Question about Cobra 25 LTD 40-Channels Base CB Radio
Static noise in my cb radio
When i am transmitting on my radio to someone , they say it sounds like it has a lot of stiatic, in it can this be fixed
  • Anonymous Mar 03, 2009
    still getting static after trying out solution
    Problem Solver:
  • 16 Answers
Radio craps cleaner aint cheap i just paid 11 bucks for a 4oz can.
Posted on Feb 01, 2009
  • 170 Answers
A lot of times the "static" Is actually a loos connection in the microphone or a dirty micke gain control. Radio shack sells a cheap tuner cleaner if you know how to take the covers of and find the mic gain control, spray it in the little slot in the control( be generous) move the knob back anf forth several times. Also if you have another mike wired for cobra, try it and see if it helps. Those two solutions fix 98 percent of the problems. If it doesn't, please let me know. I am very good with cobra radioes and am sure we can solve this problem.
Good Luck. If this so;ution helps, please rate me.
Tom
Posted on Jan 31, 2009
I have a cobra 29 with echo, tweeked and tune. I can transmit strong and I hear those who speak to me but I dont have any static like you do with a new radio. Is this something I need to worry about as Im...
Make sure the squelch is turned all the way to the left, the RF GAIN is turned all the way to the right. The cobra 29 has a very good noise blanker, Turn the ANL/NB switch to off, You will probably hear a Lot of static, As long as you have a good ground on the radio and antenna, and your SWR is 1.5 or lower, you need not worry about static.
Oct 05, 2012 | Cobra 29 LTD CB Radio
I have a midland 75-822 micro mobile-portable cb in my van. a lot of static and i was wondering how to correct it. thank you kindly.
your problem has many fixes depending on how you use your radio, but first think of were you are transmitting from a van or car is literally a big metal box so the squelch minimum will increase a bit if your antenna is inside the van. but if you use/get the UHF-DC adapter for this radio it will alow you to mount a exturnal antenna on the outside of the van, the other possibility is a bad placement of the antenna try changing its location. however if the noise increases as you excelarate then you might need a in line DC Noise Filter.
Jan 24, 2011 | Midland 75-822 40-Channels Handheld CB...
I have a cobra 29 ltd chrome and it making a lot of static noise while driving or idling. it transmits and recieves fine though
Hi, my name is John. Welcome to FixYa. Try running your power strait from the battery, that will bypass a lot of your noise. RED (+) ground (-) . Thanks for choosing FixYa....John
Nov 30, 2010 | Cobra 29 LTD CB Radio
Rushing sound (noise) galaxy 88 HL
RUSHING SOUND ?
1. Get the noise then disconnect the coax and see if noise goes away on receive, if noise goes away then address the ground on your antenna,
if noise still there then address the ground wire from power source
Mar 30, 2009 | Galaxy Radios DX- 88HL Base CB Radio
Can not hear people through static from radio.
no,its in the radio.i have had a lot of radios,and i have had several with just too much noise.its in the radio.i would not go by what a trucker cb shop says.contact company,or try and sell it and start over.i have had to do that also.
Feb 15, 2009 | Connex 3300 240-Channels Base CB Radio
I have no reciving in a cobra 29 ltd chrome
Bad switch. It's that simple. The factory switches are crimp together junk. You may be able to use a pair of needle nosed pliers to softly squeeze the case of the switch together to correct the poor contact in side of the switch, but, if it gets a lot of use you may need to replace it altogether. Or try adjusting
Thanks!
Dodgem
http://dodgem250.angelfire.com
Apr 29, 2008 | Cobra 29 LTD CB Radio
Troubleshooting?
You could peak and tweek it to a legal limit. A local CB Shop should be able to help if they do repairs. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 18, 2007 | Radio Communications
Cobra 25 LTD 40-Channels Base CB Radio Logo
461 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
