Question about Garden
Power drive engage / diengage problem
The power drive sometimes will not engage, or once engaged will not dis-engage unless i pick up the rear of mower & ''bump'' it on ground. is this a case of ''stretched out'' cable from the engagement handle? Have readjusted this several times. It seems to work for a while. The drive gears do not appear to be worn.
  • stretch226 Jan 31, 2009
    Mr. fixit-jerr. Thanks for the come back - it may be a sticking cable problem. Have used WD40 on the cable, have adjusted the length several times, It is a Honda HRM215 which has been an excellent mower, except for the clutch engagement problem.
5 Suggested Answers
SOURCE: hummer h2 transfer case
Only way for this to happen on an H2 (AWD) is for something to break rearward of the lockup hub. Take a look at the splines between the intermediate shaft and centerdifferential or even the teeth on the forward sun gear and/or stepped pinion on the center diff.
As long as you have the t-case torn down for repair be sure to upgrade to the new aluminum mode fork (production upgrade to old plastic forks thru end of 2007 or so). You should also upgrade the rear half of the housing to the 2008 version which has a pressed-in rear prop bushing (better bushing and is also replaceable.
Posted on Sep 30, 2008
  • 48 Answers
SOURCE: The front wheels on my lawn mower have locked
on yours you must replace the entire tranny unit - to make it roll you can remove the front wheels and remove the small gear on both sides - doing this of course will turn it into a push mower not self propel
Posted on Oct 21, 2008
MrScary66613
  • 1990 Answers
SOURCE: 01 chevy silverado4x4 transfewr case
Changing the Fluid would help But, It will not solve the Problem. It sounds like you may have a Broken tooth on a Gear inside the Transfer Case. The only real way to fix this is to Take the Transfer Case off and check the Gears and Electronics. Maybe even get it Overhauled.
Posted on Jan 24, 2009
  • 86 Answers
SOURCE: rear wheel drive on mower does not engage
Its possible that the cable slipped does the pulley turn on top of trans.if so does the shaft turn if so then your gears on wheels need cleaned or replaced.
Posted on May 11, 2009
  • 4 Answers
I had this same issue. In my case, the sheild that keeps the dirt out of the gears in the wheel has gotten broke and the gears filled with junk and jammed the wheels. I just have to take the wheels off and blow the junk off the gears.
Posted on Jun 07, 2009
My timecutter 1642 Z only goes around in circles. Is there a straightforward fix for the drive motors short of replacing it?
by chance did you open the dump valve or is the brake not dis-engaging ??? they use a common belt so that's not the issue UNLESS your tensioner arm is locked in place...
Oct 20, 2014 | Garden
How to adjust 95 geo tracker clutch
engaging?
you meant dis-engage im sure.
pedal up is engaged,
pedal at floor dis-engages it.
my guess, is the clutch drags unless i push the clutch pedal 100%
to the floor.
1: bad cable is 90% cause. non last this long.
2: no free play is way too loose.
3: broken lever on the pedal top. caused by #1
all fail modes covered here.
http://www.fixkick.com/tranny/clutch/clutch-on-kick.html
Apr 23, 2014 | Geo Tracker Cars & Trucks
When testing starter out of truck works fine, put starter in truck and under load starter stays engaged, rip
Either the solenoid is getting power when it should not be, or the starter drive is not aligned with the flywheel.
Jan 18, 2014 | Cars & Trucks
My rear differential is broken and i would like to engage my front wheels so i can just drive with them. the car is headed for the junk yard im just trying to get a few more weeks out of it. it has smart...
what you are describing can't be done-unless-no -the rear drive shaft will still drive the rear wheels-smart track ain't so smart. you could drop the rear drive shaft out but then you'd leak trany fluid all out the tailshaft-why not pick up rear end at the junkyard and install-cheers Denny
Oct 31, 2013 | 1999 Oldsmobile Bravada
I changed the bad resistor. Now when I turn it on, the relay engages, standby light flashes 5 times and then the relay dis-engages. Powers off. Where do I look next?
Check the three CRT drive boards one of the video ICs may be out or you could have a shorted CRT. I would try removing one CRT drive board at a time and see if the set will power up and run with the one Drive board unplugged. That will let you know which CRT has an issue if its CRT related. If that doesnt allow the set to power up then the A board would be suspect
Jul 02, 2011 | Sony Grand WEGA KDP-57WS655 57" Rear...
Not a problem as much as an answer. Are both wheels rear wheels engaged at all times on my 4x4 87 ranger?
this is a rear wheel drive vehicle and as such the rear wheels are always engaged.when in 4 wheel drive the transfer case in gages and the front differential connects and is engaged.unless the 4 wheel drive is engaged the transfer case just free wheels.
Apr 27, 2011 | 1987 Ford Ranger
How to disable all wheel drive in jeep grand cherokee 4.7 2004
From what I know about that system I don't think you can without possibly damaging the transfer case and, I don't think you really need to. The way the system works, the front wheels are not really engaged unless the transfer case "sees" slippage or a dis-similar turning speed between front and rear wheels (why it's important to keep all tires exactly the same in size, brand and tread depth) when it sees a difference a coupler inside the case heats up and makes the engagement. On dry ground, there is no slippage and the unit remains in two wheel drive.
Therefore, I'd leave it alone.
May 14, 2010 | 2004 Jeep Grand Cherokee
98 forester awd rear wheels not engaging runs fine other wise drive shafts, axles all in good shape no noises in drive train. no codes,no check engine light on
Just a thought, Check under bonnett on passenger side is a fuse that when installed dis-engages the rear drive. Remove the fuse to engage the rear drive. Sometimes people see the open fuse holder and fill the slot thinking it is missing. Truth is it is only for short towing. Good luck and have a great day.
Jan 18, 2010 | 1998 Subaru Forester
Can i disable the 4 wheel drive from the dash console or do i have to pull the fuse as well?
depends if its a auto 4x4 or regular.if the button on the dash says auto the vehicle uses inputs from the speed sencors to engage the front when it detects slippage. if its s standard 4x4 there is a specific way you have to follow to engage and diengage the unit. read your owners manual
Oct 11, 2009 | 2003 Ford Explorer
1995 dodge caravan 3.0l starts but starter does not diengage
If that starter is damaged then replace it and make sure that you shim the starter correctly or it will bind the gears and do the same thing again.
Mar 16, 2009 | 1995 Dodge Caravan
Garden Logo
109 people viewed this question
Top Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
