Question about Tivoli Model Three Clock Radio
Radio Dies with Noise
After about 15 minutes the radio completely goes crazy and just spits out loud static. Turning it off/on will correct the problem but after only a couple minutes it comes back. Maybe something inside is overheating? Anyone know how to open one of these up to check? Or know where I could get a service manual?
Thanks
    Problem Solver:
  • 5 Answers
Sell it now! Ebay would be a good place
Posted on Jun 04, 2009
  • micha Mar 29, 2013
    Great help! (not...)
INfinity speakers make loud bumping and static noise when radio fuse is plugged in
It sounds like the radio is defective. I can think of no other issue that would cause the speaker noise you discribe
May 26, 2016 | 2002 Dodge Stratus
Loud speaker static when the car is off. It drained that battery. I tried pulling the radio fuse but it was still making the noise. I had to disconnect the battery to get it to stop. Any ideas?
I GUESS that the speakers are driven by an after market amplifier. An amplifier needs to be connected to a power source that is only on when the radio is on, through a relay.
So I GUESS that:
  1. The wiring is incorrect. Or
  2. If is has a relay, the relay is stuck.
Feb 01, 2015 | Cars & Trucks
Loud speaker static from 2002 Mitsubishi Eclipse when the car is off. It drained that battery. I tried pulling the radio fuse but it was still making the noise. I had to disconnect the battery to g
The fuse might be built into the cable to the lighterand/or radio. It's called "fusable link", this type of fuse looks like a cable. Or another type of fusable link might be in the fuse box under the hood near the firewall.
Feb 01, 2015 | 2002 Mitsubishi Eclipse
Radio doesn't work - no sound although DVDs play fine
Do you hear static noise when you turn the radio on or is it complete silence? If static noise, is there an antenna on the radio and is it getting proper signal strength?
Oct 17, 2013 | Bose 3·2·1 II System
On my 2003 Avalanche, after the radio has been on for a few minutes static starts in the front right speaker then travels to all of them. As the static gets louder the radio volume goes down and the static...
take out the speaker in question and test it.
a 9v battery is good enough to 'burp' it.
if it makes a scratchy noise when you put power to it then you have a short in the voice coil.
Burping a speaker is just a short power up. Don't hold power to it.
Tap it on and off like a music note measure.
Apr 16, 2017 | 2003 Chevrolet Avalanche
E 10 tape deck error/ tapes keep spitting out
The radio checks to make sure the drive capstan is turning - if not, gives the E10 error. Either the drive belt in the radio is slipping or the drive wheel in the adapter is sticking. If it does it with a real cassette, then it's probably the drive belt. If not, you can try to figure out why the wheel in the adapter is not turning freely.
Jun 21, 2017 | 2001 Oldsmobile Intrigue
Audio has a lot of static
You can possibly diagnose the problem by trying a different speaker,it does not have to be the same shape as the original but it has to have the same amount of resistance (ohms),radio shack might have one that you can try or one from a broken radio ,if you use one with different value it might not sound as loud but we are trying to see if you hear the static or is gone.You need to unplug the unit from the wall,remove the back cover and locate the speaker,disconect the wires and reconect the one to try then plug the set and turn it on,the antenna will need to be reconected too.Is the most simple test you can do without getting in too deep.Let Us know how it goes by a way of a new question or if you need more information.
Nov 01, 2006 | Sanyo HT32744 32" TV
Tivoli Model Three Clock Radio Logo
367 people viewed this question
Top Tivoli Audio Players & Recorders Experts
Willem.
Willem.
Are you a Tivoli Audio Player and Recorder Expert? Answer questions, earn points and help others
