Notes, diagram on frequency modulation - Computers & Internet
  • pklinuxguru
    pklinuxguru May 11, 2010
    Please clarify what you want. Do you have documents you can't open or modify? Lotus Notes? What does "frequency modulation" have to do with your problem?
    President:
  • 2,692 Answers
Type in "Diagrams on frequency modulation" into google search. and you will get many hits like the one below:
http://www.music.mcgill.ca/~gary/307/week8/node14.html
Posted on Jan 30, 2009
What is code 64 as a error message
Error 64,65,66 are related to the same problem
64. (01000000) Phase 5 and 6 - Pressure Transducer (Ptx) error frequency < 66kHz
The Motor Controller module has received signals from the water level sensor (Ptx)
below normal frequency values.
Primary Source: Motor controller module.
Action: Replace Motor Controller module.
65. (01000001) Phase 5 and 6 - Pressure Transducer (Ptx) error frequency > 90kHz
above normal frequency values.
Primary Source: Motor Controller module.
Action:Replace Motor Controller module.
66. (01000001) Pressure Transducer Error [Ptx
Frequency > 90 kHz
Aug 03, 2014 | Fisher and Paykel Washing Machines
I have a fisher and paykell GW712 washing machine that has the 2 green light and 7 red light flashing and beeping after turning on at power point.after pushing buttons 4 or 5 times and turning the power on...
The second light and the seventh light on and beeping is fault 66.
This is info on fault 66.
66. (01000010) Phase 6 - Pressure Transducer (Ptx)
Error - Frequency > 90 kHz
Note: this supersedes Fault code 65 from V41 Motor Control Module
code onwards.
The Motor Control Module has received signals from the water level
sensor (Ptx) above normal frequency values.
Primary Source: Motor Control Module.
Action: Replace Motor Control Module.
Oct 07, 2013 | Fisher Paykel EcoSmart GWL15
Lights 2 and 7 and constant beeping
Error code 66 is water pressure sensor.
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
Primary Source: Motor Control module
Action: Replace Motor Control module
Dec 06, 2012 | Fisher and Paykel GWL11 Top Load Washer
Needs service code 66
The pressure sensor is faulty and needs a new/good secondhand one
You can get one from an old dead board,
But it needs to be calibrated to that board.
To calibrate the new one set machine to fill to low water level,
The plastic hex with red on it needs to be turned up to raise & down to lower the water level.1/8inch of a turn will adjust water by 15 to 20mm.
Jun 17, 2012 | Fisher and Paykel Washing Machines
Jun 17, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
Gw712
code onwards.
Apr 22, 2012 | Fisher Paykel EcoSmart GWL15
MW511. 2 & 7 lights flash, beeping. No agitate or spin?
Fault code 66 is pressure sensor is faulty
Apr 20, 2012 | Fisher and Paykel Washing Machines
Machine says "I need service"
I took this from the service repair manual. Hope it helps.
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66. On some machines the pressure switch is seperated and sometimes the plastic tub for the switch gets clogged up and blowing through it will sometims clear this fault. Not sure about this particular machine, but you can try adjusting water level to see if it will work at a different level of water.
Mar 24, 2011 | Fisher and Paykel (IWL12)
Need crossreference wiring on a 2008 dodge charger and aftermarket alarm
This link will get you 2007 which should be same. Good Luck.
http://www.the12volt.com/installbay/uploads/2007DodgeCharger.txt
Nov 03, 2010 | Dodge Charger Cars & Trucks
Pioneer GEX-FM903XM, system works great, however it often drops out and has just static. The signal indicator is strong. I think there is a bad connection into the radio. Where should I start...
It may be possible that the FM frequency chosen during setup, is in use in your area by a strong signal from a local station. Change to another frequency and see if the situation improves.
The following is from the Operation's Manual:
FM Modulator Setting
You can adjust FM Modulator frequency and output level.
7 Frequency
If output from the FM Modulator is hard to hear due to interference from a strong broadcast
station transmission, you can switch to another frequency.
You can adjust frequency between 87.9 and 90.1MHz.
7 Level
If the output sound is too quiet, too loud or distorted, you can adjust FM Modulator output
level.
You can adjust level between “LEVEL–1” and “LEVEL–7”.
1. Press the POWER button for 2 seconds to enter the FM Modulator Setting
mode.
2. Select the desired frequency
with the left/right arrow buttons.
3. Increase or decrease the Level
with the up/down arrows (buttons).
4. To cancel the FM Modulator Setting mode, press the POWER button again
for 2 seconds.
Note:
• After entering the FM Modulator Setting mode, if you do not perform an operation within about 8 seconds, the FM Modulator Setting is automatically canceled.
Nov 29, 2008 | Pioneer Car Audio & Video
Computers & Internet Logo
123 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
