Question about Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ...
My price pfister bathroom faucet wont shut off.
Pipes froze in the basement, when the water was turned back on the cold water would not shut off the hot will. I replaced the ceramic valve but the water continues to run. Could I need a new faucet or does another part need to be replaced?
    Novelist:
  • 148 Answers
You may need a new fucet...the manifold opening for the cold has probably craked or split
contct price Pfisterrdirectly they may send you a new faucet
Price Phister is more about looks than function they want to keep their marketing sales
when I built my house I ut rice phister in because of the looks ..function was marginal
Posted on Jan 31, 2009
How to reverse Pfister PP-6CD-NL valve
flip the locking ring at the top of the stem
Jul 06, 2013 | Plumbing
We have a new Price Pfister 49 Series bathroom faucet set with two handles. Even with the hot water tap open full the water just dribbles out
If you have full pressure on the cold water side and low pressure on the hot side then you well need to remove and clean or replace the cartridge for the hot side. If you have low water pressure on both sides try removing the aerator and cleaning it.
If you need to replace the cartridge on the hot side do both sides while you at it.
Whenever you work on any faucet before you turn the water on remove the aerator and run the water for a few seconds then replace the aerator.
Mar 07, 2011 | Price Pfister Two Handle Lavatory Faucet -...
Just purchased the Price Pfister 42-YP. The hot water has limited water - just a trickle. What can i do to adjust?
Hi, David pressuming the water flow was good before you put in this new tap, then other than a problem with the tap! have you checked if you have an isolater valve on the pipe work under the unit, if so check that it is fully opened?
Thanks Paul.
Aug 31, 2010 | Price Pfister 42-YP0E Ashfield Single...
I installed a Price Pfister kitchen faucet model low water pressu
yes it should have a flow restrictor in the end of the spout. You might need to clean it out
Mar 08, 2010 | Plumbing
We cleaned our price pfister faucet because we had low cold water pressure - when we hooked it back up and put the handle back on the water will not turn off.
You more then likely replaced the diverter washer backwards. There is a washer/gasket that has multiple holes (2 or 3) and it is probably just rotated 180 clockwise (or counter).
There are very few moving parts in a faucet so this should fix it.
Apr 13, 2009 | Price Pfister 34-3LC Genesis Kitchen...
Price Pfister ashfield collection shower single lever.
This sounds like a proper with your water heater. If you just installed this new shower head. First take it off and make sure that the hot water valve is opening fully if that checks out then go to the water heater and make sure the pipes check out ok and also that the heater is ok. Try putting a water heater blanket on it. Also try getting some pipe cover and cover the hot water line so on really cold days or not you will have warmer water
Feb 13, 2009 | Price Pfister Ashfield Single Control...
Handle on faucet shuts off on its own
I had the same problem. The Price Pfister web site recommends removing the handle (unscrew the dome cap, then remove the phillips screw to get the handle off) then tightening the retaining ring (I used channel lock pliers on largest setting. It worked. However the retaining ring is plastic on some models, and they recommend replacing it with a brass one. I haven't taken that step yet, we'll see how it goes (mine is plastic).
Dec 01, 2008 | Price Pfister Marielle Kitchen Faucet with...
Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ... Logo
232 people viewed this question
Top Price Pfister Plumbing Experts
Roscoe007
john h
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
