Question about HP Officejet 5610 All-In-One InkJet Printer
Fax does not connect on distinctive ring
I should receive incoming faxes from my distinctive ring on my phone. It does not work. Why?
  • 11,896 Answers
Faxes cannot be received when the phone line is in use. Even though the HP fax product has a separate telephone number, it is still sharing the same phone line.
  1. Connect the HP All-in-One product to the telephone wall jack by following the product specific documentation for your product. A telephone may be connected directly to the HP fax product or to a different wall jack.
  2. Turn on the Auto Answer setting. (Refer to your product specific documentation for the answer mode settings)
  3. Set the Distinctive Ring option to the correct ring pattern. (See Changing fax settings below for instructions.)
  • All rings
  • Single rings
  • Double rings
  • Triple rings
  • Double and triple rings
Set the Rings to Answer option to 1
Posted on Jan 30, 2009
  • Nate Stansfield
    Nate Stansfield Jan 30, 2009
    he method for changing fax settings can vary for different models of HP
    fax products. The settings for most HP fax products can be accessed
    from the front panel menu, but the settings for some HP fax products
    can only be accessed from the software. If the information provided
    below does not work for your HP fax product, refer to the product
    specific documentation for additional information.
    Follow the steps below for basic menu navigation on most HP fax products.
    1. Press
      Menu
      or
      Setup
    2. Press the
      Right
      or
      Left
      arrow buttons to navigate menu options.
    3. Press
      ENTER
      or
      OK
    4. Use the arrow keys to navigate to
      Distinctive Ring
      and then press
      ENTER
      or
      OK
    5. Select the correct ring pattern for the service you have.
    6. Follow steps 1 and 2 to navigate to
      Rings to Answer
      and then press
      ENTER
      or
      OK
    7. Select
      and then press
      ENTER
      or
      OK
    NOTE:
    The
    Rings to Answer
    and
    Distinctive Ring
    options may also be located in the
    Basic Fax Setup
    submenu.
  • Nate Stansfield
    HERE IS WHERE I FOUND YOU INFORMATION:
    http://h10025.www1.hp.com/ewfrf/wc/fastF...
  • 6,784 Answers
Make sure that you have assigned it correctly. You should get a completion indicator or some kind of notification saying that the ring has been assigned to the specific location you ordered. if not, i will not be assigned correctly and it will go back to the default ring.. hope that helps ya:)
    Scholar:
  • 118 Answers
It's either your phone, or it's your fax machine that does not support fax through phone.
Lexmark pinnacle pro901 will not receive faxes i can send but can not receive what do I do
Are you sharing your home phone line with your fax? Do you have an answering machine or a voicemail feature in the same line?
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may want to subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Nov 02, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
I cannot receive faxes on my lexmark X4270. It will ring but nothing come through
Please go through the following checklists:
  • Make sure the that the fax line is working. To check, insert a telephone device straight to the fax line. You should get a dial tone.
  • Make sure the telephone cord from the phone jack in the wall is plugged into the Line port on the back of your Lexmark printer.
  • Assign the correct fax number on the printer.
  • If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
  • If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
If these don't help, please contact Lexmark Technical Support Center for additional assistance.
Sep 24, 2011 | Lexmark X4270 All-In-One InkJet Printer
How to set fax machine so it can accept after 2 rings?
Distinctive Ring basicsDistinctive Ring service is an optional service available from many telephone companies. The Distinctive Ring service permits you to assign more than one telephone number to the same telephone line. Distinctive Ring allows you to use a single phone line for both voice and fax calls. You can assign a unique phone number and ring pattern for incoming fax calls. When a fax comes in, each telephone number makes a distinctive ringing sound, such as a single ring, double ring, or triple ring.
NOTE: The Distinctive Ring Service is the name HP and others use to describe this feature. Distinctive Ring is also known as:
  • Call Sign
  • Custom Ring
  • Ident-a-Call
  • Ident-a-Ring
  • Ident-a-Ring
  • Multi Ring
  • Personalized Ringing
  • Ringmaster
  • Smart Ring
  • Teen-Ring
The Distinctive Ring Service allows the HP product to work similarly to a dedicated fax line. If you connect an HP fax product and a telephone to one telephone line, you can assign one telephone number for fax calls and another for voice calls.
NOTE: You cannot send or receive faxes when the phone line is in use. Even if the HP fax product has a separate telephone number, it is still sharing the same phone line. Set the Distinctive Ring Service Using the menus on the product control panel, follow these steps to set a distinctive ring pattern. Step one: Turn on Auto Answer Turn on Auto Answer by pressing the Auto Answer button on the control panel. The button light indicates when Auto Answer is on.If the button light is already on, you do not need to press the button. Step two: Set the distinctive ring patternFollow these steps to change the answer ring pattern.
  1. Press the Setup button (c01461502.gif ) on the product control panel.
  2. Press the Right Arrow button (c01185072.jpg ) to select Advanced Fax Setup , and then press the OK button.
  3. Press the Right Arrow button (c01185072.jpg ) to select Distinctive Ring , and then press the OK button.
  4. Press the Right Arrow button (c01185072.jpg ) to select one of the following options:
    • All Rings
    • Single Rings
    • Double Rings
    • Triple Rings
    • Double & Triple Rings
  5. Press the OK button to select the option.
  6. Press the Back button (c01490920.gif ) to return to the main menu.
Now if you have anymore problems copy the link from below and paste it in your address bar and it will help you further with a document. Follow all the settings in the document and your fax should be setup,keep in MIND THAT THE RINGS TO ANSWER SHOULD BE 2,SO YOU CAN RECEIVE FAXES AFTER TWO RINGS
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01647469&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3795406
Feb 01, 2010 | HP Officejet 6500 Wireless All-in-One...
How do I use use a distinctive ring to separate the incoming fax from the incoming normal calls I want to direct to the answering machine. I am from S. Africa. I am using an all in one Samsung SCX-4521F. I...
Firstly, you will need to get a 2nd ringtone from your phone provider. Most of them will provide a designated "fax ring" (not a new number) for little or no cost.
In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. “Distinctive Ring” is a telephone company service which enables a user to use a single telephone line to answer several different services.
Using the Distinctive Ring Pattern Detection feature, your fax machine can “learn” the ring pattern you designate to be answered by the fax machine. Unless you change it, this ringing pattern will continue to be recognized and answered as a fax call, and all other ringing patterns will be forwarded to the
extension telephone or answering machine plugged into the EXT. jack. You can easily suspend or change Distinctive Ring
Pattern Detection at any time.
Before using the Distinctive Ring Pattern Detection option, Distinctive Ring service must be installed on your telephone line by the telephone company. To set up Distinctive Ring Pattern Detection, you will need access to another telephone or someone available to dial your fax number from outside (a cell phone will do!).
To set up the DRPD mode:
1 Press Menu until “Fax Setup” appears on the top line of the display.
2 Press the scroll button ( or ) until you see “Receive Mode” on the bottom line and press Enter.
3 Press the scroll button ( or ) until you see “DRPD Mode” on the bottom line and press Enter.
4 When “Set” displays on the bottom line, press Enter.
“Waiting Ring” appears on the display.
5 Call your fax number from another telephone. It is not necessary to place the call from a fax machine.
6 When your machine begins to ring, do not answer the call.
The machine requires several rings to learn the pattern.
When the machine completes learning, the LCD displays “End DRPD Setup”.
If the DRPD setup fails, “DRPD Ring Error” appears. Press Enter when “DRPD Mode” displays and retry from step 3.
7 To return to Standby mode, press Stop/Clear.
When the DRPD feature is set up, the DRPD option is available in the Receive Mode menu.
To receive faxes in the DRPD mode,
you need to set the menu to DRPD;
NOTES:
• DRPD must be set up again if you re-assign your fax number, or connect the machine to another telephone line.
• After DRPD has been set up, call your fax number again to verify that the machine answers with a fax tone. Then have
a call placed to a different number assigned to that same line to be sure the call is forwarded to the extension telephone or answering machine plugged into the EXT. jack.
• In Tel mode, you can receive a fax by picking up the handset of the extension phone and then pressing the remote receive code Alternatively, you can press On Hook
Dial
(you can hear a fax tone from the remote machine) and then press Start on the control panel of your machine.
• In the Fax mode, the machine answers an
incoming call and immediately goes into fax
reception mode.
• In Ans/Fax mode, the answering machine answers an incoming call, and the caller can leave a message on the answering machine. If the fax machine senses a fax tone on the line, the call automatically switches to Fax mode.
• In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. This option is available only when you set up the DRPD Mode.
The full user manual for your machine is located here
Hope that is of help to you :)
Nov 09, 2009 | Samsung SCX 4521F All-In-One Laser Printer
I want the fax to work with an identa ring. How do I program this? As it is now I have to turn on the fax to receive. Does this HP work with identa ring?
The following set up assumes you have one conventional phone line, but two different phone numbers. One being your regular phone number and the other a distinctive ring for your fax machine
If that is what you have then this is how you set up the phone. Its important to know what type of distinctive ring your phone company will send to your phone. If it doesn't work you can talk to them about getting a different one than their default distinctive ring.
2 Set the HP all-in-one to answer incoming calls automatically.
Press the Auto Answer button until the light is on.
3 Change the Answer Ring Pattern setting to the pattern that has been assigned to your fax number by the telephone company, for example, double rings or triple rings.
For information on changing this setting, see Change the answer ring pattern
(distinctive ringing).
Note Your HP all-in-one is factory-set to answer all ring patterns. If you do not set the correct ring pattern assigned to your fax number by the telephone company, your HP all-in-one might answer both voice calls and fax calls or it might not answer at all.
4 (Optional) Change the Rings to Answer setting to one ring or two rings.
For information on changing this setting, see Set the number of rings before answering.
5 Run a fax test. For information, see Test your fax setup.
Your HP all-in-one will automatically answer incoming calls that have the ring pattern you selected (Answer Ring Pattern setting) after the number of rings you selected (Rings to Answer setting). Then it will begin emitting fax reception tones to the sending
fax machine and receive the fax.
If it is easier or you want to know other options which may be more applicable to your phone setup. You can find that information here.
http://h10032.www1.hp.com/ctg/Manual/c00235090.pdf
Jul 09, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Lexmark X6170 Has a shared phone/fax line with different numbers
Open the Lexmark "Fax Printer Setup Utility". Click on the "Connection/Dialing" tab. In the "Interact with Phone Line" section, "Answer Incoming Calls:" should be set to "If fax tones are detected".
If this is turning out to be too unreliable for you, you will need to either manually receive incoming faxes (by changing the setting to "Manual"), or you will need to at least spring for a separate phone number with a distinctive ring for incoming faxes.
Apr 05, 2009 | Lexmark X6170 All-In-One InkJet Printer
Faxes office Jet K60
You have to have either a dedicated phone line just for the fax --or-- pay your phone company approximately $2 a month for a service called Distinctive Ringtone. This service will ring a certain way when you have an incoming fax. You will then configure your fax machine to pick up when this distinctive rington is heard. The ringtone is usually two or three quick rings. Your fax machine's settings will have this setting.
Unfortunately, you can't just plug your fax machine into your phone line and start sending/receiving faxes. Look through your fax machine's manual regarding the distinctive ring service. Good luck!!
Oct 01, 2008 | HP OfficeJet k60 All-In-One InkJet Printer
Incoming faxes
Do you have a distinctive ring pattern in the same phone line
If no then you need to get a distinctive rig pattern from your service provider, which will differenciate the type of rings for phone and fax.
If you have a distinctive ring pattern make sure which one it has single rings, double rings, triple rings and double and triple rings.
To enable> First make sure auto answer in turned On
In setup/Menu go to > Rings to answer and set it to 5 or 6, and make sure the rings to answer in you answering machine set to 4(Always Should be lower then you rings to answer in the fax)
In Advance Fax setup> Then Ring pattern should be setup for the one which you service provider as given either double or triple Rings>
And the go to tools and run fax test and check what has failed
Aug 28, 2008 | HP Officejet 5610 All-In-One InkJet...
HP640 not receiving with Distinctive Ring Option
You need a dedicated ANALOG phone line.
A DSL filter screens out ANALOG signals to a DSL device.not the other way around. There are no DIGITAL fax machines.
Aug 10, 2008 | HP 640 Inkjet Fax Machine
Lexmark x73
Yes you need to connect to computer to receive and send fax........ Telephone as to connected to dial up modem of the computer if you dont have dial up modem then the faxing wont work.........
About Distinctive Ring Pattern Detection (DRPD)
"Distinctive Ring" is a service provided by some telephone service providers. Two phone numbers are assigned to one phone line so that you will hear different ring patterns for incoming phone calls than for incoming faxes. If you subscribe to this service, follow the instructions below to program your All-In-One to use it.
On the X125:
Press Setup once, then press Menu nine (9) times until DRPD appears on the display.
On the X63:
  1. Press Setup once, then press Menu eight (8) times until DRPD appears on the display.
  2. Press Options until you see Learn, and then press Start/Yes.
  3. Dial the phone number that you want to use as a fax number. (Do this from a different phone line, not from the line the fax will be installed on.)
  4. Press Setup.
  5. Press Menu until you see Fax Receive Mode on the display.
  6. Press Options until you see DRPD, and then press Start/Yes. The All-In-One detects the ring pattern and answers all incoming faxes on the second ring.
Sep 20, 2007 | Lexmark X73 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
154 people viewed this question
Ben Johnson
