I am getting an error read on my CD player. The CD Disc CD player (original) to my 2003 Experdition will not release CDs. The CD player which is an automatic feed was force fed a CD by a minor child. The Radio still works fine. Is there a way to pull the player from the dash and replace it after the OFFENDING CD has been removed. Is there a tool to use that will not damage dash or machine?
? 5:15
https://www.youtube.com/watch?v=pH33UZveLYI
Jun 24, 2013 - Uploaded by Shyzah
How to fix a boombox CD player when it wont play .... My box reads "no disc", but it is in proper position ...
CD Errors · E20 or CHECK CD : Cause(s): The CD player cannot focus on the disc or there is an internal focus problem. Correction(s): Try cleaning the disc or using a new disc. Make sure the disc is loaded correctly. The road could be too rough or there is too much humidity.
If your player is an AC Delco giving you the e20 error and only on your burnt discs the lens is probably not shot. It's just very dirty and can only read professional grade CDs. The remedy is to open the CD player and clean the disc with 70% Isopropyl Alcohol.
You will need a small adjustable wrench or ratchet set as well as a T-7 torx bit. You only need to remove the bottom of the player and the front piece in order to get to the CD player inside. Unscrewing other screws will just lead to having to more to reassemble. Once you get to the heart of the CD player you will need to release it by unscrewing the torx screws and then turning the player over and you will see the lens. Put some alcohol on a q tip and gently rub the lens a few times. then reverse all disassembly and put the player back together.
When you reinstall the CD player it should play all of your CDs
ALSO be sure to disconnect the negative in the battery before removing any electric devices to prevent short circuiting. And only reconnect it after you have reinstalled the CD player.
you might want to just take the factory cd player out and put a after market one in cause thats what i had to do on mine casue it costs way to much to get the original one replaced
Well if the unit came with car over 10 years old, u can't clean it might have to just replace. buying a new one will cost as much as trying to fix that one.
From Tiburon owners manual: Er6 - DISC ERROR - CHECK IF THE DISC IS INSERTED CORRECTLY IN THE CD PLAYER. MAKE SURE THE DISC IS NOT SCRATCHED OR DAMAGED.
i have a infiniti i-35 2002 and my cd player won't play or eject i was switching cd's on no. 4 and when it went in it got stuck inside it won't play no. 1thru6 are there any suggestions
