Access code need to know how to get into the admin panel of bizhub c350. moved it from one location to another and have not used it in about 6 months need to get it to work with new computers
    Scholar:
  • 177 Answers
HI YOU CANGET INTO IT BY 12345678 OR EIGHT ZEROS IF THIS DOES NOT WORK YOU CAN RESET IT BY USING 92729272
GOOD LUCK
Posted on Apr 19, 2012
    Problem Solver:
  • 5 Answers
It can be one of 4 passwords
0000
00000000
1234
12345678
I hope this helps
Posted on Jan 30, 2009
I ave problem on c350 error code 2160
BIZHUB C350 SHOWING ERROR CODE C-0900 AND
NOW C-0950
Sep 30, 2013 | Konica Minolta Bizhub C350 Digital Copier,...
Konica minolta bizhub c350 error codes c-0510
eror code c-0098 meaning ??????????????pls tell me the solution
Jul 31, 2012 | Konica Minolta Bizhub C350 Digital Copier,...
How do you clear error code on a bizhub C350. A piece of paper was fused on the fuser unit and we were able to get the paper off. Now we have no access because the panel is locked.
while powering up machine hold down utility/counter key until trouble reset appears on screen. select it and ok should apper under it. power down machine for atleast 10 sec and turn machine back on.
Jul 22, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Minolta c350 password admin
Hi Hamdaoui33,
The admin password should be 1 2 3 4 5 6 7 8
but I'd also try 0 0 0 0 0 0 0 0
Unless someone has changed it from factory setting
Regards
M-PRESS.BIZ
Feb 19, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Malfunction detected error code c 001a on minolta bizhub c350
Im thinking either it was moved improperly and the image units werent kept level, or maybe just sitting to long caused them to settle in. try (gently) removing the IU's and shaking them (keep them level) in order to unclog or redistribute the developer inside. (imagine sand in a horizontal tube. It has to be uniform all the way accoss the tube, and not settled into any one location)
May 28, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Bizhub Password Reset
You can try the default admin password which is 12345678
Mar 24, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub C350 Malfunction Code C-0510
I have this malfunction code, C-11A3, coming up on my Konica/Minolta Bizhub 350 copier/printer. Anyone know what it is? I don't use the techs, because they charge much I don't pay for the service anymore-seems like most things should be able to be fixed by the owner. I needed help for this code
Mar 21, 2009 | Konica Minolta bizhub C250 All-In-One...
ERROR CODE C0096 - BIZHUB C350
2.6.19 C0096: Image Transfer Belt pressure/retraction failure
2.6.20 C0098: Fusing Pressure Roller pressure/retraction failure
Relevant Electrical Parts
1st Image Transfer Retraction Position Sensor (PC12)
1st Image Transfer Pressure/Retraction Motor (M11)
Control Board (PWB-MC)
Step Action
WIRING DIAGRAM
Control Signal
Location
(Electrical
Component)
Check the M11 connector for proper connection
and correct as necessary.
2 PC12 I/O check PWB-MC PJ3MC-6B (ON) 6-B
M11 operation check PWB-MC PJ5MC-1~4
(Pulse Output)
6-C
4 Change PWB-MC
Feb 18, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Erroe code
You post a wrong printer nr, you must have bizhub C350 not bizhub 350, beacause 350 doesnt have that kind of code.
In Bizhub C350 that code means:
C12C0: Hard disk recognition error
You have the following options:
- reinstall the hard disk
- change hard disk
or as a last chance change PWB-MFP
good luck
Feb 06, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
337 people viewed this question
jasbo
jasbo
