Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
1990 Kenmore Self Cleaning 24in Elec Double Oven - Top Oven door does not open
I placed food in the oven to cook. Someone came in the kitchen checked the food and pulled the knob across for it self clean. I cannot open the door. The food is still in the oven. I tried turning the oven on and letting it cool. That did not work. I have not tried the self-cleaning mechnism because I am afraid it may melt the pan and aluminum foil that is still in the oven. What do I have to do to get the door open? Thanks
  • Anonymous Nov 24, 2007
    self cleaning oven is locked with food in it
    President:
  • 1,314 Answers
Hit cancel or stop clear see if that helps if that doesnt work start self clean then stop it
Posted on Dec 29, 2007
How to change lower element in DeLonghi Airstream Convectio Oven
  • How to change lower element in DeLonghi Airstream Convectio Oven??
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Oct 28, 2017 | DeLonghi Ovens
    How do I get the door open after self cleaning and what do I push to self cleaning
    Hi, Some ovens are self cleaning During the cleaning process, the oven heats up to a temperature of 900 degrees Fahrenheit. The extreme heat cooks off food and spills inside the oven, leaving ash that can easily be wiped out. The oven door locks while it is cleaning to prevent the door from being opened. Self cleaning ovens are better insulated than regular ovens to keep the extreme heat inside.
    Instructions
    Read the owner's manual that came with your oven before you perform self cleaning. Although all self cleaning ovens work basically the same way, there may be slight variations for some manufacturers and models.
    Take out the oven racks. You need to clean the oven racks by hand, and then put them back in when the oven is done cleaning.
    Wipe up any spills and messes inside the oven first, using warm water and a mild soap. Ovens smoke more during cleaning when there is food inside. Wash the inside of the oven door as well. Do not scrub the door gaskets, just gently wipe them off. Damaging the gaskets prevents the oven from sealing.
    Lock your oven door manually if your model does not lock it automatically when you clean.
    Open a window near the oven for ventilation. There is a certain amount of smoke when you clean the oven. The dirtier the oven is, the more smoke is created.
    Turn the control on your oven to "clean" and set the timer for 2 to 5 hours depending on how dirty your oven is, and what the manufacturer recommends.
    Wait for the cleaning to finish and the oven to cool before opening door. When oven is fully cooled wipe up any ash inside. If your oven is not completely clean, next time set the timer for longer. If your oven is spotless you might want to see if you can get away with a shorter cleaning time.
    Tips & Warnings
    Because self cleaning ovens are better insulated, they are more energy efficient when used for cooking. However, if you run the self cleaning feature on your oven more than once a month, you offset the savings you realized. With light to moderate use your oven should be able to be cleaned every one to three months.
    Save on the electricity used with a self cleaning oven by cleaning the oven right after use at a high temperature. For example, if you set your oven to clean after making French fries at 450 degrees, it takes less energy to get the oven up to the required 900 degrees.
    If you have pet birds, take them out of the house before cleaning your oven. Over heated cooking surfaces, oils and fats, can create fumes that are harmful for a bird's delicate respiratory system.
    Hope it helped.
    May 28, 2011 | Ovens
    Oven Was Self Cleaning. Bottom Oven Opens Top Oven Does NOt
    Seems like you found out the hard way what I wrote about in this tip...
    Check it out it also contains some thing to try on how to unlock that oven..
    Self Cleaning Oven Problem
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
    Jun 21, 2010 | Whirlpool RBD305PD Electric Double Oven
    I have an older model double oven by Kenmore - probably 15-18 years old. I was baking bread in foil three days ago and the oven set on bake 325 degrees. (I had been cooking a roast in it for several hours...
    Hi.
    the oven may have locked in consequence of the self cleaning cycle.
    After unplugging, allow the oven cooling down for few hours.
    If the is still locked, then the high temperature generated in self cleaning cycle may have damaged temp probe, door latch, or electronic control.
    Parts must be tested to discover the fault.
    Call Kenmore at the number listed on the owners manual.
    Regards.
    Mar 03, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
    Dacor CPO230, can't get lock to engage for self cleaning. I follow step clean symbolcomes up door lock moves into locked position then beeping starts and the word door flashes and the lock opens up.
    For some reason the oven thinks you have a door that is not shut all of the way. Check the locking slot to make sure that there are no obstructions. Make sure that you are only doing one oven at a time, and not trying to cook in the other. Make sure you have no racks in the oven. Try pushing lightly on the door when the lock engages. For some reason your lock isn't engaging fully and that's why door is flashing. Good Luck
    Below is from the owners manual for your oven.
    Oven does not self-clean Door not shut tight Check for obstructions. Close door tightly
    Oven set for delay timed cleaning Oven will start to self-clean at preset time.
    Press CANCEL/SECURE to return to
    normal operation
    Double ovens only: Other oven is on. Turn off other oven.
    May 10, 2009 | Dacor ECD230 Epicure Electric Double Oven
    How can i quit cleaning oven?
    During the self clean cycle, oven temp will exceed 900 degrees F. At these temps, if you opened the door, the food inside would immediately catch on fire when the supply of oxygen hit it. When you turn your self clean cycle off, the oven door will remain locked until the internal temp drop below aprox. 550 degrees F for your safety. Once the oven cool below this temp, you will be able to start using the bake or broil again. This should be a Fix-Ya for your oven.
    Dec 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    F8 CODE IS FLASHING, OVEN BEEPING AND TOP OVEN DOOR IS LOCKED
    heatman101
    Dec 24, 2008 | Frigidaire 27 in. Electric Double...
    Kenmore self cleaning oven 362.75471691
    see to it the there was no stuck object or parts on the door parts...
    Sep 30, 2008 | Ovens
    Self cleaning oven directions
    Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
    Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
    Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
    153 people viewed this question
    Top Kenmore Ovens Experts
    Archie Ferrarini
    Archie Ferrarini
    Marvin
    Marvin
    Are you a Kenmore Oven Expert? Answer questions, earn points and help others
