Question about Norcent Technologies LM-762 17" Monitor
Brightness fades For no apparent reason and at random times, the brightness/contrast info box appears and the screen gets darker. It will not respond to the panel controls. Any suggestions?
  • Dick Slattery Jul 30, 2007
    What power supply? It is plugged directly into an electric outlet. I guess I'm not as conversant with these items so I don't understand the "PSU".
  • Anonymous Mar 29, 2014
    Screen vacillates between bright & dim for no apparent reason
  • Norcent Tech... Master
  • 12,061 Answers
This is a Common problem MOST if NOT ALL, problems like this with this type of fault it is invairably a problem with the Power Supply, in the PSU Electrolytic capacitors dry out and often cause this type of exact problem... It is a relitively simple fix, by replacing the caps with new ones... Any good shop should be able to fix for a modest fee.. OR if ya know anyone handy with a soldering iron maybe they could do it for you there are generally about 4 - 6 to replace... in the PS section, just do them all to be safe..
Posted on Jul 30, 2007
My Fujitsu lifebook T902 keeps changing the screen brightness levels for no apparent reason.
I would think that if the virtual level controls are not changing, either the power socket/supply, back light or invertor has an issue.
Dec 01, 2013 | Fujitsu LifeBook Computers & Internet
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Lost my user's guide need to change make copies darker
May I know the model # of your machine?
Some of brother machine have the copy options where you can change the brightness, contrast and color of the document that you are copying.
For example for MFC-240:
You can change the brightness contrast by pressing copy mode. Then load the document in the feeder, press copy option so that it will show the option to change the brightness, contrast and color. Just press the arrow key to select the brightness then hit ok/menu. then press arrow key to have it lighter/darker..
Hope this helps.
Mar 29, 2011 | Brother Office Equipment & Supplies
Help!!!- Gateway w340ua. Brightness flickers and comp shuts off
sounds like a power probelm
check the pin in the dc jack where you plug the adapter in, if this pin is loose just a little
it could be that yoru going from battery power to ac power , for that reason your screen would flash and you would shut off now and then
Jul 22, 2009 | Computers & Internet
I have a pioneer elite pro 100 projection tv. the picture seems to be getting darker and darker. and the color seems to be fading as well what could be wrong? and i havent tried to turn up the brightness...
hi..first check it out the brightness.It is available in the
menu button,available on the top of the tv.If it still doesnt
work Projection TVs have a high intensity lamp as the light
source. They wear out and gradually get dim.You probably
need to replace it.
check it out..
thank u..
rate my response..
May 05, 2009 | Pioneer PRO-100 TV
Brightness quit working
Unfortunately, it soulds like the monitor may be going bad. You may have to use the manufacturer warranty if its still valid.
Thanks
Nov 14, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Brightness
most monitors get darker with age -- for a while you can counter this by turning up the Brightness and Contrast controls, but this only gives you a little extra time (and probably speeds up the decay process anyway).
Sep 16, 2008 | LG Studioworks 563N 15" CRT Monitor
Brightness adjustment not very effective - XP-sp2
Alter your gamma,brightness,contrast,etc with your grapics card settings,
Mar 01, 2008 | Acer AL2016W 20" LCD Monitor
Can't read the screen
That's just the contrast and brightness of your screen. all you need need to do is to hit 2nd and then hit the up arrow. you will need to do this several times for it to get darker. Everytime you do it you need to hit the 2nd key and then the up arrow.
Jan 08, 2008 | Texas Instruments TI-84 Plus Calculator
Open Questions:
Norcent Technologies LM-762 17" Monitor Logo
47 people viewed this question
Top Norcent Technologies Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Piyal Perera
Piyal Perera
Brandon Murphy
Are you a Norcent Technologies Computer and Internet Expert? Answer questions, earn points and help others
