Question about Garden
SNOW BLOWER STUCK IN DRIVE
While using my Craftsman Model 536.887251 Snow Thrower it became stuck in drive. I released the Traction drive lever and it kept on rolling. After a couple of tries of holding it and releasing it I finally had to shut the engine to get it to stop. Now the wheels are locked and the I am unable to move the shift lever.
Thanks,
Jack
  • Anonymous Jan 31, 2009
    Hi Jerr,
    I took the inspection cover off and did find one of the tension springs had fallen off. Replaced it but still the same problem. There is no clearance between the FRICTION WHEEL and the SWING PLATE and it stays engaged. The only way to free it is to put downward pressure on the SWING PLATE by using a long screw driver. The tension springs could never exert that much pressure. Could something else have come loose?
SOURCE: Electric starter won't engage with the engine.
I have just taken apart my Troy-Bilt Model 5521 so now I can see how all the bits fit together.
The electric starter is a separate device that engages with the cogs on the outside of the engine flywheel.
The cord pull engages the flywheel at the centre.
The fact that the cord pull starts the engine is a good thing.
If you dismantle the blower and take of the top cover (very annoying with many bolts all over the unit, take a look at the spare parts guide to see the exploded view) the starter it comes away with the power cord.
You can plug this in to the main supply and press the start button and you should see the small cogged teeth turning about 200 rpm. Keep your fingers clear.
I am guessing that this is not working at all. Either that or the cog wheel has shaved the teeth off or it is jammed.
This is a good do it yourself project for someone who doesn't mind getting their hands dirty.
It should take about 3 hours to take the unit apar and another 2 to put it back together.
Troy Bilt doesn't sell the starter motor or the engines (mine had an engine seize with a broken main bearing and a broken piston).
I suspect that the resellers don't have these parts either. But someone does.
Good luck
Posted on Dec 22, 2008
  • 2976 Answers
SOURCE: Snow Thrower does not self-propel
Did you check under the handle area, near the blower itself for a transmission lever? This will engage & disengage the transmission.
Posted on Jan 31, 2009
  • 630 Answers
SOURCE: snapper electric start snow thrower won't start
If the engine has a float type carburetor, remove the float cover and see if the float is hung in the down position. If so free it up and make sure it will now operate freely up and down. If not and the bowl is full of crud, you will have to remove and clean the carb.
Posted on Mar 13, 2009
SOURCE: My Troybilt Snow Blower wheels have locked up
Just found the same problem with mine.  The bearing on the gear shaft is frozen.  To replace these, follow the instructions in the manual to replace the friction wheel, then tap out the bearings in the side of the case, you'll probably find one frozen up.  As long as you're there, might as well put in a new friction wheel.  Mine is looking pretty worn after fighting the bearings all winter.
Posted on Apr 19, 2009
  • 430 Answers
SOURCE: CRAFTSMAN 5 hp 24 SNOW THROWER, WONT STAY RUNNING
rebuild the carb.
Posted on Nov 30, 2009
The drive cable came off as i was engaging it & i can't figure how to replace it
TRACTION DRIVE CLUTCH CONTROL
CABLE
6.1. The drive control is on the right side of the handle bars
6.2. Stop engine and allow it to cool disconnect disconnect
the spark plug and ground it to the engine.
6.3. Confirm that the fuel level is low enough to prevent spillage through the gas cap vent with a plastic bag between the cap and the filler neck.
6.4. Carefully tip the snow thrower forward so it rests on the auger housing.
6.5. Mark the bracket to the frame as demonstrated in figure 5.2
6.6. Detach the z-fitting end of the cable from the engagement handle.
NOTE: The cable routes down to the cable guide pulley that is mounted on the drive cable adjustment bracket.
6.7. Remove the bottom access panel.
6.8. Detach the spring end from the friction wheel support bracket.
6.9. Examine the removed cable: If the cable failed because of something other than normal wear, identify and correct the cause before returning the snow thrower to service.
6.10. Install new cable by reversing the removal proceedure.
6.11. Run/test/adjust the tension on the traction drive
clutch control cable.
Feb 15, 2016 | Craftsman Snow Blower / Snowblower Bottom...
Can I use 0w 20 Mobil 1 oil in my snow blower
It can be used, although the manufacturer recommends;
Super S 5W-30 Snow Thrower Engine Oil - Sears
www.sears.com/explorer-5w...snow-thrower...oil/p-07188298000P
Sears Rating: 4.5 - ‎5 votes
Oct 21, 2010 - Explorer 5W-30 snow thrower engine oil is a premium formulation for use in all four cycle engines when temperatures are below 32 deg. F. Explorer 5W-30 snow thrower engine oil protects the engine by lubrication, cooling, cleaning and sealing internal moving parts.
Aug 23, 2015 | Craftsman Snow Blower / Snowblower Bottom...
How can I the drive control that is loose on my craftsman snow thrower model 247.8819990,first time using it. Worked for a while and then became loose no longer engaging the wheel. What can I do?
Hi rita, this here web site may be able to help you. Cheers Greg. http://www.searspartsdirect.com/Craftsman-Snow-removal-equipment-Parts/Model-247887000/0247/1507200.html
Feb 02, 2015 | Garden
On my craftsman snow thrower the auger is stuck (jamed)
you bent it straighten it out as to where it works as it should , easy fix , did you get the bad tile out
Feb 14, 2014 | Garden
Craftsman Snow Thrower engine spews balck smoke
the choke is stuck so remove the cover and look for the choke to see why it,s not movin
Feb 13, 2014 | Craftsman Arnold Mtd Snow Thrower Blower...
Craftsman snow thrower stuck in 6th gear
empty gas to less than half full
tip machine on its nose
remove bottom plate
know you can see the drive and whats going on
the shaft that the speed wheel rides on may be stuck
or the tension is too much that the wheel is engaged
check for broken cable , and springs clean shaft
dont get oil or greese on the silver plate or drive wheel
Dec 15, 2013 | Garden
Attching a craftsman snow blower to craftsman tractor 247.288820
you must ask to your supplier manufacturer by matter of design machine. Take the toll free or website and ask them by ONLINE via chat and ge the support.
God bless you
Nov 20, 2013 | Garden
Changing auger belt on snow blower
The most common cause of this is the drive belt is worn. If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belts.
Your operator's manual will show you how to remove the cover and check/change the belts.
I am going to assume you have a Craftsman snow blower. If you don't have a copy you can get the manual through managemyhome.com
You will need the model number off the snowblower. It is usually located on the bottom right hand corner of the frame (from the handle side)
The model number looks like 247.123456.
The belt closest to the blower assembly drive the auger/blower and the belt closest to the engine drive the transmission.
With the engine not running, have someone depress the drive lever and check the belt.
You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced.
On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt) It may be torn and broke completely.
Your Craftsman manual will show you step by step how to change th belt.
You can get parts for you Craftsman and most MTD made models through searspartsdirect.com. With other makes you can get parts through jackssmallengines.com
If you are unfamiliar with repairing machines you can get your snow blower repaired by taking it to your local Sears.
They will have a technician troubleshoot and repair the unit.
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Craftsman 16" High Garden Tractor Snow and...
Jan 25, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Garden Logo
245 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
