Question about HP Pavilion dv1000 Notebook
Wireless not working
I have V6211AU Compaq Laptop. I used to connect via wireless some time back. But not I am not able to do that. Tried everything from reinstalling the drivers, downloading it from HP website, Reformating the system.
I do not see wireless lan adapters in Device manager, have enabled it from BIOS as well, enabled wireless zero configuration as well. But it still does not show up.
Any suggestions?
  • Dan rogers
    Dan rogers May 11, 2010
    Look for a switch on the laptop or up on the F-buttons for a pic that resembles this "I" and that is how you will turn the device on. Since you have a laptop there is somewhere to switch it on and off.
  • 520 Answers
Do you have built in wireless or plug n play wireless.
if you have plug n play wireless and it isnt plugged in(connected)
it wont show in device manager if its built in you should at least see wireless icon.
if you downloaded the driver from site its a self extracting file that unpacks the software to install it doesnt install in other words you need to locate the extracted file and execute it which will install the driver then pc will detect device and install to system.
also try installing wifi manager and use without zero config.
Posted on Feb 15, 2009
Cannot connect to wireless internet
It sounds like a problem I had. While traveling, my laptop connected with a WIFI network with the same name as my home network.It was my son's. He gave me his password and I entered it on both my machine and my wife's. When I got home I had the same problem. I tried everything including re-installing the WIreless drivers a few times. I could cable connect but every time I tried wireless, it told me to enter a password then came back with "SORRY CHARLIE"
Called my son and he said probably the wireless password was written to my registry and my laptop was telling me to give the password. As my router was expecting a different password it wouldn't connect. The cable connection did not check the registry since it uses a different driver set.
The registry entry for the router password must be deleted. The only way I knew how was to re-install my operating system. This is throwing the baby with the bathwater. I am sure someone out there knows how to find and erase a Register entry.
Jan 25, 2012 | HP Pavilion DV6500Z Notebook
My Hp compaq laptop can not connect to the
many times this happens what u r saying......
the most probable cause could be non-availability or very week availability of network signals.....
IT COULD be also due to any change you have made to IP adderess
so first get conformed of the IP adderess u are using
Mar 30, 2010 | HP Compaq nx6110 PC Laptop
My Compaq Presario V6211AU laptop does not dectect wireless card!!! It detects for few mins after formatting the laptop. plz givw me a solution
you need to check your drivers. after seeing the magic word Format that is the first thing to look at.
Open system properties - control panel / Performance & maintance / system
Select Hardware tab at top
select device manager
look for any entries that are highlighted
right click on highlighted entry and select update driver
(allow internet access if asked)
do this for all entries highlighted
REBOOT
you should now be ready to rock... :-)
Oct 17, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
I have a compaq armada lap top and i tried 3 wireless connection and none of the are working
Your compaq wireless receiver may not be correctly configured. It is best to contact the hardware manufacturer and ISPs refuse to assist with the many variables in wireless connection problems.
Apr 18, 2009 | Computers & Internet
Wireless not define in my laptop
here ya go......
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-53245-1&lc=en&dlc=en&cc=uk&product=3200953&os=228&lang=en
Mar 09, 2009 | Compaq Deskpro EN 6500+ Model 6400 CDS PC...
Wireless connection
First you must sure that your wireless card is working
Second confirm your wireless setup is right.
Then reset your wireless account. Or your laptop battery cant supply the power to your wireless card, check the metal connection.
Oct 28, 2008 | HP Compaq nx6110 Notebook
Compaq EVO N400c without wireless capabilities will external wirelss card work?
http://www.everythingusb.com/hardware/index/Linksys_Wireless-G_USB_Network_Adapter.htm
This is just one source. I did a google search for USB wireless adapters. They are used by many users. Generally these units cost the same whether online or at the local Radio Shack, etc. because of shipping.
Oct 04, 2008 | Compaq Evo Notebook N400c
Router won't log into it's IP address online
It appears to me that you have everything plugged into the desktop PC. This is not the way that it should be done. Plug the cable modem into the wireless router via the Internet/WAN port. Plug your desktop PC into one of the ports numbered 1-4. Now connect to the router via the wireless connection for the router and you should be able to now connect to the internet with your laptop.
If it still does not work, power down everything in this order: Laptop, Desktop, Router, Cable Modem. Bring everthing up in the reverse order (Cable Modem, Router, Desktop, Laptop) waiting for each device to stablize before moving to the next.
Once you get everything working, turn on your wireless security (WPA not WEP) asap to keep your computers and surfing safe, and to keep intruders off your network.
Jul 20, 2008 | NetGear RangeMax WPN824 Router
Wireless
What are you trying to connect to?
Jul 04, 2008 | U.S. Robotics USRobotics USR5461 Wireless...
Wireless internet connection problem
You need to reinstall the wireless driver for your model laptop which you can find at the hp/compaq website. Just click on the link for support and provide information on the model of your laptop and you will be redirected to the proper web page that contains all the drivers for your particular laptop. I did this when my internal wifi did not respond when I pressed the wifi button. After installing the driver everything worked great.
Jun 09, 2008 | Compaq Presario Notebook
HP Pavilion dv1000 Notebook Logo
128 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
