Question about Emerson MS9700 CD Shelf System
My ms9700 plays 2,4,and 6 disc not 1 , 3 , 5 even after took off the top
Is having trouble reading or tracking disc.I opened top and while playing disc the tracking mechanism goes out then back in and starts playing where it stopped?
You can clean the lens with a small amount of windex and put a little oil like 3 and 1 oil on the spindle motor shaft and on the sled rails. Good luck !
Aug 22, 2015 | Audio Players & Recorders
The DVD Disney's A Christmas Carol/Jim Carrey will not play on my 3-2-1 Bose 3 2 1 GSX System. I thought it was the disc at first, but returned and go another new one. Even tried multiple other copies...
Talked with a BOSE rep and they said it is a laser reading/tracking issue at their end (BOSE) and the way the dvd is made at Disneys' end and it is not going to work in their system. Had the same problem worked fine in an older dvd player
Dec 09, 2010 | Bose 3 2 1 GSX System
Everything works on my emerson MS9700 except the cd player. the display keeps saying no rdy. how can i fix this?
If the indication says" not ready " it means that the disc is not reading the data present on it . It is possible that the disc is not scanned by the optical head to be ready to play.
So it is possible that the optical head is defective or weak, please try to clean the optical eye with ear bud very softly or use a disc cleaner.
If there is no result the head can be faulty.
If the set was not used for long time please keep it powered ON.
Also the processing section/main board can be a suspect.
Nov 19, 2010 | Emerson EM-MS9700 6 CD-Changer stereo...
MY EMERSON MS9700 READS NO READY WHEN I TRY TO PLAY A CD.. IT TURNS THE CD MAKES THE SQUEAKING NOISE LIKE ITS READING IT BUT THEN NOTHING HAPPENS OTHER THAN THE NO RDY MESSAGE.. HOW CAN I FIX THIS???
I've been having similar problems. I've had mine over 4 years, so it is likely on its last leg. To resolve, nothing techno here, I take both hand an simultaneously give the entire unit a good "bang" on both sides. Sometimes it takes 2-3 attempts, but so far it has been working. I'm already on the look out for a new system, as i know this probably won't work forever.
Sep 12, 2010 | Emerson MS9700 CD Shelf System
Emerson ms9700
one thing that you can do and this helped me when i had that same problem is to take off the top cover and clean the laser lens
Oct 25, 2008 | Emerson MS9700 CD Shelf System
LG LHY-518
I had the same problem. Also, the disc tray had issues opening if there was no disc in there. The problem was two fold... I think.
1) It was kinda dusty inside the machine and needed a good air can dusting. Get around the tray but be careful not to turn the can upside down and freeze components. I also ran a lens cleaner disc several times.
2) The tray top (only visible with the system open) was starting to warp... likely because the build up of dust was creating too much heat, also causes issues in reading discs... I created a make shift cushion that I taped to the top of the plastic tray that was depressed when the top of the machine was placed back on. This required several tests as if too much pressure was applied, the tray wouldn't open at all and I got read issues in the middle of playing a disc (possibly an alignment issue of the lens caused from the pressure). I finally got a good system where I occasionally have push the top with my finger to open the tray only if it was empty so my padding (made from gauze and gauze tape) was barely getting pressure. Again, this took about 30 minutes of trial and error to get it right. The heat and the displacement due to the warped cover could have caused read issues.
I don't know if either or both of these were the cause of the problem but I can safely say that I have no issues now and yes, prior to this, I slowly went from 100% reading discs to almost 0%.
Sorry for the winded response but this saved me from buying a new system and may save you. Good Luck!
Dec 30, 2007 | LG LHY-518 System
Error message
I had this happen to me as ell. you've probably got a cd stuck under the revolving tray. I took the top cover off and then opened the drawer and removed the offending disk. If you're not technically minded it's probably better to take it in to a repair shop. Mike
Dec 24, 2007 | Marantz CC-4300 5-Disc CD Changer
Cd jumps tracks
The CD lens may need cleaning.
Try a 'wet' CD lens cleaner.
The laser PU may be low emision.
Nov 09, 2007 | Emerson MS9700 CD Shelf System
Emerson MS9700 CD Shelf System Logo
26 people viewed this question
Top Emerson Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
