Question about Kenmore 24032\24036 Top Load Washer
NO POWER SEEMS TO BE GETTING TO WASHER
I REPLACED THE LID SWITCH AND IAM STILL NOT GETTING POWER TO MY WASHER, WHAT ELSE COULD THIS BE , BEFORE THE WASHER CLUNKED OUT ON ME, IT WOULD WASH BUT WOULD SHUT OF AT RINSE AND KICK OFF THE GFCI , I WOULD HAVE TO MANUELY TURN THE TIMER KNOB TO GET A COMPLETE WASH
  • 640 Answers
Defective timer..
Posted on Feb 01, 2009
Frigidaire affnity no power washer does nothing
see this causes and fix it. God bless you
see the diagram attached and troubleshooting.
1. No power to the washer
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
2. Lid switch
The washing machine may not function if the lid switch is defective. The switch is usually located near the door. Replace if found defective.
Sep 30, 2012 | Frigidaire Affinity ATF7000E Front Load...
Does not run
2. Lid switch
Sep 26, 2012 | Samsung WF330ANW Washer
I just replaced the door lock because the door would not lock and now the machine will not work.
It doesn't work at all If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Jan 05, 2010 | GE WSXH208A Front Load Washer
WE just installed both the duet washer and dryer. The dryer starts up just find but the washer will not turn on. Checked the outlet and it is working..so there seems to be no power getting to the machine....
Hi, check the following trouble spots below. you will find the issue in one or, all the areas stated.
2. Lid switch/door latch
The washing machine may not function if the lid switch or door latch mechanism is defective. The switch is usually located near the door. Replace if found defective.
**If you are getting power to the washer and, step 1 and 2 check out ok, replace the timer control or control Board and start switch as well.(You can test the continuity or, resistance level of the Lid/door switch with a multimeter(ohm).
Sep 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The washer doesn't start
Sep 04, 2009 | Whirlpool Washing Machines
Lsq9010pw2 washing machine won't do anything tried giggling master switch
1. No power to the washer Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
2. Lid switch/door latch The washing machine may not function if the lid switch or door latch mechanism is defective. The switch is usually located near the door. Replace if found defective.
**If you are getting power to the washer and, setp 1 and 2 check out ok, replace the timer control or control Board and start switch as well.(You can test the continuity or, resistance level of the Lid/door swicth with a multimeter(ohm).
Aug 27, 2009 | Washing Machines
No power to my bosch maxx classic
2. Lid switch/door switch
**If you are getting power to the washer and, step 1 and 2 check out ok, replace the timer control or control Board and start switch as well.(You can test the continuity or, resistance level of the Lid switch/door switch with a multimeter(ohm).
Aug 17, 2009 | Bosch Washing Machines
Hotpoint aquarius wt540 no power in machine no light at switch
The washing machine may not function if the lid switch or door switch is defective. The switch is usually located near the door. Replace if found defective.
**If you are getting power to the washer and, step 1 and 2 check out ok, replace the timer control and start switch as well.(You can test the continuity or, resistance level of the Lid switch with a multimeter(ohm).
Jul 16, 2009 | Washing Machines
Wont turn on at all
2. Lid switch
Jul 10, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore Top Loader Washing Machine
check to make sure the lid switch is closing when you close the lid. When you open and close the lid you should here a click similar to a wall light switch.
Also check the lid to make sure the tab has not broken off that actuates the lid switch, your model may not have a tab on the lid.
ask more questions is lid switch is functioning,
Jul 16, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
Sal De GO PATS
fordexpert
Ed Mac
