Question about Xerox WorkCentre XD105F Laser Printer
L6 error keeps popping up
I have a Xerox WorkCentre XD105f printer. The L6 error message keeps popping up on the LCD screen. When I trunoff the printer and turn it back on the error light goes off and I'm able to complete the print job. When I have to print or copy again the same error message pops up again and I go through the same routine. What can I do to remedy this situation?
    President:
  • 2,072 Answers
That is a laser error. The motor that drives the mirrors is most likely oing bad, The laser unit will have to be replaced.
Posted on Jan 30, 2009
I have xerox workcentre xd105f, can't make copies, paper jamed and letter P on display
to remedy the P display error remove the paper tray and take any paper from under the tray and between the rollers, clean the rollers with alcohol or an acetone solution to remove paper dust and paper debris, refit the paper tray with the paper pushed below the tabs on the tray ensuring that the correct paper size is shown, IE: ltr ltr-r etc.
power the unit off and on and you should be back in business.
If this remedies the problem please rate the solution accordingly
thanks
Derek
Jun 19, 2009 | Xerox WorkCentre XD105F Laser Printer
I have xerox workcentre xd105f, can't make copies,paper jam
P will flash on the screen when the paper tray is empty, paper misfeeds or the paper tray door isn't closed all the way. Make sure both (if you have 2 paper trays) are loaded, that the paper isn't folder and wrinkled, and ensure that the tray doors are closed firmly. Then hit start on the workcentre to continue any unfinished jobs.
Jun 19, 2009 | Office Equipment & Supplies
Need Drivers for Xerox XD105F for Vista - Do any exist and where
try this link > http://drivers.softpedia.com/progDownload/XEROX-Printer-WorkCentre-XD105f-501230001-Download-2253.html
on the right side there is a DOWNLOAD LOCATIONS
for XEROX Printer WorkCentre XD105f 5.01.2300.01: and below is EXTERNAL MIRROR, click this mirror and save the file. Scan the program prior to your installation, file size is about 4MB. Let me know if there is any other i can help. regards. cebuwano
Apr 11, 2009 | Xerox WorkCentre XD105F Laser Printer
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Connecting printer
You can purchase an adapter "Parallel to USB" for printers to be used with printers.
http://accessories.us.dell.com/sna/productdetail.aspx?sku=A0489585&cs=04&c=us&l=en&dgc=SS&cid=30098&lid=674094
Hope this helps. Bud
Jan 09, 2009 | Xerox WorkCentre XD105F Laser Printer
Xerox WorkCentre XD100 Digital Copier
L6:The Main PWB sensed a Polygon motor lock signal error.
That is related to the mirror motor within the laser.
The laser most likely needs to be replaced.
Mar 12, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox workcentre xd105f
Guest.
The L6 indicates the machine is not seeing the motor in the laser, that rotates the mirrors.
There are 3 possibilities, I will list them in order of probability.
1 The Laser unit itself.
2. The cable connection on the Main Board.
3. The Main Board itself.
The laser depending on the lens, Curved or straight is $323 and $393.
the main board will cost in the $250-$400 range depending on the vendor.
That is without labor.
Oct 29, 2007 | Xerox WorkCentre M123 Copier
Xerox Workcentre XD125f problem
Does it keep showing that after you replaced the toner cartridge?
Aug 17, 2007 | Xerox WorkCentre XD125F All-In-One Laser...
Xerox WorkCentre XD105F Laser Printer Logo
495 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
