I want to delete the music from my sony mp3 player, but not sure if it will go back onto my windows media player. I don't want to loose the music, I want for future use so if i delete it will it go back onto my media player?
No you will need to1) insert the mp3 player into the computer2) navigate to the mp3 player folder the contains the music files you would like to keep.3) once your inside the folder with the music select one file by left clinking one of the media files,4) locate the control key on the bottom left or right side of the keyboard.5) locate the letter a key6) press and hold the control key and the a key at the same time, all the files should highlight blue.drag them to your desktop or my documents folder and thats it, you may then erase the drive/mp3 player--Good Luck.
SOURCE: i try to download music to my mp3 player
is this mp3 player is a plug and play. if not you cannot just copy/phase the file you need to install the software fist that comes with the mp3 player after installing it you have to import all the songs you want to that application and syncronice your device then walla! You have transfer the song if you still having problem plz let me know
SOURCE: deleting music from sandisk sansa E260 4FB mp3 player
you can change the usb mode in the sansa player settings to MCS then connect it to the computer, in windos xp the device will be recognized automacally. go to the explorer or to my pc and you should see it there.. go to the folder music and delete what you want,, you can copy music as well.
then desconect it safely and restart the device,, It will refresh the database and that's it.
you can change the USB mode bac to MTP if you wish.
SOURCE: I HAVE AN EMERSON MP3
I have an Emerson 2gb MP3 player model EMP 312-2, not sure if this info is for you or not. Make sure you are in the MUSIC MODE, when you use the menu button to go from music mode, voice mode, settings etc. you must push menu button again when the mode you want is hi-lited. I had a similar problem. Files were loaded (my music is on my harddrive already so I just copy to mp3 player) but when I turned player on it said no files. AHA, I finally realized I had somehow got into the voice mode and I did not have any voice files, so it said no files. I then went to Folder Mode and it only said micin.dir and it was empty, THAT WAS BECAUSE I WAS IN VOICE MODE, when I switched to music mode, they were all there. I know this sounds very rudimentary, but I am pretty computer literate and had no idea how I switched to voice mode. Before I figured this out for myself I called Emerson customer service, they said it was bad firmware and send it back. If someone there had walked me through what I just told you it would have saved me a lot of time. Hope this helps.
SOURCE: i don,t know how to put music on my mp3 player
Windows Media Player has the Sync tab. I believe that WMP 9 does. But not 10. Either way, you can just open up the player in the My Computer folder. Then copy and paste any music files you have.
SOURCE: my GC-821 pink mp3 player says
Do NOT open the "RECORD" folder and put your music in it.
Put you music in the folder that opens. the "RECORD" folder is NOT for you to put music into. It is for you to get your .WAV recordings out of.
Ohhhhh, now you get it!!!!
you do not have to use wmp or any other app jest erase delete copy etc from the windows explore, no extra software required
