Question about HP Compaq ProLiant ML530 Server
SCSI Devices not detected when posting ML530 Server.....
When I boot the server, I recieve the following message......
"No drives detected, No SCSI devices detected, HP Smart Array 5302 - 128 controller v3.54 0 logical drives"
Media test failure, test cable.
Also, how can I get into the BIOS of this machine ?
Thanks much
  • 596 Answers
To get to the BIOS for your server, press F10 at start-up. This should get you there to verify if settings are detecting SCSI devices. If they are there, you may have to reinstall the SCSI controller drivers. Good Luck.
Posted on Feb 09, 2009
No scsi devices detectde
I would check 3 things here: Make sure the cable is secured to the drives and motherboard, next is the drives good? You may have to replace them. Finally, you may need to update the drivers on your system.
One more thing....make sure the BIOS is updated and has the SCSI setting correct.
Good Luck
Jan 05, 2012 | HP Compaq ProLiant ML530 Server
Proliant does not boot from raid controller if external SCSI drive is powered on.
Try to disable boot to other device on your bios setting.
Make sure that your Smart Raid is set on the first boot device.
Nov 01, 2011 | HP Compaq ProLiant ML350 G3 Server
I have dell 4600 pe serveri want to install Server2003 os i have configured raid 1 on the machine every thing is fine but! on boot process it display message no Boot Device Found Press F1 to continue F2...
The hard drive needs to be set as the first SCSI ID device boot device..
The hard drive needs to have the jumper set to SCSI ID 0, the CD and FDD can be set to SCSI ID 1 and SCSI ID 2. No SCSI devices can have the same SCSI ID number unless it is on a different SCS controller.
Jul 01, 2010 | Dell PowerEdge 4600 Server
How to enter in bios to boot change sequence in ProLiant ML 530
Press F10 during post boot if you have smartstart installed in the partition. If not, you need to boot from SmartStart CD.
May 08, 2010 | HP Compaq ProLiant ML530 Server
Configure & install two scsi disks scsi disks in ML 150 G2
The SCSI driver is required to installed during the initial boot up for installation when additional drivers are asked .the new models dont come with a Floppy drive so an external floppy drive can be used .The detection of HDD s must be at the startup by the Bios os SCSI card.
Feb 24, 2010 | HP ProLiant ML150 G2 Server
How to repair server 2003 in IBM 226 server
first you need to prepare the scsi drives ie host raid adapter scsi drivers are server raid cotroller 6 scsi drivers by using the serevr raid support cd dikettitools proper os drivers to floppy and boot with widows cd at the time starting boot press f6 to specify the scsi drivers then all scsi hdd will detect for installatio.
Jan 18, 2010 | IBM xSeries 226 Server
I cant boot my server the hard drive can not be detected
Try taking the side off and removing and replacing all the hard drive leads. Remove and replace all the scsi drives and generally check for loose connections. If this does not work you will need to post more infomation.
Oct 29, 2009 | Dell PowerEdge 1800 Server
OS Loaded on SCSI HDD Cashed
If the Bios did not detect the third drive, try switching it to a known working slot and see if you have a bad drive, or something wrong with the cage or cabling. The 3000 were shipped with either a 68 pin drive cage or a 80 pin drive cage. The 68 pin drives and the 80 pin drives are not interchangeable. To make matter worse, the drive cage would be configured as simplex or duplex. For duplex mode, you will need to connect two SCSI cables to the cage.
Dec 30, 2008 | Compaq ProLiant 3000 Server
Problem with scsi driver proliant ml 370 for NT4
Are you attempting to boot from the Windows CD?
If you are booting the server from a Windows installation disk and it is unable to detect the hard drive, this typically means the following things.
You need to provide the driver for the RAID controller of the server (this can vary, depending on the version of the ML370 e.g. G4/G5)
If it still cannot detect the hard drive after providing the driver for the RAID controller or if there is not a driver available for NT4, it may not support the controller.
In this case you can remove the RAID set by entering the RAID setup (could be LSI or adaptec). NOTE THIS WILL DESTROY ALL DATA ON THE DISKS THAT ARE A PART OF THIS RAID SET.
Dec 26, 2008 | HP Compaq ProLiant ML530 Server
There are many configuration settings, although i personally would hunt down an SCSI hard disk, many will fit from many other models just like IDE ones
Mar 24, 2008 | Compaq ProLiant ML530 Server
HP Compaq ProLiant ML530 Server Logo
1,696 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
