Question about Kenmore 47772/47774/47779 Electric Double Oven
Delay or time bake
Kenmore Pro Double wall oven
Is there a way to do time bake or delay on
these ovens. I can not find it in the manaula and
don't seem to be able to figure out a way to make the
timers do it.
    President:
  • 1,214 Answers
You can find the manual at www.managemyhome.com, and the instruction is on page 11.
You make sure the time is set correctly.
You press Bake, and set the temperature you want to bake.
You press Cook Time and enter the amount of time you want the oven to cook.
You press Delayed Start, and enter the clock time that you want the oven to start.
Posted on Jan 30, 2009
Element heats up when we only put oven light on
Stove will not turn off CHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
Nov 17, 2014 | Whirlpool RMC305PV 30" Built-in Microwave...
When trying to thermal/radiant bake, convection fan at the rear does not stop turning after the preheat. Why doesn't this happen? Isn't it then convection baking?
Most wall ovens have a cooling fan that comes on when the oven has been on for some time. It is separate from the convection operation. It should shut off after the oven has been off for a time.
Nov 12, 2013 | KitchenAid KEBS279BWH 27" Double Electric...
Oven door will not open
This unit may have a door lock built in to the control unit lockout. To release it you may have to turn off the oven circuit breaker in your house circuit box. If not, it is just jammed and you will need to wobble it free.
Jan 12, 2013 | Whirlpool RBD275PVS 27" Double Electric...
GE electric range with self cleaning oven. When
try to unplug power from wall and wait 30 min,then turn on
Jul 05, 2009 | Ovens
My oven was a display model & I have no manual. I'm trying to figure out if I can do some type of delay bake
Here's the manufacturer's website for a free downloadable manual. Don't be thrown off by the whirlpool name - this will have your Maytag manual. Enjoy your new oven and send me a brownie when you bake the first batch!
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=CWE5800A&siteCd=MT_EN_US
Dec 24, 2008 | Maytag CWE5800A Electric Double Oven
Broil turns ON when pressing BAKE button on RBS275PD Whirlppol oven
Our Whirlpool oven just started doing the same thing!!!! The Delay Start Time (setting it for one minute ahead) and then Start works just fine.  But we fried the tops of three loaves of homemade bread!!!!
Is Whirlpool just a bad brand for ovens?
Dec 07, 2007 | Whirlpool RBS275PD Electric Single Oven
I need to disable my ovens auto shut off
The control is automatically set to turn off the oven after 12 hours baking or 3 hours broiling should you forget and leave the oven on. If you want to remvoe this feature do the following steps: 1. Press and hold, at the same time, the BAKE and BROIL buttons for 3 seconds, until the display shows "SF". 2. Press the DELAY START TIME button. The display shows "12Shdn" for 12 hour shut off. Press the DELAY START TIME button again. The display will show "no Shdn" for no shut off. 3. Press the START button.
May 21, 2007 | Kenmore 33464 / 33465 / 33469 Gas Single...
Kenmore 47772/47774/47779 Electric Double Oven Logo
1,211 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
