Question about Brookstone Pure-Ion (506840) Air Purifier
Just stopped working
I just finished cleaning the filters but while they were cleaning someone unplugged the unit. Now it does not work at all. Is there a reset somewhere or do I need to get it serviced?
  • 1 more comment
  • Anonymous Nov 13, 2007
    I too have had the same problem. I  put the filters back in and then turned it on and the lights started to go through all the indicators, and then the fan came on but no turning left to right
  • Anonymous Dec 19, 2007
    After cleaning the filters and plugging back in.... the unit fans work
    but it does not oscillate. The lights dim and brighten like there is
    some short inside. After 5 months of use, it is still under warranty.
    The same model is not offered. Brookstone will pick it up and refund
    or replace with the new model for $30.
  • Anonymous Mar 10, 2008
    Mine just died on me. I cleaned the filter as usual and it was working through the night. When i woke up, it was off and ***** came back on.
    New Friend:
Every time deler charge the service for replacing cliner after this problem
Posted on Jun 23, 2013
Exactly the same thing happened to me. I get ** response from the unit. I may need to get it serviced from a local electrician as Brookstone is **t helping me.
Posted on Mar 10, 2008
Honeywell Air Cleaner
Is the filter clean?
Are the ionizing wires clean? gently wiping them with 600 grit finishing paper should clean them up and restore perfomrance.
Is unit bent? If so it may be shorting out.
is unit fully seated and making contact?
Jan 31, 2012 | Honeywell FC37A1064 Air Purifier
Shortly after I turn on the sanitizer on the machine, it turns itself off (the whole machine). Does it need to be cleaned?? What type of solution do I clean the boards in??
Remove the plaques and using an old tooth brush clean with mild soap and water.. Rinse thoroughly, towel dry and finish drying them with blow drier. The interior of the unit and it's filter should also be cleaned. Depending on what type filer it uses (Aluminum mesh or soft mesh plastic) they too and can be washed with mild soap and water, rinsed and thoroughly dried. Any other type filter material may need to be replaced. Clean the interior with canned compressed air with a straw nozzle and a dry paper towel.
Of course, before you do any of the above, unplug the unit.
Mar 02, 2011 | Ecoquest Breeze AT Living Air Purifier
It doesnt work when you plug it in, no sound.the fan does not come on. what can i check to see if it is suposed to work?
There's a reset button on the bag of the unit, as well as a replaceable fuse (if necessary). But before trying all of that, check to make sure that the screen on the back is installed properly. There is a tab on the right side, at the bottom of the filter. If that is not tripping or pushing in the built-in contact, nothing will work. It's a safety switch for when you remove the filter regularly to clean it. Cleaning is simple .. just back flush with warm water in the kitchen sink. Then fold a towel around it to capture most of the water and use a blow drier to finish the job.
Feb 05, 2011 | Ecoquest Living Air Classic Air Purifier
When clean the filter in one hour the machine stop and i need clean back
clean the metal filter grid blades with a long strip of scotch brite pad and also clean the corona wires in the back of the unit very gently with light grade sandpaper. i had this problem and tried cleaning my unit so many times that i was ready to toss it into the trash. now it works normally. i did some spray painting in the room where the unit was operating and believe it picked up a coating of paint causing the sparking. good luck!
Jul 22, 2010 | Sharper Image Hybrid GP (SI724) Air...
Our Eco-Quest Breeze no longer works. I cleaned
I've seen several like that and found the wire connections corroded off. Easy to fix if that's the case. Make sure the unit is UNplugged before taking it apart.
Sep 03, 2009 | Air Purifiers
How to troubleshoot a Pure Ion #AP-75 non-working
My ionair cleaner doesn't clean the air what so ever. All four filters are perfectly clean after running for over two months. All of them are properly inserted and seated as specified. No filter warnings turn on and the unit works in all other ways. There is an ongoing fire in the hills nearby and our house if full of hazy smoke.
Aug 08, 2009 | Brookstone Pure-Ion UV Air Purifier
The Kenmore air filter will not turn on.
Check the switch and make sure that it is getting power. You can also disconnect the connectors to the swiitch plug the unit back in and touch them together if that works then you know the switch is bad
Feb 14, 2009 | Kenmore EnviroSense 85501 Air Purifier
Brookstone Pure-ion Advanced
i am a low voltage tech my wife told me that our 506840 air cleaner stopped working so being a tech geek i had to know why it just stopped working.when plugged in i heard a click telling me that the main board was getting power.opened the back end where power cord goes to put my meter and voltage was going to the main power coil. but the main board was oxidized. when my wife was cleaning the filters and might not have had the filters completely dried the water was dripping down to main board.the unit to main power source is not design very well where water from cleaning the filters can drip down to main power board.solution i am working on is trying to get a new board when we bought this it was $499.00
Oct 15, 2008 | Brookstone Pure-Ion (506840) Air Purifier
Clean Filter Red light
I cleaned the filters as well earlier and the red filter light still blincked to clean the filters. Then I pushed the power button for about 10 seconds continously and then turned it on and the light turned off.
May 22, 2008 | Brookstone Pure-Ion UV Air Purifier
Wont run after I cleaned it
On the model 30200 there is a safety interlock switch actuated by a plastic tab (about 4" down from the top of the front filter cover) on the right side. Assuming that all you did was take off the front cover and clean or replace the filter(s) and the unit was working previously, this should be your answer. If in taking off the cover the switch actuation tab was broken off, you could (carefully) wedge a tab into the slot where the switch resides. This defeats the safety aspect of certifying that the unit isn't running when you remove the cover. The safe work-around is to unplug the unit before you open it for service.
Feb 09, 2008 | Hunter 30200 \ 30010 (Set) Air Purifier
Brookstone Pure-Ion  (506840) Air Purifier Logo
392 people viewed this question
Top Brookstone Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Brookstone Air Purifier Expert? Answer questions, earn points and help others
