Is it a C code?
The service manual only shows one code 3600:
U03600:
Confidential polling reception was interrupted because of a mismatch in specified confidential box No. Or, an interoffice subaddress-based bulletin board reception was interrupted because of a mismatch in the specified subaddress confidential box number.
This regards fax system (k)
SOURCE: i am geting an error code of c3100 call for
Your scanner cable broken or twisted inside. You need to call local representative for further action.
SOURCE: my kyocera km1820 displays error code c6400
Zero-crossing signal problem
• The engine PWB does not detect the
zero-crossing signal for the time
specified below.
At power-on: 3 s
Others: 5 s
Causes:
- Poor contact in the connector terminals.
- Defective power supply PWB.
- Defective engine PWB.
Check procedures/corrective measures:
- Check the connection of connectors YC7
on the engine PWB and YC2 on the power
supply PWB, and the continuity across the
connector terminals. Repair or replace if
necessary.
- Check if the zero-crossing signal is output
from YC2-11 on the power supply PWB. If
not, replace the power supply PWB.
- Replace the engine PWB if C6400 is detected
while YC2-11 on the power supply
PWB outputs the zero-crossing signal.
