SOURCE: coil pack keeps going bad,
Your problem sounds like an intermittent short in the power feed to the coil pack from the EEC module
SOURCE: need a diagram of the firing order of spark plug wires from coil packs to spark plugs
FROM LEFT TO RIGHT, 5/2 3/6 4/1. ASSUMING YOU HAVE THE 3.1L ENGINE.
SOURCE: 1997 CAMARO TURNS OVER BUTVWONT
the icm, coil, and crank sensor all read off the opti. Chances are you have a bad optispark (distributor). I just went thru the same issue and found it to be the problem.
check your fuel pressure as well, you may have anissue with your fuel pump and or relay
