Question about Phoenix Gold Xenon-200.4 Car Audio Amplifier
Moisture in amp while on, caused a small pop, then no sound outpu
I own a pheonix-gold M44 triple darlington high definition amplifier, and it has worked very well for. I have it intstalled in an s-10 extended cab behind the drivers seat on the floor board. The situation is that a little snow got on the amp on the top left corner of the vents. I brushed off the excess, but didn't unplug the amp, so after about ten mins. of driving(amp was working just fine) I had the radio on, and i hear a small pop come through the speakers and then the sound is gone, and the OVR(red light) is blinking on the amp(solo flash of light with a 1 sec. pause in between blinks). The fuse inside does not appear to be blown.
  • pharris12 Feb 01, 2009
    yeah, I took it apart and there is dime sized area that looks chared.
    Problem Solver:
  • 5 Answers
Check the fuse between the battery and the amp. (not the fuse in the back of the amp).
if that doesn't work then something on the inside of the amp is fried.
Posted on Jan 30, 2009
No sound from subs
You need power to the amp. If the light on the amp is not on then your amp is the problem. Get power to it.
Nov 10, 2013 | Phoenix Gold Xenon-400.1 Car Audio...
How many watts is a white phoenix gold ms 2125 triple darlingtion high definition amplifire
into 4 ohm 13.8 volts 160 watts rms x2 2 ohm 13.8 volts 255 watts rms x2bridged 4 ohm 13.8 volts 510 rms
hope that helps or follow link to manual
http://download.phoenixphorum.com/Manuals/Amplifiers/MS_MAC_Amps/ms2125.pdf
Aug 15, 2010 | Phoenix Gold Limited Edition MS2125 TA...
What does it mean when the red IND PROTECT light is on? my subs cut in and out, mostly out with the occasional hard hit popping up in the middle of a song. Whats wrong?
You've got the gain to high and the amplifier is clipping the sound frequency causing it to distort. Possible problems are you have a bad speaker(s) and the reading is below 4 ohms. Each of the 4 channels can only take 4ohms. If your bridging 2 speakers to this amp you have to also make sure you are only bridging 4ohms anything lower will cause the amp to overheat. Dont put 2 speakers in parallel on one channel or you will definitely have more problems.
Apr 07, 2010 | Pyramid 1000 Watt 4 Channel MOSFET...
Can i hook up a powered 12'sub to a Pheonix Gold xs2500 amp without blowing the speaker
First I hope you remove the speaker wires from the speaker that come from the built in amplifire. You cannot hook the powered sub to the amp without doing that first. Then all you need to do is run speaker wire from the sub out of the box to the amp. In no way can you hook up any other part of the powered sub, but the sub itself, to the amp. If you know the wattage of the sub and the ohms then wire it to the amp correctly. Your phoenix amp will put out 125 watts x 2 at 4 ohms and 250 watts x 2 at 2 ohms and 500 watts x 1 at 4 ohms bridged. Remember, only the sub itself in the sub enclosure can be connected to the amp. Hope this helped you. Let me know if you need more help.
Aug 23, 2009 | Phoenix Gold XS2300 Car Audio Amplifier
I have 2 kicker cvr 4ohm dvc hooked to a pheonix gold rival amp
If the amp is not kicking what it should it probably s a wattage problem. Check to see if the alternator has high enough voltage distribution. That is also why it keep shuting down.
Feb 28, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Need to repair amp
there is something touching or shorting out..could be speaker wire inputs on the inside..if you have it crossed over you could have it backwords or you could have a short in your RCA's..
Dec 04, 2008 | Phoenix Gold XS2300 Car Audio Amplifier
Subs
I looked up that amp, it doesn't have a listing for 2ohms x1 but it has 2 ohms x 2 and its at 250watts. For this situation, I would recommend a different amp or different subs. Right now you are getting the most you can get out of your sub/amp combo, if you only have single voice coil subs. Which is common in the mtx preloaded boxes. Either you want an mono block amp stable at 2 ohms or 2 dual 4 ohm voice coil subs. If you got the subs you would wire the voice coils in series so you could get 8 ohms then the subs in parallel so you could get 4 ohms, which would be the best for that particular amp. Good luck.
-Andrew Hawkins
Aug 23, 2008 | Legend LA1490 - American Legacy Series 2 -...
Wondering why im blowing fuses
The most common reason for an amp (in good working order) to blow fuses is a speaker load that's impedance is too low. You may need to rewire your speakers.
Let me know if you have any other questions.
Aug 21, 2008 | Legend LA1490 - American Legacy Series 2 -...
Pheonix Gold Xenon 600.1 power problem.
Do your speakers move in/out smoothly if you push on them?
Have you tried disconnecting the speaker wires from the amp to see if it would remain on?
Apr 11, 2008 | Phoenix Gold Xenon-600.1 Car Audio...
Phoenix Gold Xenon-200.4 Car Audio Amplifier Logo
243 people viewed this question
Top Phoenix Gold Car Audio & Video Experts
Mark Skinner
Jose Velazquez
Jose Velazquez
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
