Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave problem hi, iam using panasonic nna774.i replaced magnatron as the microwave was nt heating and shutting down in less than 30s ecs.now iam facing another problem.microwave is heating but this time it shuts down exactly after a minute like a timer.even the mechanic doesnt understand the problem.he doubts a loose connection in the keypad.pls help me. thanks
  • 3 Answers
Could be that magnetron is not receiving adequate cooling thus causing thermal protector to open. This is mounted on the magnetron.
Posted on Aug 02, 2007
SOURCE:
I bought my microwave last year,It had been working but suddenly will not heat, the light comes on table turns and sounds like it is on but will not heat? please help
Repolace the microwave, the heating components like the magnatron would cost almost as much as a new microwave. If money is an issue try Goodwill, they usually sell microwaves for about 5-10$ which is WAY less than cost of parts.
Sep 20, 2012 | Panasonic Microwave Ovens
Microwave is still running when the door is open
The cooling fans run for a time after the magnatrons have stopped, The magnatrons are the heating components so I dont think you are in any danger as the microwave doors are double locked so the magnatrons cant run once the door is open
Sep 27, 2009 | Panasonic Microwave Ovens
Microwave runs for about 20 seconds then shuts off.
My mother had the same problem and she was going to trash it. Me being an extreme environmentalist, dint wanna let it go to the scrapyard. Got it down to Mumbai India checked with the engineers down here and rectified it. Problem was with the Magnatron. You would need to replace it. Well this one's getting repaired and off to a institution in need like the Home for the Aged rather than some scrapyard.
Apr 18, 2009 | Panasonic NN-SN657S Microwave Oven
MICROWAVE RUNNING. DON'T HEAT & TURNTABLE WON'T TURN
your magnatron needs replaced! (It may cost less for a new one then to fix this one!)
Dec 09, 2008 | Sharp R-930AK Convection/Microwave Oven
Magic Chef MCO153UW
You absolutely need the magnetron cooling fan to be working, or the magnetron will be destroyed!
It is part # 3511800100 and you can order it for less than $20 here.
Far less than a magnetron.
Aug 28, 2008 | Microwave Ovens
GE JVM1870 Runs, but won't heat up
use a high voltage probe to check high voltage, if present replace the magnatron if no HV replace the high voltage board this is the board that has the heavy wires to the magnatron
Feb 06, 2008 | Microwave Ovens
Panasonic Microwave Warm
Replace the h.v. capacitor (the silver can mounted in back under the magnatron) and the h.v. diode and it will be fine.
Hope Ya Fix It!
Jan 30, 2008 | Panasonic NN-S960WA Microwave Oven
Panasonic microwave does not heat , but the rest seem's to work?
High voltage parts are suspect. Need to put a voltmeter on the input (primary) side to the high-voltage transformer (big heavy iron thing in there) Should be getting 120Vac when it goes to cook cycle. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing either the magnatron or the high-voltage capacitor and diode. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Jan 25, 2008 | Panasonic NN-H264 Microwave Oven
Microwave won't heat.
Magnatron is suspect. Need to put a voltmeter and see if the input (primary) side to the high-voltage transformer (big heavy iron thing in there) is getting 120Vac. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing the magnatron. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Dec 30, 2007 | Maytag UMV1152BAS Microwave Oven
Microwave is nt heating
The problem of shutting down after 29 seconds is due to a defect in either the magnetron or the inverter. It will need service, preferably by a professional due to the lethal voltages inside. You should be able to find a servicer at the Indian site: http://nationalpanasonicindia.com
May 03, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
97 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
