Question about Refrigerators
Pump wont run
Everything seems to work but the pump wont run
  • 7 more comments
  • craigpeterso Jan 30, 2009
    yeah i meant the compressor
    nope it isnt making any noise or getting warm i wonder if it needs to be charged but i dont know how to charge a fridge
    yes
    ill chech it out its a frigidaire frs26znh thanks
  • Mark Egan May 11, 2010
    OK. See if there is a wiring diagram on the back of the refrigerator. Or there may be one in a small envelope behind the front grille at the bottom of the refrigerator. And while you down there, look to see if you see a defrost timer, a little square box, sometimes with a screwdriver turned contol. If you do, plug the refer in , and turn that control some. If the compressor comes on, then replace the timer.
    If you hear other actions taking place, wait to see if the timer turns on it's own. If it does, we need to look elsewhere. If it doesnt, then replace it.
    Let me know the make and model of your refirgerator.
    If nothing is running, then it doesn't matter if there is a charge of freon. Don't even break into the system until you've exhausted all other remedies.
    Do you know how to use a voltmeter and read a wiring diagram?
    OK.
    Is the compressor body hot?
    When you turn the refrigerator on or plug it in, do you hear the compressor try to start?
    The topic heading is for a refrigerator, yet you say your pump won't run. I don't know of a refrigerator that has a pump (but I am always willing to learn something new!). Are you talking about a refrigerator, or are you calling the compressor a pump?
    President:
  • 1,214 Answers
I'm 99% certain the problem is the defrost timer. I found a wiring diagram for the refer.
It's mounted on the lower left corner, behind the front grill. You should see a slot for a slotted screwdriver that you can turn.
Posted on Jan 30, 2009
95 Taurus 3.8 SHO wont start replaced everything fuel pump to big relay is buzzing even new one im lost need help
Run tests. Fuel pressure correct? Spark at plugs when cranking? Fuel injector pulse working? Compression test?
Apr 06, 2015 | Cars & Trucks
Why wont a 2001 kia sportage start ???
look into the ignition relay, coolant sensor. Scan the ecu for any leads (codes)
Apr 25, 2017 | 2001 Kia Sportage
My GE front load washer doesn't run cycles
Check the connections again, specially around the control board.
Do you have water in the machine?
Mar 22, 2013 | GE WBVH6240F Front Load Washer
Drain pump isn't working properly or mystery clog
I would replace the drain pump if you are sure there are no obstructions to the water flow.
May 19, 2017 | Washing Machines
Hi there my yzfr125r is a 59 plate and it wont start. i have taken the whole thing apart and checked everything that i can do but cant find nuthing wrong it seems that its not gettin fuel into the engine...
If there is fuel coming from the injector and you're sure about it.
Better get a CDi from a friend and test it, looks like a CDi problem.
Tell me more after you replace the CDi.............
Oct 25, 2010 | 2008 Yamaha YZF-R125
Truck wont start
you have to replace your fuel filter, and just get a new pump in case
good luck
Aug 24, 2009 | 2001 Ford Super Duty F 450
Engine seems to run good then goes downhill
Have a look at the fuel pump it looses pressure when hot which means it is due to be replaced.
rate this please
May 24, 2009 | 1991 Subaru Legacy
Engine wont start,,battery works...starter works...not sure if its fuel pump or what the problem is
It might not have enough fuel pressure. Try spraying carb cleaner into the throttle body when you crank it to see if it fires.
Apr 17, 2009 | GMC Safari Cars & Trucks
Car and radio wont turn on - everything else will
sounds like the problem I had last week (20 amp fuel pump fuse under the hood) but try all the fuses.
You ask "Fuel Pump" Heck, I dont know seems to control ALL the relays
Jan 06, 2009 | 2002 Chrysler Sebring
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
