Question about Lexmark Wheelwriter 10 Series II Typewriter
Need to print the same thing over and over
We need to print over and over and over get the point! on a plain piece of paper but we don't have our manual. can you help? wheelwriter 10 series 2. thanks!
    Problem Solver:
  • 3 Answers
Manuals are available (scanned) on the Lexmark website under the Publications button on the left hand side of the homepage. At the bottom of the Publications page is a pull down menu for IBM typewriters. Find your model on the pull down menu and it will bring up a PDF of the scanned copy. Sure beats buying one!
Posted on Feb 09, 2009
  • Lexmark Master
  • 3,594 Answers
Load the paper by pulling the rt. upper bail arm forward. Type info. and return, press reprint key top l. of keyboard. info. will reprint.
Posted on Feb 13, 2009
We found the answer on a website. i can't remember which one.
i was reading your terms and conditions and there is something in there about refunds. i didn't see where it told how much it cost to be part of FixYa. help me please. thank you so much for your email. and please take me out of your fixya email database. i am leaving trane and i don't think they want to recieve more emails. :-) Thanks again.
Posted on Feb 01, 2009
Can't print payroll checks for intuit, get support code 2101 message
Is the paycheck form the same size as the plain paper? If not adjust the paper guides (and size selector if there is one) to the edges of the cheque form.
Aug 14, 2014 | Office Equipment & Supplies
Mx 2830 - fails to print - asks to add extra plain paper
Check the paper type and paper size in the Printer Properties. Set them according the actual paper used in the printer. Check the paper size in your document you want to print. Correct, if differs from the printer's paper size.
Jan 09, 2014 | Sharp Office Equipment & Supplies
When we receive faxes, Only the very right side prints out. WE have a new ink cartridge and drum unit. It did it before we changed it and it is doing the same thing. Is there anything that we can do?
don't know if this will fix prob, but pull drum unit out and locate the piece of glass that runs right to left inside of fax right over top of where drum would be sitting. clean that off. if theres toner coating that glass, that will cause light prints or blanks. this is of course, assuming that you are getting these kind of prints from more that one fax.
Jun 15, 2011 | Brother IntelliFAX 4750 Plain Paper Laser...
Where do you put envelope to print on it?
You are brave trying to print to an envelope...remove paper from tray, put in "plain" envelope, print side down, flap should point to left ( I put a dab of glue stic on flap to hold it securely) will print from top or bottom tray. If envelope keeps coming out askew...make sure to check for a wayward piece of paper stuck in roller from last paper jam.
Aug 04, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
Prints only a plain piece of paper
There is something wrong with your printer head. Call brother for a replacement.
Dec 30, 2009 | Brother MFC-5840CN All-In-One InkJet...
Dell Laser Printer 5100cn Load MPF Letter Plain 1 !
Are you trying to use the "MPF" (Manual Paper Feed) tray?
If you are then the manual paper feed tray is usually a fold down flap at the back of the printer. It only accepts on piece of paper at a time.
However, if you are just trying to print to the printer's default tray, then you need to check both the "Page Setup" in the application and the printer driver properties to make sure that you are calling the correct paper tray.
Nov 18, 2009 | Dell 5100cn Laser Printer
Canon IP4600 won't feed from rear tray.
It turns out that if you read the documentation VERY carefully it says that "if the application program specifies 8.5x11 plain paper and that is what is loaded in the front cassette you cannot print from the rear tray". It turns out that this is true even if you go to the printer driver and specify "rear tray" manually. The driver disregards the setting. You can force printing plain paper from the rear tray by going to the Canon "My Printer" icon and forcing ALL printing from the rear tray. If you do this, remember to change it back. You can also print plain paper from the rear tray if you specify the "allocation" option and the paper from the front cassette runs out. You can always print from the rear tray if the application that created the print job specifies something other than 8.5x11 without resorting to the forced override, e.g. printing a .jpg or .gif or something from an application like Paintshop or Printshop, etc.
Jun 12, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
HP 2710 Printer
Issue When using colored paper in the all-in-one, printing or copying is slow. Solution This issue is a result of the automatic paper type sensor misreading the colored paper as photo paper. The print out takes longer because the unit is printing in Best mode instead of Normal mode. Follow the steps below to temporarily change the Automatic Paper Type setting from within the application that you are printing from.
  1. Click File , then Print or Print Setup .
  2. Select the appropriate all-in-one from the drop-down list and click Properties .
  3. Click the Paper/Quality tab and under Type is: select Plain Paper . Changes made within the application might not be permanent and the setting will default back to Automatic after closing the application. The setting will have to be changed each time colored paper is used in the all-in-one.
Follow the steps below to change the default Automatic Paper Type setting to plain paper.
NOTE: By following the steps below, the default Automatic Paper Type setting will be changed to Plain Paper. In order to use a different paper type in the all-in-one (e.g., photo paper), the setting will have to be temporarily changed to reflect the new paper type.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Double-click Printers and Faxes .
  3. Right-click the appropriate all-in-one, and then click Printing Preferences .
  4. Click the Paper/Quality tab and under Type is: select Plain Paper . This sets the default paper type setting to Plain Paper.
May 30, 2008 | HP Photosmart 2710 All-In-One InkJet...
Printing Problems
Turn machine on..
The unplug power cable on the back....
Press & Hold # 3 while connecting power cord.
keep it pressed & hold till screen display reset or shuts down...
Then follow the prompts on screen...
If this will not resolve the issue , then replace
call 1800 474 6836 & request them upgrade , You will save some money on purchasing new.
Apr 26, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Lexmark Wheelwriter 10 Series II Typewriter Logo
524 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
