Question about Casio Parts Cash Register PC Desktop
Replacing lock/switch combo.
Have a ce 2350 and old one for parts. the key/ switch combo is broken and won't go past "x". have removed four screws in tape/battery compartment, but right side won't slide back. can't find the fastener.
  • 737 Answers
Hi.
The best way to find the screw or clip that is holding it is to take the tray out of the drawer and look on the inside of the drawer. You can see all the points where screws come through the drawer. Just find the one that is still holding on.
Mark
Posted on Jan 30, 2009
I had just replaced my ignition lock cylinder in my 92 Camaro Rs, and I'm under going several problems. Problem #1: My brand new ignition lock cylinder won't lock as to where the key cannot...
If all you did was to remove things down to the turn signal switch to allow access to the screw that holds the lock cylinder in, I would check the ignition switch for being out of adjustment. Do you have to turn the key a long way to get the engine to turn over? If you have to do that as well then go towards the bottom of the column. The switch is held on my two screws (5/16..maybe one a phillips screw). Loosen the screws and slide the switch. In your case with not turning back far enough to get the key out I would say slide the swicth down towards the firewall. The high/lowbeam dimmer swicth is also attached to part of the ignition switch.
Your clockspring not going in makes me think you don't have the rest together correctly. There should be a heavy spring, them the white plastic horn/ signal actuator that fits around the top of the spring, then the lock plate, THEN, there is a C clip. Just a round metal clip that is split. The lock plate needs to be pressed down, usually with a tool (I have used my thumbs and a budies help in the past) then that clip slides over the shaft and down into a grove to keep the lock plate down tight.
If that is not done then this could also be the reason why your column feels loose. Another reason for that is at times there are four Torx bolts that work themselves loose. If the column was tight before I would bet its the clip is not in the lock plate.
I have pictures of when I replaced my ignition lock in my 91 (same column) I don't know if I can post them here though.
http://www.createforum.com/allgenfbody/index.php
This is my forum. If you join and then PM me I can get you the pics. Then once that is done, if you wish you can delete your account.
Jul 26, 2011 | 1992 Chevrolet Camaro
Need to replace ignition cylinder. no keys
This is not an easy repair due to anit theft requirements. need to chisel off bolts.
Section 11-04: Steering Column 1997 Probe Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 05/17/2000
Ignition Switch Lock Cylinder Removal
  1. Remove the steering wheel (3600). Refer to the procedure in this section.
  1. Remove the four lower steering column shroud screws.
  1. Separate the upper and lower steering column shrouds.
  1. Remove the ignition switch lock cylinder illumination miniature bulb from the lower steering column shroud.
  1. Remove the upper and lower steering column shrouds.
  1. Remove the multi-function switch (13K359). Refer to Section 11-05 for the removal and installation procedure.
  1. If equipped, remove the ignition/shifter interlock cable screw.
  1. Disconnect the ignition/shifter interlock cable (3F719) from ignition switch lock cylinder (11582).
  1. Use a chisel to remove the two ignition switch lock cylinder bolts.
  1. Remove the ignition switch lock cylinder from the steering column.
  1. Disconnect the ignition key reminder switch electrical connector.
  1. If necessary, remove the ignition key reminder switch.
Installation
NOTE: Use new ignition switch lock cylinder bolts. Tighten the bolts until the bolt heads break off. Check for proper ignition switch (11572) operation.
To install, reverse the removal procedure.
Mar 25, 2011 | 1997 Ford Probe
Key wont come out of ignition switch
Try to push shifter higher in park and remove the key at same time, make sure your foot is off of the brake pedal.
Feb 21, 2011 | 1997 Dodge Neon
How do you remove the ignition switch part to replace
FIRST OF ALL TURN OFF RADIO TO KEEP FROM LOCKING IT OUT.THEN DISABLE AIRBAG.DISCONNECT NEGATIVE BATTERY CABLE.WAIT 20 MINUTES.MAKE SURE TURN THE STEERING WHEEL SO THAT BOTH WHEELS POINTING STRAIGHT AHEAD.TURN IGNITION SWITCH TO LOCK THEN REMOVE KEY.TO REPLACE THE IGNITION SWITCH.REMOVE THE INSTRUMENT CLUSTER.REMOVE THE 2 SCREWS SECURING THE IGNITION SWITCH.PUSH SWITCH 1 INCH STRAIGHT BACK TO CLEAR THE MOUNTING BRACKET THEN LIFT OUT.TO REMOVE LOCK CYLINDER PUT KEY IN SWITCH TURN TO RUN POSITION THEN DEPRESS THE PIN WITHDRAW THE LOCK CYLINDER.
Jun 30, 2010 | 1999 Oldsmobile Alero
CASIO CE2350 E1 MESSAGE
You haven't finished in the previous mode before you turned the key. Turn the key back to where it was before the error and finish what you started in that mode. ----------------------------------------------------------------------------------------------
If anyone is looking for a Casio CE-2350 manual, go here: http://the-checkout-tech.com/manuals/cashregisters/casio1.php
Jun 11, 2010 | Casio Parts Cash Register PC Desktop
Ignition Lock cylinder set removal
Then you either got the wrong bolt, or the knob part is still in the hole. Take a close look at the bolt you took out, and see if something may have broken off it. If it did, you might be able to get the rest out with a magnet. There is a threadless part on the end of the bolt that's about an inch long. It goes down against the tumbler and hold it in there. The newer ones are a torx head, but i can't remember if 78 is or not.
Jun 02, 2009 | 1978 Chevrolet C1500
Something is broken inside ignition switch housing.
The ignition crank shaft is broken inside the Steering Column Lock Assy. You will need to buy a new assy (cost appr. $202.21) and 2 steering lock bolts (cost appr. $4.96 ea) at a Toyota or Lexus dealer. Call either dealer for best price and availability. To replace you'll need to remove the black snap-on panel below speedometer then remove the screws securing the driver side dash. Behind the dash is a steel plate. Remove that and remove the steering column covers by turning the steering wheel to access the screws. You'll see that the SCLA is secured by 2 break-away bolt (this is an anti-theft feature). Use a dremel tool with cutting disc to make a notch in the screw head to remove with a flathead screwdriver. If this doesn't work your other option is to cut the bolts where the assy bolts together. Remove the broken SCLA and remove the key FOB and install into new SCLA. If your mechanically incline this should take about 2-3 hrs. and save you $300-400 in labor cost. Part numbers are same at Toyota and Lexus dealers.
Steering Column Lock Assy: 45280-60510
Steering Lock Bolt: 45897-12020 (need qty. 2)
Mar 16, 2009 | 2000 Lexus LX470
My key broke in the switch can switch be saved
Yes, you need to remove the steering wheel and the wheel lock collar then remove the signal switch plate.....on the left side of the steering shaft there is a single screw remove it and the ignition switch will slide out(you may need to rotate the switch to the run position.)then you should be able to push the broken part of the key out..........you may need to drill a small hole in the bottom of the cylinder and use a small screw driver to push the broken key out
hope this helps.....Good Luck!
Dec 15, 2008 | 1991 Buick Regal
Konica Minolta Magiccolor 2350 Laser Printer
When the front door is open, it locks the 4 cartridges so they can not move. The tab is flimsy & I broke mine on the second or third change. It pushes on a mechanical switch just above the toner port. If you broke the tip of the tab off, you can use a drywall screw inserted into the Mechanical switch. when the door closes the bigger part of the tab will push the screw against the switch,
Jul 16, 2008 | Konica Minolta magicolor 2400 Laser...
Casio Parts Cash Register PC Desktop Logo
48 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
