Question about HP Pavilion F1703 17" LCD Monitor
Hp 1703 Video for 1second then Black Please Help if you replace the main boards ( Power & Video Or just the Power Board) will this fix the display issue. thanks
  • trainnut2 Jan 31, 2009
    No OS install just power up the monitor in bios only..montior on for a second or two then is looks to be the backlight, because if you use a flashlight you can see the bios. Should I replace the power Board.I taken the monitor apart and there is no broken solid. thanks
  • Misterixas May 11, 2010
    Do you mean video on monitor shutts off when entering Windows, or before? Have you tried starting your computer with Safe Mode?
    If you are using Windows Vista look for instruction here:
    http://windowshelp.microsoft.com/Windows...
    For Vindows XP, here:
    http://support.microsoft.com/kb/315222
    If your monitor works fine, then there's something wrong with video card, it's drivers or even power supply unit
    Sniper:
  • 96 Answers
Probably something wrong with the monitor's power-board. If you are good enough in electronics and soldering, disassemble the monitor, unscrew the board. Check the cables, connectors, blown caps and fuses (some of them may doesn't look ordinary) first. Look for the dry joints, especially at transformers. Resolder all the connections. Test power transistors. You should unsolder them to test properly.
Posted on Jan 31, 2009
    Scholar:
  • 118 Answers
You may want to check your power and connection cables are not showing bare wire, which is the metal hanging out of the rubber insulation cord. So just check for that and if not that I would call HP.
Posted on Jan 30, 2009
2 Suggested Answers
  • 3 Answers
SOURCE: Hp 1703 Video for 1second then Black but can see it but wery dark
sorry, not really a solution, but may help point you in right direction. I have similar or same problem with my monitor but is an f1903 (HP). I recommend you look at the f1903 board postings to see those answers. Several seem identical for fixes and fix may possibly be cheap, but unfortunately noone has posted how to open the monitor up to actually check it inside. This is the tricky part, as seems no catches or buttons are present and removing back screws do not let the monitor case open without some type of special trick or move. If you figure it out, please tell us all! Thanks
Posted on Feb 12, 2009
Lg Flatron-w1942T Problem: Black display plz help when i swich on the monior it shows video for single moment and then black .au io is ok my video card is ok
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Sep 01, 2016 | LG Computers & Internet
WMG30GS Whirlpool microwave display
please follow this steps and fix it. God bless you
  1. Main control board If the display on your microwave has gone out completely this is usually a sign that it is a malfunctioned main control board. To correct the issue the main control board would need to be replaced.
  2. Display board A display board can either malfunction completely or partially, causing two separate results. If the display on the unit has completely gone out, this can be attributed to either a bad main control board or display board. On the other hand, if the display has only partially gone out, this is usually a sign that the display board is defective and will need to be replaced
Nov 27, 2013 | Microwave Ovens
Vertical bars (1 black, 1 cyan) running from top to bottom. Which board do I replace?
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Aug 18, 2017 | Samsung HP-S5053 Television
I have LG 50PC3D-UD display issue. I'm getting a black screen with thousands of blue pixels in center of screen. 5-6 inches wide orange horizontal from top to bottom moving across the screen. I check and...
The reason the blue pixels are igniting is caused by the driver board, not the power supply or main board. The drivers are part of the LG screen and cannot be replaced.
Mar 08, 2017 | LG 50PC3D 50 in. Plasma Television
Proscan 47LB45H tv turns on , has sound , no video
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jun 19, 2017 | Proscan 47LB45H 47 in. LCD TV
HP compaq nc6220 doesn't starting up, with power light on
try to go in to you bios and check and see if the video is set to your monitor or a secondary sorce
Mar 24, 2009 | Compaq Presario 1200XL104 Notebook
Jan 30, 2009 | HP Pavilion F1703 17" LCD Monitor
AKAI Plasma TV PDP5016H
See I cant cross that part number and I have all the boards sitting in front of me. That number is the akai part number, but not the actual number of the board. There are 2 boards that they call main in the service manual, the main control board which actually drives the panal, and the "main video board" which handels the video inputs and on screen displays.
PCB failure analysis
1. MAIN CONTROL : a. Abnormal noise on screen. b. No picture.
2. MAIN (video): a. Lacking color, Bad color scale.
b. No voice.
c. No picture but with signals output, OSD
and back light.
If you can determine which of the 2 boards is the problem, I can sell you a new replacement for $125 shipped.
Basicall....Control board is no picture at all.
Main board is no picture, but on screen displays work.
Aug 16, 2008 | Akai PDP-5016H 50 in. HD-Ready Plasma...
HP Pavilion F1703 17" LCD Monitor Logo
159 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
