Keyboard replacing for advent 7108
Sometime ago my daughter spilt something on her laptop, she took off all the keys and cleaned it up as much as she could. A couple of the keys still stick and some are missing. I know I can probably just replaced the keys but I'm wondering how easy would it be to take off the keyboard, give the underneath a good clean and then replace it with another keyboard.
Can anyone advise me?
How to replace the keybord on an advent 9517 laptop
Advent laptops are manufactured by DSG International, which owns the names to other name-brand computers such as Acer and Hewlett-Packard.
The Advent laptop keyboard has integrated mouse touch-pad functions that allow you to move the mouse around the screen with your fingers.
Function keys at the top of the board contain alternate ways to exit and enter software applications.
Function Keys
The Advent laptop keyboards function keys are "hot keys" that act as shortcuts to applications and functions on the computer. The function keys sometimes don't work and won't carry out the function assigned to the key. This problem is considered a hardware malfunction, and the solution is to replace the keyboard or use a universal serial bus (USB) keyboard for the laptop. b> Malfunctioning Keys b> Advent keyboards are made of thin plastic. Striking the keys too hard will cause the keys to break or stick awkwardly in the housing unit that supports the keyboard. When these keys get stuck in the housing unit, a pin tool can easily set the keys back on track. If there are too many keys that get stuck or broken, you can purchase a replacement Advent keyboard and have it installed. b> Mouse Problems b> The mouse is located at the bottom of the Advent keyboard but is connected to the keyboard data strip that sends information through the keyboard unit to move the mouse on the screen. If the mouse malfunctions, check the connector under the keyboard to see if it is loose. A loose connector can cause the mouse or other keys not to function on the laptop. b> Electrical Shortage b> An electrical shortage can cause an Advent keyboard not to work properly. A shortage is when the main board of the laptop is not getting the voltage needed to efficiently operate the computer. When this happens, certain devices underperform or become inoperable. Check to see if your power supply is extremely hot or if your system heats up around the keyboard. If so, replace the electrical adapter. b> Wire Damage From Keystrokes b> The wire that is responsible for the liquid crystal display (LCD) on the Advent laptop extends from under the middle of the keyboard to the LCD display unit. This wire is unprotected and can be damaged from striking the keys over the wire. When this happens, the display will not show the correct colors or the screen will go black. To eliminate this problem, purchase a keyboard cover that fits the keys to relieve the pressure between the keyboard and video cable. b> Keyboard Drivers b> Problems have been reported with upgrades from Windows Vista to Windows 7. Windows 7 will not recognize the system drivers that operate the Advent keyboard. To get the keyboard to work, you must load the old drivers in Windows 7 Safe mode, which is used anytime there is a hardware or software discrepancy. Advent keyboard drivers can be loaded from the original restore CD, which is included with the system at the time of purchase.
http://www.laptopkeyboard.com/Guides.php/Advent/Advent Series/9517 (Black)/KBAD3
Jan 29, 2013 | Computers & Internet
When I press 1 key it gives me 2 or 3 letters / numbers. i.e. when I press r I get f & r ,,
the keyboard is shorting. sounds to me like someone spilt something on the keyboard...
replacing the keyboard is the only thing that will fix this once this happens. Laptop kepboards are designed to be throw outs.
if this was a desktop i woudl say you coudl try cleaning the plastic boards but since it is a laptop you can get a replacement form ebay and usually decent priced.
Jul 29, 2011 | Compaq Keyboard
Spilt water on keyboard acer aspire 5542, while it was turned on, some keys have stopped Working. can this be fixed or does it need replaced?
Matthew.,
Before you declare the keyboard dead and unusable please do the following. Use the hairdryer without heat to blow cold air into the keyboard. This will remove all traces of water that may be shorting the keys. Do it for quite sometime as you have to ensure that there is no water left under the keys.
All the best
Mar 25, 2011 | Computers & Internet
Have a HP Pavillion 3163cl Entertainment Laptop and the Space Bar asks like someone is pressing down on it at all times. Like a stuck key and makes the noise when turning it on. The Laptop belongs to my...
To clean your laptop's keyboard you have to look under your laptop, you can see like keyboard icons with some scews, so, open them, they will let yout to remove your keyboard.
So now your can remove just your keyboard slowly for some connectors on the motherboard then clean it with a tooth brush.
You can only clean your keyboard with a toothbrush without rmoving it,
Try to remove the space bar key and clean under it.
Try to hard press the space bar for about 5 times, it can release the pusher under the key.
it some liquid was spilt on it you have to remove the keyboard and clean the plastic under ther keyboard.
Good luck
Jan 20, 2011 | Computers & Internet
Certain keys are creating double letter combinations e.g. typing "y" yields "hy", "i" creates "ki", "r" "fr", and "o" brings "o9". the shift key has stopped working. replaced batteries. took off key caps...
i think maybe some of your keys are stuck together. have you spilt something on it or is there a load of debris underneath keys if so just give it a wipe to clean it or blow on the keys to remove debris
Sep 26, 2009 | Dell 0Y3740 Keyboard
My advent 7108 had the blue screen followed by the white screen
it is Hard disk problem. pls replaced it & installed os again.
Aug 21, 2009 | Acer Aspire 4720 Notebook
Avent Laptop 1115C Replacement keyboard
I have the same problem replacements arent cheap though www.adventspares.co.uk £39 +vat apparently part number is 71GL51082-21 hope this helps
Jun 02, 2009 | Recoton Advent Advent Q2035A 20" TV
HP 530 Laptop, NO Power
Um apart from growling at the dog lol you will probably need a new keyboard section.
Apr 25, 2009 | HP 530 Notebook PC
Keys are sticking the keyboard. Can i clean underneath the keys?
Depending upon how sticky the keys are, it might be easier to buy a cheap replacement keyboard.  Trust me, it takes a whole lot of patience and a steady hand to take apart the keyboard key by key and then put it back together.
Mar 09, 2009 | Toshiba Computers & Internet
Replacing keyboard for advent 7108 laptop
I have had the same problem several times over and it is VERY likely that the liquid has reached other components (specifically the motherboard) and will corrode anything that the liquid has come to rest on. The keyboard itself is easy enough to remove and replace, but the only place I am finding parts for advents is in the UK. This means replacement of the keyboard COULD be costly and in the long run the computer may fail due to corrosion especially if it was pop or juice or any other acidic liquid. Here is the link I found for a possible solution.  http:/www.adventspares.co.uk  if they dont have it, these guys might... http://www.techno-mart.co.uk/advent.html
Good luck, and I hope you havent damaged your motherboard! Kirk
Jan 30, 2009 | Computers & Internet
Computers & Internet Logo
215 people viewed this question
David Payne
David Payne
