Question about Jazz JDC25 Digital Camera
Donwloading problems camara plug into computer,picture wont display
  • Arlon Rosell May 11, 2010
    Do it ask for drivers? Please state the details.
First checkout connection, then go on My computer and then right click on it and go to manage and check it is working or nor.
Posted on Jul 22, 2010
Hi, how download the picture in my camara to my pc. I have a GE X5 digital camara.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Apr 01, 2011 | GE Cameras
Can I download pictures from my digital camera onto my Dell Latitude d410? If so, how?
You can download from any digital camara.Load the CD that came with the camara or obtain one if you can. You need the interface cable that is purchased seperately. You do not specify the camara spec so you will need to Google the" model and pc interface cable". If you have the cable then the next step is the camara driver which should be on your cd that came with the camara. Plug in the cable to the camara and to the USB port on the PC (make certain the camara is set to the Play position or PC). Windows will ask for the driver location. Insert the cd and continue. If windows does not see the driver you will need to locate it manualy from the cd or on line and download it to your desktop from the manufacturers web site. All camara companies have a support website for the drivers. Once the drivers are loaded then you need to switch the camara to the Play position so it can be seen by the computer. Go to the control panel in windows and select system then hardware then devices. If all went well you should see the camara listed as a device. Now you need the camara software or a picture viewer from the web. Here is the web kocation http://en.kioskea.net/telecharger/telecharger-653-picture-viewer
If all went properly 1. driver 2. picture software then you should be all set to handle your pictures. Good Luck Phil pmgibs1@verizon.net
Feb 20, 2010 | Dell Latitude D410 Notebook
Cannot see what im shooting and on lcd screen,no picture jus black. It shows numbers timer everything else except picture. In play mode everything works fine.
I have 2 xelim camaras. One of which has a piece of some type of cover partially obstructing the view. This camara still displays the time and menus and older pictures. If I take pix now the picture is obscured. The other camara has no picture on the display but when I take a picture it turns out just fine. That camara will need disassembled and a connector hooked back up
Most screens on digital camaras are for aiming the camara and output (displaying the picture) therefore any problems with the screen do not translate to a picture.
Oct 23, 2009 | Canon ZR85 Mini DV Digital Camcorder
My digital camara will not save pictures. Messages appear.
If you are using SD memory card, it can be locked. Take out your memory card, on the left side there's a switch. Turn switch up and try again. Hope this will work.
Aug 09, 2009 | Cameras
No input signal after downloading camara photos
check the num lock after power on the machine if it is working it is the problem with monitor otherwise it is the problem with system.
May 17, 2009 | E-Machines eMachines Desktop PC
Getting pictures from camara to computer
Which camera/brand you are trying to get pictures from??
Regards
Jan 19, 2009 | Casio Exilim EX-Z40 Digital Camera
Cannon Reble xti
Hi
Most Canon cameras you just plug it in the computer and away it goes... If that doesn't work set it to playback mode and then plug it into the USB port. If that still doesn't work, open up My Computer on your computer and see if it shows up, if it does right click it and make sure the Auto Play is set to transfer the pictures and is not turned off.
Hope this helps.
Thomas D.
Darntoothysam com
Oct 29, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Casio EXILIM camera lens will not extend fully!!!
Try plugging the PC interface cord into the external connector. No need to hook it up to your computer, just plug it in and out a few times. Then try to power up the camera.
Good luck.
Zductive
Jun 02, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Jazz JDC25 Digital Camera Logo
50 people viewed this question
Top Jazz Cameras Experts
pontelemon
pontelemon
Computer Links
Are you a Jazz Camera Expert? Answer questions, earn points and help others
