Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Why wont my washer spin?
My washer goes through every cycle but when it comes to spin it drains the water, but wont spin it. It just stops! what is wrong?
  • 4 more comments
  • Anonymous Feb 01, 2009
    washer drains but wont spin makes chattering sound
  • Bocciball Feb 03, 2009
    My washer wont go on the spin cycle. We took apart the transmission and the main nylon gear was stripped. We replaced it and it still wont go into high speed spin. We were told that it was the timer, we replaced it with the same result. What going on?
  • loriallen Feb 06, 2009
    I know the answer I just can't figure out how to get the casing off to fix it. Its the lid switch. It costs 37.00 but I need to figure out how to install it!!!
  • ak67 Feb 09, 2009
    my washer won't spin nor will it agitate but the water fills up and drains out at apropriate cycle points
  • gmo1028 Feb 10, 2009
    Can I replace the coupler by tilting the machine back without taking the cover off?
  • jim6910 Feb 11, 2009
    I have the same problem. All the cycles work except it won't spin to dry the clothes. I replaced the motor coupling but it still doesn't work. I can hear the motor running and it stops running when I open the lid.
  • 370 Answers
You need to replace the drive coupler. It is the piece that is between the motor and the transmission. You can see this part when you tilt the washer back and lay under it and look between the motor and the tranny. This is a very cheap part only about 25 bucks.
Posted on Jan 30, 2009
4 Suggested Answers
reg501
  • 413 Answers
SOURCE: frigidaire washer wont go into spin cycle
Check the lid switch for proper operation.
Posted on Jun 17, 2008
jsrock516
  • 5911 Answers
SOURCE: washer
The symptoms you describe are typical of a broken lid switch. The lid switch is located under the washer top on the right hand side. It is activated through a slot by a small plastic piece on the lid called a "lid strike". Make sure the lid strike is still installed and not broken. Make sure the lid switch itself is not loose, as well. There are two mounting screws along the washer tub opening that hold it in place. If the screws become loose the switch will not make contact with the lid strike when the lid is closed. If you need to replace the switch or lid strike, the parts are available at searspartsdirect.com. Just type in your model number and look under the "Washer Top and Lid" heading on the next page. The lid switch is listed as item number 22 (part #3355806) and the lid strike is listed as item number 16 (part #358684). Both parts combined will cost you about $30. If you have further questions and/or require additional assistance, please let me know. I hope this helps you.
Posted on Jul 22, 2008
heatman101
  • 43501 Answers
SOURCE: washer wont drain. fills
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Apr 21, 2011
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
Why did my washer quit spinning out in spin cycle
Quite often the problem with spin cycles is that the cycle cannot start until a sufficient amount of wash/rinse water has drained. So what will often happen is that the washer drains, the cycle starts, a lot of water comes out of the clothes, it stops, waits for the water to drain, then restarts. If the drain pump or drain lines are restricted or blocked or the pump is faulty, the unit may never achieve spin cycle.
Sep 18, 2014 | Washing Machines
What can be wrong with my washer my kenmore washer wont spin
I've posted on this subject before. Your washer will not cycle correctly if there are any restrictions in the pump and this usually means that during doing the wash things have been transferred from your clothes generally the pockets. ..These things usually get lodged in the pump. When the washer enters the spin cycle the pump kicks in and pumps out the excess water. If you can get the back off the washer you will see a semi - round object that is usually white with 2 hoses coming out of it. One hose is the water in let hose the other one is attached to the drain hose that goes into the sewer drain outside of the washer. Make sure that the washer is unplugged then remove the hose that goes to the outside drain. Now with a flashlight look inside of the pump and see if you can see any debris or foreign objects. If you see anything in there you will have to remove these things through the hole where the hose connects. After removing debris replace hose inspect the surrounding area for obvious reasons why the washer may have stopped like look to make sure that the belt on the drive motor is ok. With no other signs of problems replace the back of the washer andplug it back in and try to sstart the washer just like you were just starting a new load of laundry. G
May 22, 2014 | managemylife.com
Kenmore washer stops spinning a few seconds in to the cycle.
Sounds like the brushes are struggling to get enough power to the motor to spin. Renew motor brushes
Apr 21, 2012 | Kenmore Washing Machines
Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
heatman101
Apr 21, 2011 | GE Washing Machines
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
182 people viewed this question
Dan Webster
Dan Webster
Sal De
