I have an Evesham Explorer A5500 notebook Laptop and earlier when i was usuing it the screen became covered in white lines i rebooted to try and fix the problem but now when i turn on my laptop the screen is black and it doesnt do anything. i tried to link my laptop to my tv and the screen was still blank please help.
  • ian_skater_d Jan 31, 2009
    The Light to show when the hard drive is eing used never turns on at all and the wireless internet light is now blue when it used to be green. thanks for the help if you can give more it will be muchly apprciated
  • 114 Answers
Take a bright light and shine it on the screen when it is on. Can you barely see any display, but really dark? If so, the lamp or the lamp inverter has failed (some laptops use LEDs instead of CCFL lamps and has no inverter either).
Just hooking up to another display doesn't necessary tell you anything if it doesn't show anything. As sometimes you have to change a settings in the BIOS, use the Fn key plus another key that looks like a monitor, or change it through a display menu on the screen.
Posted on Jan 30, 2009
Dell inspiron laptop grey dotted line across
You could try removing the display device in device manager then rebooting. At boot up windows will reinstall the drivers.
Check for new display drivers at Dell's support site.
Mar 13, 2014 | Dell Inspiron E1505 Notebook
Updated antivirus an it said to reboot an i did an now its a white screen nothing will load
It probably crashed explorer. If you hit ctrl+alt+del and choose run task -> explorer.exe it should show up.
Mar 07, 2011 | Acer Aspire 5050-3242 Notebook
I have two verticle lines- one white and other one
The screen will likly need to be replaced. Try an external monitor on it, does it still have lines? if not then its the screen on laptop.
Feb 25, 2010 | HP Pavilion zd8000 Notebook
White screen on Acer Travelmate 7720
most likely you have a faulty LCD screen, the only option u have is to replaced it or u can use a external LCD screen to act as screen for your laptop. you'll be needing a VGA cable to connect your laptop to any LCD screen available.
Dec 16, 2009 | Acer Aspire 7720 Notebook
Display freeze then colors became crazy
Turn off the Notebook remve all the peripherials, Remove battery and disconnect AC Adapter and then press and hold down power button for thirty seconds.
After 30 Seconds connect Battery and Power supply as soon as you tun on the Notebook keep on hitting F10 Notebook will show BIOS then F9 Notebook will show Load Set-up Default than Hit yes and Hit F10 again it will show save Exit and chnages now that show Fix the Problem
Thanks and Regards
Neeraj Sharma
HP and Compaq Notebooks Expert
Oct 10, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
White screen
the video cable behind the screen panel probably became loose. so what you would need to do is take off the front cover, usually screws are hiding under the little rubber pads. then then get behing the monitor and unplug it and then plug it back in and tape it down.
Jun 14, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Display blinking and turn in to white color with black lines
no its not a driver you have a video chip getting ready to fail.on the v2000 it intergrated in to the mother board. soon you will be joining many other compaq v2000 and m2000 owners in the search for a mother board compaq has updated part numbers it a whole differant board for these units due to having a common failure rate of the original mother boards.Compaq know there was a over heating of the video chip that leads to failure but has not offered any assistance to there customers. john@johnslaptops.com
Feb 17, 2009 | HP Compaq Presario V2000 Notebook
Jumbled / black screen
Have you run an on line virus scan such as Bit defender, it is free and I came cross this once before and it was a virus that the up to date anti virus in residence had missed. Its worth a try, good luck
Jan 10, 2009 | HP Pavilion dv4000 Notebook
Wi fi problem
You can try to restore your system to an earlier point, maybe you changed somenthing into your settings accidentally or a new software installation moved something.
CLICK ON START
ALL PROGRAMS
ACCESSORIES
SYSTEM TOOLS
SYSTEM RESTORE
choose restore my computer to an earlier time
NEXT
choose the closest system checkpoint since it worked fine click next
your system will be restared.
If it does not work you can try to an earlier point.
Regards
Feb 10, 2008 | Computers & Internet
My laptop screen is flickering
That could be ths connector that connect the LCD to the Motherboard in the laptop. Ive seen something similiar wherein i took down the screen, cleaned up the connectors and it worked like new...... for a few weeks then it went back and started he flickering again. We finally fixed the problem by replacing the screen. Apparently the connector behind the screen was giving trouble. Have someone check the cable from your LCD to the board but I think you might need to fix the connector or replace the LCD screen. Regards, babb
Apr 19, 2007 | Evesham Voyager 5800 Notebook
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
