Question about GE Spectra JBP78 Electric Kitchen Range
Trying to remove oven door
I have a G E Spectra TRU TEMP electric range. I am having a problem removing the oven door. Can anyone help?
Ge spectra elec., how to remove the oven door
Posted on Dec 18, 2010
I have a GE Spectra range/oven the oven will no come on and gives me a F4 error message, can you help?
Hi
F4 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 28, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
General electric spectra electric oven, door doesnt close complete. Heat from the oven comes out.
please,i need help!i have a problem about my GE spectra electric oven door is loocked i cannot open at all,what i can do?to be open?
Mar 29, 2011 | GE Spectra JBP78 Electric Kitchen Range
Error code f2 broiler comes on by itself and won't shut off
F2 Oven over temp - exceeded 590F with door in unlocked position or 990F with door locked If actual temp condition occurred, look for welded relay contacts or high resistance connection or any cause in the oven temperature sensor circuit
Mar 01, 2010 | GE Spectra JBP78 Electric Kitchen Range
Ge tru temp range, oven will not shut off
You have a malfunctioning oven switch,get it replced or simply remove the fuse for your oven there maybe 2 fuses.
Jan 30, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
GE spectra jbp66 oven is off but F2 error comes up and oven turns on and wont turn off. ive already unhooked and rehooked temp probe and took out the plastic connector and used wire nuts instead and...
Hi There
I have found this for you to read and hope this helps you.Let me know how it goes.
F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensorThank you for writing to fix ya.
Best Regards Richard
Jan 07, 2010 | GE Spectra JBP78 Electric Kitchen Range
GE Profile Spectra Electric Oven.
call a appliance and parts store give them the tear and model number from stove it is inside the door or on back it5 mkay also be on the top under the fuse panel access door
Dec 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Do you kep door closed when broiling
Hi, yes, your oven door should be closed , at all times whenever you're using it, otherwise your home will become oven, use oven thermostat to maintain temp, door should be closed, especially on broil. knob you turn, to light oven is also a thermostat. good luck.
Aug 10, 2009 | GE Spectra JBP78 Electric Kitchen Range
Oven door won't open
The micro switch in the latch has failed.
You must turn off the gas supply.
Remove the screws from the surface burners.
Raise the lid to access the door mechanism to open the door and to replace the switch.
May 23, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Bottom gas oven will not light
Ignitor. Easy fix.The new part comes with 2 high temp wire nuts. The wire is extra long. I would cut the old one at the base just to make it easier to replace.Remove the door to make life easier.
Jan 21, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra JBP78 Electric Kitchen Range Logo
1,027 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
