Question about Amcor Amigo4300 GPS Receiver
Amcor 4300 gps system constantly indicates no satellite signal
When I try and use my Amcor 4300 gps it will pull up the options to use, but when I try and find a location for it to direct me to it doesn't work. It constantly says "no satellite signal". Do I have to somehow reset the unit to get a satellite signal?
Amcor 4300 gps touch screen is not working
Posted on Nov 02, 2009
  • gem_song Nov 02, 2009
    I have problem with my amcor gps 4300 touch screen is not working
No signal
If your gps says no signal, you need to check if all the connections on it are appropriate, once they are checked. Turn it off for some moment then turn it back on, if it still does not work, then you need to reset it. After resetting it should pick signal, and if that does not do the job, then it means there is a problem somewhere.
It is either the location you are there is no good satellite signal for the gps to pick signal, or your antenna is faulty, try to use another antenna to see if it works, if that works, then all you have to do is to replace the antenna, and if it does not help, then it means the problem is from the network around the location you are.
Hope this information worked for you.
Dec 21, 2010 | Amcor 3990 Car GPS Receiver
Mio P550 how to change hardware id
Do a hard reset. Pull batt. let stand for 30 min or more.
Dec 05, 2007 | Mitac Mio P550 GPS Receiver
NO SIGNAL
If your gps says no signal, you need to first check if all the connections on it are appropriate, once they are checked. Turn it off for some moment then turn it back on, if it still does not work, then you need to reset it. After resetting it should pick signal, and if that does not do the job, then it means there is a problem somewhere. It is either the location you are there is no good satellite signal for the gps to pick signal, or your antenna is faulty, try to use another antenna to see if it works, if that works, then all you have to do is to replace the antenna, and if it does not help, then it means the problem is from the network around the location you are.
Dec 21, 2010 | Amcor GPS
I want to use the gps and navigator on my nokia 5800 can you please help
The Nokia 5800 has a built-in GPS satellite navigation receiver, which can tell you where you are anywhere on the planet. The 5800 also has cell-tower-positioning technology, which finds your location using the position of the nearest phone network mast if a satellite signal is unavailable. GPS is more accurate but can take a while (from 10 seconds to a few minutes, depending on how obstructed the sky is) to find your position ('Assisted GPS' is also present, to download the expected GPS satellite positions from the Internet and help speed up your fix.)
The 5800 also has a built-in mapping application called Nokia Maps, which shows you your location on a street map, tells you exactly how to get to another location by driving or walking, and can give details of nearby amenities such as shops, fuel stations, museums, etc. Nokia Maps uses both GPS and cell tower positioning to tell you where you are: the latter gives an instant rough position, while GPS data is used after the phone has locked onto enough satellite signals calculate its position. You'll know the phone is locked onto a satelite as the lock indicator at the bottom of the screen will turn green.
Other phone applications can also use the GPS receiver if required. For example the camera application can optionally "geotag" photos with your current location using the GPS receiver to work out where you are (click here to see our camera tutorial and find out more about geotagging). If you switch to the standby or menu screens while an application is using the GPS receiver, you'll see a little satellite icon in the top right corner of the screen to indicate that GPS is active.
How does the 5800's GPS work? Like all satellite navigation systems, the 5800 receives signals from many different GPS satellites in the sky, and calculates your position based on those signals, using a combination of triangulation, signal delay calculation and a lot of very heavy maths that you really don't want to know about.
Important Note: Satellite signals cannot penetrate buildings, so GPS satellite signals will be difficult or impossible to receive if you are indoors and away from windows. If you want to speed up the process of GPS showing your location, take the phone outside or place the phone next to a large window with a good view of the sky.
The 5800's GPS aerial is inside the top left side of the phone. If you want to get a good GPS lock make sure this part of the phone is uncovered
May 11, 2010 | Nokia 5800 XpressMusic Smartphone
I need to download a user manual but cannot find one for my Amcor 3750 navigation system
Not going to suggest you stop looking but i did manage to find the website, but it is up for sale and currently hosting a search engine did find this though and i might help you out in the long run, as usual cut and paste
http://www.avforums.com/forums/satellite-navigation-sat-nav/769514-amcor-3750-only-60-comet.html
Hope this helps.
Apr 26, 2010 | DURAGADGET Amcor Navigation GPS 3750 GPS...
No GPS Signal yesterday 15th and taday
I can't solve this. But it is happening to me, too. I probably know about as much about the satellite systems as you do. I've got an older aviation GPS I have not tried, yet. Did nextar indicate what Satellite was down and why the GPS would not acquire a different satellite.
Jun 16, 2009 | Nextar Q4-04 Car GPS Receiver
Navigo sy885 not receiving gps signal
I had this with mine. remove the back of the gps and simply unplug the antenna re plug and try system. Worked with mine. Chris
Nov 04, 2008 | Tomtom Navigator 5 1H50.082 GPS Receiver
I have an Amcor 3900. I cannot move from the settings/meltimedia screen.
Found this link......http://www.amcornavigationusa.com/manuals/3900GPS.pdf
Sep 17, 2008 | Amcor 3900 GPS Receiver
Garmin Nuvi Firmaware Update Complete, Unable to catch satellite signal
Same here - garmin nuvi 310 - bought it last year around March, said dowloading gps and then can't get a signal/satellite?? Will phone garmin tomo
Apr 18, 2008 | GPS
Amcor Amigo4300 GPS Receiver Logo
201 people viewed this question
Top Amcor GPS Experts
Will Halftowaite
Martin Murray
Are you an Amcor GPS Expert? Answer questions, earn points and help others
