How do i load card stock paper in my copier...it jams.
  • 55 Answers
card stock is tricky to run do you have a bypass tray this is not a paper tray it is a tray where you can put 1 or 2 copies of paper in it? It is on the side of the copier if you have one try that.
Good Luck
Posted on Jan 30, 2009
Paper jams with card stock
Lubricate the print head shaft. Not too much as it will collect dust.
May 04, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
Jammed card stock
This machine has auto paper type sensor- may be at fault
May 01, 2009 | Dell Photo 964 All-In-One InkJet Printer
The paper jams up when the printer pulls it into print
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed throught the printer. The reason for this, in some cases I have been able to clear the paper track of debris that was deposited there over time. Worth a try. I have fixed a number of printers this way saving costly repairs. Bud
Jan 21, 2009 | Lexmark X4530 InkJet Printer
I have hp photosmart 7850. I was printing envelop and there was paper jam. I pulled out the stock and jammed envelop and ever since the printer would not load paper to prinit and keeps flashing for error....
I have had this happen to several people and also to me. What I did is to take a sheet of Card Stock (Heavy Paper) and put it through the feed putting pressure on the Card Stock and pressing on the feed button. What happens is that a piece of the jammed envlope or document gets caught in the feed way and will not allow the document or envelope ( in your case) to pass. It should solve your problem if it works. Bud
Jan 05, 2009 | HP Photosmart 7850 InkJet Printer
Paper jam
I have had this problem with other printers. What I did is to take a sheet of Card Stock 8.5" x 11" , putting it in the Feed and push the print button while applying a small amount of pressure on the card stock. Sometimes a small piece of paper gets in the path way and indicates a paper jam. Could be another problem that is causing the jam indication. Worth a try. Bud
Jan 04, 2009 | Lexmark X5470 All-In-One InkJet Printer
Samsung 6210 paper jam
open access(load area) check feed roller take a q tip and use rubbing alcohol and clean photo eye that detects paper be sure all jammed paper is removed
most jams are at the exit and there may be some paper obstructing that area
insert card stock through the paper path
insert ine
Dec 30, 2008 | Nikon COOLPRINT Thermal Printer
Trouble printing Clean Edge business cards
not tru. you need to go to printer set up and chane the setting to heavy paper so that the fuser will fuse the toner in to the card stock
Dec 03, 2008 | Brother MFC-465CN InkJet Printer
PIXMA MP450 alarm light is on and it says paper is jammed but there isnt any jammed, please help?
You could try this, but there is no guarantee. There are a lot of sensor in the paper path of a Canon printer. When these sensors get stuck in the up position, pushed up when paper is present, you get the paper jam alarm when no paper jam is present.
The trick to try that sometimes works is to run some index card stock through. Insert the index card stock in the paper tray, run a print test and as it runs put some gentle firm pressure on the card stock to ensure it travels smoothly. Once it is done the sensor may have reset itself. In lieu of card stock you can use a thick magazine cover and cut it to size of an 81/2 x 11 piece of paper.
If this works great. If it doesn't let me know and please don' t bother to rate this if it fails. It works some of the time and not most of the time.
Thanks,
Worldvet
Nov 20, 2008 | Canon Office Equipment & Supplies
T642 Paper Jam and Check paper stock jamming.
You need to change the paper type when using card stock, plain etc.
As for the paper jams; you need to check the exit sensor at the exit door, also if you have a duplex, 2-3 drawer you also need to check for jams.
Sep 08, 2008 | Lexmark T642 Laser Printer
Copystar CS-2030 Copier Logo
451 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
Oloyede Monsuru
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
