Potterton heater comes on a then goes of after about ten minutes
My heater will not stay on and keeps going of after a short period of time
    Problem Solver:
  • 17 Answers
If it lights for about 3 seconds and then goes off, you may have a dirty flame sensor. usually this sensor looks like a metal rod that sticks in front of one of the burners. it will have a single wire with a spade connector running to it. usually the ignitor will be on one end of the burner row and the flame sensor on the opposite end. you can remove the wire and take the flame sensor out. use some steel wool or emery cloth to shine it up real good. try this and let me know. if it doesn't work, give more details like make and model of furnace and approx. age.
Posted on Jan 30, 2009
The breakers at the electrical panel keeps tripping, would work fine for awhile then it trips
Sounds like a shorted defrost heater, it shorts after a period of running when the machine initiates a defrost cycle... Defrost Heater Assembly 242044113
Mar 18, 2016 | Freezers
Heater will run for 15-20min then the flame goes out ..Lots of keeps going fuel stays on...I cleaned filter and put new fuel..same thing..115000btu reddy heater..its new in 09..
Sounds like a thermostat problem causing it to run for short periods of time. Check your thermostat first you most likely find the problem there.
Dec 07, 2010 | Reddy R115DT Oil Filled Utility Heater
Domestic RM3663
replace the thermocouple,its the only thing keeping the pilot alight.
Jun 03, 2010 | Dometic RM2620 Refrigerator
Dimplex oil heater FR24. 2400W oil heater. shorts fuse box
I would suggest that the element may have absorbed some mloisture whilst being left in storage for a period of time. You may need to take it to a local repairer to see if they can dry out the element.
If there is moisture in the element it is not safe to use, hence it trips your circuit breaker.
May 27, 2010 | Dimplex Heating & Cooling
My hot tub keeps tripping the breaker and will only stay on for a short period of time before tripping the breaker. What can I do?
Check for a water leak in the electrical areas of your spa... specifically look closely around the heater terminals, look for wet and corroded connections... If this spa is wired to a plug-in outlet, look at the GFCI plug assembly as well... You can also try disconnecting the blower, pump, heater, etc, from the control pack (one at a time) to determine which item is causing the tripping.
Dec 26, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Natural gas hot water heater not stying lit
Probably a bad solenoid in the gas valve. Higher voltage of a new thermocouple keeps it open longer but it still fails over a period of time. Look into a new gas valve for the water heater.
Dec 17, 2009 | General Electric GE SmartWater Household...
Bosch Water Wizard 600 pilot light keeps going out
You need a new thermocouple. Its the little stick like thing that the flame heats up to tell gas valve to open.
Jun 15, 2009 | Bosch Water Heaters
Reddy heater rlp 100
Sounds like the thermocouple is not working or the flame is not hitting the thermocouple. It may take 30 seconds of flame or longer to keep it on. Check for a loose connection at the gas valve.
Either a 30# or 110# tank of propane will work. You might even get by for a short period of time using a gas grill tank, depending upon how cold it is outside.
Oct 26, 2007 | Reddy Heater-30,000 BTU Propane Forced-Air...
Heating & Cooling Logo
125 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
