Question about Refrigerators
The light bulb blew in my refrigerator and I went out and bought a new one and it still did not come on
  • Anonymous Apr 01, 2009
    Nothing like answering a simple question with an irrelevant question. Somebody wants to know how to change the bulb. The cover is on like fort knox. Same question I have. No answer here though.
    President:
  • 1,214 Answers
Does the refrigerator still work?
Posted on Jan 30, 2009
Side by side ice and water dispenser
Did you replace the bulb with one of the same voltage rating?
Seems strange that a new bulb should blow straight away, maybe it was faulty.
This sounds like a blown fuse.
Oct 13, 2007 | Frigidaire FSC23F7D Side by Side...
GE model 26 we changed the bulb and light still is not working..what can it be?
try checking for a stuck "off" switch around the door or where the door latches, or could be loose wiring, Do Not open up the guts of a microwave unless you know what your doing, you can seriously hurt or even kill yourself.
May 09, 2012 | GE Microwave Ovens
Suzuki katana ay50 treg my front and rear light went off put in new bulbs and they blew
Check the battery voltage when the engine is running. It sounds as if the regulator has failed. Also check the earth lines on the bike and make sure they are tight and clean.
Mar 17, 2012 | Motorcycles
Ice dispenser won't work, light won't work.ge side by side fridge
A GE uses a 12 volt bulb . It will not come on , if you went and bought a bulb with the same receptical end . HAS to be a 12 volt .
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My hitachi 50v720 bulb blew and the replacement doesn't fit
I believe the lamp you need is the UX21516. not the 21517
I have a 50VF820 and this is the lamp for it.
By the way my unit just hit the 3 years and the lamp just blew as well.
Dec 14, 2008 | Hitachi 50V720 Television
KSRS22FGWHO4 INTERIOR LIGHT LOCATION
As I mentioned previously, I had previously tried a new bulb behind the control panel and it didn't work. I tried again, but first I unplugged the refrigerator, and then installed the new bulb. And when I plugged the refrigerator back in, the light worked!
I am not sure why unplugging the refrigerator before installing the new bulb worked, but it did.
Darrell
Sep 11, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Interior light
Hi. I've seen this situation on this model. The bulb is not screwed in all the way. You think it is but it is not. If it still doesn't work, get new bulb. Sounds like you got a couple bad bulbs. Good Luck, Mack
Mar 29, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Magic chef #rb19k-4a refrigerator: bulb replacement
unplug refrigerator look inside light socket youll see a tab in the bottom of the socket bend tab up alittle bit then screw light bulb back in. if this doesnt help then the door switch is bad
Nov 21, 2007 | Refrigerators
Refrigerators Logo
144 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
