Question about Ruud UBHC Air Conditioner
    Problem Solver:
  • 8 Answers
Most air handlers will have an area where a electric heat strip will hook up,get it from dealer
Posted on Mar 19, 2009
Is a RUUD UBHC-14J11NFH a heat pump?
Compressor and condenser not included
Spec sheet go here
Jul 04, 2014 | Ruud UBHC Air Conditioner
RUDD Model UBHC-21J18SFA: Emergency heat not automatically engaging. Used to work, now I must manually turn the thermostat to "Emergency Heat" to get the elements to engage. What's broken?
Sounds like your Auxillary heat is out (the element that is energized when an air to air heat pump can't keep up with the thermostat setpoints).
Jan 30, 2014 | Heating & Cooling
No heat unit is blowing cold
thermostat, heat sequencer, heat elements, fusible link no 240 volts. fan works on 120 volts.
Jan 24, 2014 | Ruud UBHC Air Conditioner
Ruud ubhc wiring manual blue
depending on ambient temperture there may not be enough heat in air to transfer into house that would be first stage. the auxilarry heat is second stage
Jan 16, 2014 | Ruud UBHC Air Conditioner
I have a ruud model no. ubhc-17j11nfd and i am having a problem with my heat. when the heat does come on, the thermostat says it is on auxilary heat. i am getting no suction from inside the house but the...
If you haven`t changed your furnace filter do so. If there still isn`t any air flow then the evaporator coil is plugged with dirt and needs cleaned. It is inside your furnace where the pipes from the outside unit connects. As far as the auxilary heat, this is normal when the house temperature drops to far below the thermostat set point and they will turn off when the house is close to temperature and lets the heat pump take over.
Feb 02, 2011 | Ruud UBHC Air Conditioner
Trouble Wiring in Rheem heat pump
The red wire goes back to the furnace red, the blue back to the thermostat blue, the brown back to the furnace C terminal, the yellow back to thermostat Yellow (if there is a Y terminal on that furnace, land your Y's there. The purple wire outside comes back and ties to the W terminal on the furnace. Now you have a dual fuel unit so you will need a dual fuel kit or a thermostat that has dual fuel capability along with an outdoor sensor.
Jul 02, 2009 | Ruud UBHC Air Conditioner
all units specially straight cool or heatpumps have heatstrip connections
Jan 30, 2009 | Ruud UBHC Air Conditioner
Need to Replace Heat ELements
you remove the screws that hold on the base plate that has the sequencers mounted on it. pulling it out so the elements clear the sides of the unit. once you remove it you can easily see the heating element coils which you can purchase a restring kit fairly cheap at your local appliance parts store. just remember to stretch it out uniformally the same length as the old one, reinstall the heat kit the same way you removed it. kit comes with new ceramic gromets if some are damaged. these units do have a 5 yr warranty on the heat strips.
Jan 12, 2009 | Ruud UBHC Air Conditioner
I have a heat pump unit. the fan will not come on. on the outdoor
ck capacitor on blower motor,ck relay,also make sure you have signal from thermostat to indoor unit
Dec 30, 2008 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
137 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
