Question about Ricoh FAX3900L Plain Paper Laser
Repair CombBind C450e binding machine
Our office uses this machine extensively and it is in need of repair. I cannot seem to locate anyone in the concord, nh area to do this.
  • Anonymous Mar 06, 2009
    MY MACHINE IS THE C800PRO, ALSO MADE BY COMBBIND, AND NEEDING REPAIR.
3 Suggested Answers
aquaman987
  • 927 Answers
SOURCE: Combbind c450e orange light showing
I looked this up and found the owners manual. It shows the trash tray or bin and says to empty it. I assume that you did that already. Apparently there is a switch of some sort that monitors that area of the machine. If unplugging the machine electrically doesn't reset the light, I would call:
(800) 989-4923.
(In Canada: (800) 268-3447)
Gary
Posted on Feb 06, 2011
SOURCE: CombBind C450e binding machine.
the top is connected with 7 star shaped screws look in the back of the machine you will see the exact shape. in the back there are 3 screws then there are 2 more screws on every side under the dark grey lable on is located on the very bottom (lift the lable you will find it) to find the other 2 slide your finger on the grey lable you will feel a small round hole on the right side it is about a cm under the **** where the papers get punched and on the left side it is about 3 - 4 inches under that ****. Good luck
Posted on Mar 01, 2011
Who can I call for service on gbc proclick p210e
Depends whats wrong with it. Can you provide more info and your basic location . In the meantime, check the manual for trouble shooting
https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0ahUKEwiV_cj0q9zKAhXCFz4KHdadCyUQFggrMAM&url=https%3A%2F%2Fwww.mybinding.com%2Fmedia%2Fmanuals%2Fgbc-proclick-p110-p210e-manual.pdf&usg=AFQjCNHgnkPfSIhq-J77l1TaxA60gQkm3g&cad=rja
Feb 03, 2016 | Gbc ® ProClick P210E Electric Comb Binding...
Serger clanking/binding?
Well first of all STOP SEWING until you have this resolved. open up the door to the loopers and hand turn the wheel while you observe carefully what it's doing. Feel for any binding as you turn the wheel while noting where the loopers are. If you find some binding or clunking Gently wiggle the loopers to check for play or slop. Everything look ok? ... If you are not mechancially inclined... please take it back and tell the guy it's worse than before (meaning he didn't repair it) Ask him to fix it properly this time on his dime.
Cutting a pin could have knocked it out of time.... if that is the case you should fess up and pay to have it timed.
Sep 06, 2012 | Simplicity Serge Pro SW432 Mechanical...
Hi, I want to load a word doc using the .doc extension from my samsung galaxy phone but this phone uses a .docx extension & it is not recognised. Does anyone know how to do this?
doc extension is for microsoft office 2003 and docx extension is for microsoft office 2007, so try to convert from doc to docx
May 09, 2011 | Cell Phones
Unibind machine will not heat. Does heat if turned upside down. Can it be fixed?
I think it can be fixed. It appears that there is some kind of loosing inside the machine and when the machine is turned upside down it heats up because the electrical contact is made. If you can work inside such electronics, you may try to fix. IF NOT DONT TRY IT (there is a danger of electrical shock). Instead you may refer any repair/ service professional .
Hope it helps! Good Luck!
CreativeTECH
Apr 19, 2011 | Unibind UNB25182US00W2 Binding Machine,...
CombBind C450e binding machine. How did I get the top off? A piece fell off inside and I cannot get the top off.
Aug 27, 2010 | Ricoh FAX3900L Plain Paper Laser
How do I open up the binding machine to see what's going on?
often the stickers will be concealing screws under them
move a screw driver over the stickers and see if it pushes in anywhere and if so make a hole there :-)
May 05, 2009 | Office Equipment & Supplies
Are we able to get the Binding machine blades sharpened. We have an Ibico, Ibimatic-No 315468. Have had for about 5 years. Thanks
This product is now manufactured by GBC (General Binding Corp, part of Acco) and was replaced by the CombBind C150 - just FYI. The lower-end machines such as this seem to run in the range of $200 USD.
I have never heard of sharpening these "blades", as they are actually punches, and there are likely some 20 small, individual "blades" that are part of the system. You might check with a local dealer or office supply partner, to see if they know of anyone who could or would perform the service and what they might charge for it. I believe that if you could find someone to do it, it would cost more than it would to simply replace the machine. There does not appear to be a way to replace the punch mechanism (die / strip usually) in these models.
An example of a machine with interchangeable dies is located at: http://www.factory-express.com/Binding_Machines/WireBindingMachines/GBC-TL2900/GBC-wirebind-TL2900.html.
Obviously, this is a much higher-level (expensive) machine than the one you have here. But this is an example of the interchange concept, and associated costs.
So, this is a rather long way of saying, and trying to explain why I recommend that, you check with a local dealer perhaps, but plan to replace the machine. If it lasted you this long, the same level of machine should last just as well, and $40 US a year isn't too bad!
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Jun 29, 2008 | Office Equipment & Supplies
Why do we always have to click repair
What the repair option does is more or less disable and then enable the network connection to refresh the systems settings. This article explains what exactly it does: http://www2.lut.fi/atk/palvelut/PCTUKI/Windows/XP/Repair_NetWork_Conn.html ? Attempts to renew the DHCP lease, if the connection obtains its IP address through DHCP, using a broadcast message. ? Flushes the Address Resolution Protocol (ARP) cache using the command arp -d * ? Flushes the NetBIOS cache using the command nbtstat -R ? Flushes the DNS cache using the command ipconfig /flushdns ? Reregisters the NetBIOS name and IP address with WINS using the command nbtstat -RR ? Reregisters the computer name and IP address with DNS using the command ipconfig /registerdns So if this is what is being done, lets try to trouble shoot each symptom and see what resolves it. My first inclination would be to check your DHCP scope on your server, and see if your scope is running out of space. Also check the lease length and see if it is set to a small amoutn of time. Your PCs could be losing their IP addresses and thus need to get new ones all the time. Are you pinging by IP or name. I would do most of the ping tests by IP as that would remove any of the name resolution issues you may be encountering. Is the wireless brindge doing any type of mac-address or arp filtering? Also, can machines in the extension always ping each other constantly? This would help narrow down the problem to see if it is an IP problem on the hosts or a possible network equipment issue.
Sep 21, 2006 | HP Broadcom NetXtreme 10/100/1000 Network...
Ricoh FAX3900L Plain Paper Laser Logo
572 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
