Question about Sony STR-DE545 Receiver
The STR-DE545 My sound works intermittantly and when it does is only for about 30 seconds before it goes silent. About 6 months ago i placed an xbox 360 on top of the unit and the xbox does produce alot of heat. Im not sure if the xbox info was important but thought i should mention. I checked all the speaker connections and they are solid. Also, since the time i origianlly bought it, the manual power button does not work. you can only turn it on/off with the remote.
    Sergeant:
    Champion:
  • 319 Answers
Check for faulty speaker wiring and connections
Posted on May 01, 2008
SOURCE:
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ...
www.richardfarrar.com > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from www.avsforum.com
Dec 12, 2015 | Audio Players & Recorders
Str-de545 sony not putting out sound to rear speakers
From page 46 (Troubleshooting)-
No sound or only a very low-level sound is heard from the rear speakers.
>>> Make sure the sound field function is on (press SOUND FIELD - MODE).
>>> Select a sound field containing the word "cinema" or "virtual" (see pages 28-30).
>>> Adjust the speaker volume (see page 19).
>>> Make sure the rear speaker size parameter is set to either SMALL or LARGE (see page 17).
Jan 11, 2011 | Sony STR-DE545 Receiver
Optical digital cable connection ?
It only works through DVD setting
Jun 20, 2009 | Sony STR-DE545 Receiver
Sony DE-445 reciever flashes PROTECT
Sounds like a grounding problem. If the ground plug isn't missing or loose try plugging it into a different outlet.
Jun 13, 2009 | Sony STR-DE445 Receiver
Intermittent "static surges"
Ionic Breeze is no longer supported because Sharper Image went into bankruptcy as a result of these products proving to be ineffective.
Here is a Sharper Image article
Here is an EPA article
Jun 17, 2008 | Sharper Image Professional Plus Ionic...
STR-DE545 Receiver -
I just turned my DVD player off when my STR-DE545 was still in DVD input mode and it came up LOCKED, maybe the input that you are using is not receiving a signal?
Feb 03, 2008 | Sony STR-DE545 Receiver
Sony STR-DE545 5.1 not working
Are you connecting from your DVD player to receiver using an optical cable or simple AV cable?
Nov 06, 2007 | Sony STR-DE545 Receiver
Problem with 'central' speaker output
took apart my reciever and found that the blue relays in back in the middle are starting to malfunction. I tapped on them and they clicked. When I tapped the right one, i got the sound back in my center speaker.
Oct 30, 2007 | Sony STR-DE545 Receiver
Sony STR-DE545 receiver
You should have access to receiver's format from remote or front panel. If the unit was moved around a lot and for a long period, the micro-processor may have locked due to ambient static electricity. Try unplugging unit for seversl hours, then re-try
Aug 19, 2007 | Sony STR-DE545 Receiver
Sony STR-DE545 Receiver Logo
114 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
