Question about Dell 540 Photo Thermal Printer
Half-Photo Dell 540
My Dell 540 is only printing half a photo lengthwise. I have tried printing from the computer and printer itself and have also changed ink cartdriges, no change. Any ideas?
  • 4 more comments
  • BMillies Jun 01, 2008
    dell 540 only prints on the left side of paper. tried printing from computer and the printer same thing also installed new cartridge. Was working fine then I didn't use it for a few months and now this problem. Thanks
  • Anonymous Jun 19, 2008
    my dell 540 printer also is printing about only 1/3 of the left side of the paper. i have not used it in 6 months. installed new cartridge etc. please help!
  • Anonymous Aug 06, 2008
    My printer only prints on one side of the page lengthwise. Dell offered no solution and said the printer has gone bad. Dell unable to fix or offer a replacement. I used this printer minimally and had not use it for a while when I discovered this problem. Printer was only about 1 year old. Dell should offer something other than, "buy a new printer", if others are having this same problem. Help!
  • Justasking Oct 01, 2008
    same problem, tried other supplies, still same problem.
  • volzstone Nov 03, 2008
    I have same problem only prints half the pic.
  • Anonymous Apr 08, 2009
    it prints half a photo, i changed cartridge but same
Vvvvvvvvvv
Posted on Aug 06, 2008
SOURCE:
Canon selphy 710 printing only bottom half of photo. how to correct this?
Hiya Jeannie it sounds like you may have overwinded your ink sheet as that makes it impossible to print to all the paper....hope that helps.
Mar 08, 2015 | Canon SELPHY CP710 Dye Sublimation Printer...
Prints only top half of photos on top half of
I suggest that you go into the printer properties section on control panel. There Will be a section which allows you to tell the printer the type of paper, size desired, orientation of photo to horizon and etc. There is also likely a selectable setup procedure on the printer's own display to do the same... It sounds like a basic setup format issue....
Apr 02, 2010 | HP OfficeJet 6210 All-In-One InkJet...
My photosmart 7150 prints half a page(vertical half) ! It worked fine before this. Help! thanks
Ok, I was having this same problem and the solution for me appears to lay in the fact that the "photo tray" was pushed in, signaling to the printer that it should print to the size specifications of a photo (approximately half the width of a standard letter page). I should also mention that with my problem, the printer would hang at every single print job--presumably to wait for you to input your photo paper--and that executing this fix solved the problem.
To fix this, I followed these instructions: SOLUTION:Follow the steps below to correct the issue:
  1. Disconnect power to the printer.
  2. Remove all photo paper from the Photo Tray.
  3. Push the Photo Tray completely into the printer.
  4. Snap the Photo Tray out (towards you) sharply.
  5. Reconnect power to the printer.
  6. Print a self-test on 8.5 X 10 paper.
  7. Engage the Photo Tray.
  8. From the Printer Toolbox, select Calibrate the Photo Tray .
Sep 26, 2009 | HP PhotoSmart 7150 InkJet Printer
Only prints top half of picture...
Throw it away the Thermal heater has failed and it will cost more than the printer to fix. Dell will not support this item so lie the rest of us you are stuck with a Lemon. Yes Dell sucks, yes they **** again and yes they will keep sucking!
Aug 07, 2009 | Dell 540 Photo Thermal Printer
White line across photo
clean ur printer head. and check that if any air ur ink box
Jul 21, 2009 | Dell 540 Photo Thermal Printer
Trying to print from a dell insprion 6000 to a dell AIo922 printe
Dell Photo Printer 540
http://search.dell.com/results.aspx?c=us&l=en&s=gen&cat=sup&k=insprion+6000&rpp=12&p=1&subcat=ddc/33&rf=all&nk=f&sort=K&ira=False&~srd=False&ipsys=False&adv
Jan 15, 2009 | Dell 922 All-In-One InkJet Printer
Dell 540 photo printer
It might be time to, but try these first:
(1) Try rebooting the computer (Press Ctrl+Alt+Del>Shutdown>Shutdown OR press and hold the power button down on the front of the workstation/computer/tower/CPU until the unit turns OFF)
(2) If that doesn’t work, then try clearing the print queue: Start>Settings>Printers>Double-click on the printer>Right-click on the print job(s) and click cancel/delete/purge documents and try reprinting a document
(3) If that doesn’t work, then try a power cycle: Try turning the printer off, then unplug the power supply from the printer, then unplug the USB cable from the printer then the back of the computer; wait 30 second; then plug the USB cable back into the computer, then back into the printer then plug the power supply back into the printer and turn it on – run a test print
(4) Run a Test Print: Start>Settings>Printers>Right-click on the printer>Properties>Print Test Page
Jan 02, 2009 | Dell 540 Photo Thermal Printer
email me at [email protected] and I will tell you how I got mine to prin the whole picture again.
Dec 03, 2008 | Dell 540 Photo Thermal Printer
Looks like to heaters are going How long have you had it Still under warranty? If so send it back or ask for a replacement.
May 22, 2007 | Dell 540 Photo Thermal Printer
Dell 540 Photo Thermal Printer Logo
304 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
