Question about Nikon Coolpix S210 Digital Camera
Formatting Memory Card
I just recently got a Nikon Coolpix for Christmas. My stepdad put a kingston 2GB memory card in the camera and I took pictures. When I try to put them onto my computer it says the memory card hasn't been formatted and that if I try to format I'll lose all the data on the memory card, is this true? is there a way to keep all my pictures now?
    Sniper:
  • 55 Answers
This memory card not formatted error is quite famous, I saw it before, but luckily I found the solution, check it out
Fix Memory card not formatted error and recover files
hope that you can find the help as me.
Posted on May 16, 2013
    Problem Solver:
  • 9 Answers
Are you sure the pics are on the memory card
I had this problem and the camera had been writing to internal memory
Posted on Feb 04, 2009
Nikon LL110 still says no more memory after formatting new card
Sounds like you have the wrong type memory card for the camera, check user manual and make sure you have bought the right type and capacity card.
Jan 27, 2013 | Nikon Coolpix S51c Digital Camera
Memory card size
i think those photos save in your camera built in memory. took the card out and turn on the camera . NOw press the play button and see the photos appeared in screen or not. If yes then you have to make the default storage location as your memory card.
Aug 07, 2012 | Nikon Coolpix 2000 Digital Camera
How do I delete the pictures from my Nikon coolpix880 camera
Use this option to format the internal memory or memory card. Formatting the Internal Memory To format the internal memory, remove the memory card from the camera. The [Format memory] option appears in the setup menu.
Formatting the Memory Card
When the memory card is inserted in the camera, the [Format card] option appears in the setup menu.
or for more detail get the user manual from here
http://www.nikonusa.com/pdf/manuals/coolpix/L12_en.pdf
do rate the solution if helped
Nov 28, 2010 | Nikon COOLPIX L12 Digital Camera
Cannot find instructions in manual for Nikon Coolpix S210 on how to delete ALL photos from memory disk. It will let me delete one at a time but I want to wipe the memory card clean. Thanks for any and all...
These instructions are from the Instruction Manual of the Coolpix S 210 and need to be carried out within the Set-Up Menu.
Refer Page 19:
Removing Memory Cards
Before removing memory cards, turn the camera off
and confirm that the power-on lamp is off. Open the
battery-chamber/memory card slot cover and press the
card in 1 to partially eject the card 2. The card can
then be removed by hand.
B Formatting Memory Cards
If the message at right is displayed, the memory card must be
formatted before use (A110). Note that formatting permanently
deletes all pictures and other data on the memory card. Be sure
to make copies of any pictures you wish to keep before formatting
the memory card.
Use the multi selector to choose Yes and press k. The
confirmation dialog will be displayed. To start formatting, choose
Format and press k.
Do not turn the camera off or open the battery-chamber/memory card slot cover until
formatting is complete.
• The first time you insert the memory cards used in other devices into the COOLPIX S210, be sure to
format them using this camera (A110).
Refer Pg 110:
 Format Memory/m Format Card
Use this option to format the internal memory or a memory card.
The Format memory option appears in the setup
menu.
Formatting a Memory Card
Format card option appears in the setup menu.
Hope this helps
Ian
Aug 09, 2009 | Nikon Coolpix S210 Digital Camera
Nikon Coolpix S60 is the camera. The problem is
Put the memory card into the camera, then use the "Copy" command in the Playback menu.
Mar 08, 2009 | HP Photosmart M415 Digital Camera
KINGSTON 4GB MEMORY SD CARD
Check if your camera can support a 4G card. Some don't support than 2GB. if it supports, re-insert the card.
PS. If you have a card reader. Formatting once from your computer can help.
Jan 15, 2009 | Kingston 4GB Secure Digital High Capacity...
Nikon Coolpix L4 Memory card problem
Back up all the pictures on the card and then format the card.. Everything will be back to normal.
Note: While formatting select FAT32 file system as it is more reliable..
Jun 18, 2008 | Nikon COOLPIX L4 Digital Camera
Moving images from camera to memory card.
Use the usb cable, or use a card reader.
Dec 04, 2007 | Nikon COOLPIX L3 Digital Camera
Camera stuck when using memory card
hi, i had a problem with my camera where i put in memory card and it said 'out of memory' i took the card out turned on camera went to set up mode and found one that said 'rest to factory defaults' pressed that and then put card in and all ok, might be worth a try :-)
Mar 13, 2007 | Nikon Coolpix 3200 Digital Camera
Nikon Coolpix S210 Digital Camera Logo
202 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
