Question about HP Officejet Pro L7680 All-In-One Printer
Operates fine, than all of a sudden, the printer disappears.
It can not be found when the printer dialog box opens and it is nolonger in the Printer/Fax folder on the control panel.
The Microsoft image writer is now shown as the default printer. After install, it works fine for a few hours and it disappears again.
The problem started 2 days ago, after 3 months of normal operation.
  • vciufia Feb 20, 2009
    The suggestion was right on target! Everyting is now working fine.
    I did not install all of the software the last time around, as the HP Solution Center was a continual problem. I believe that there was a conflict either with Windows XP and/or Adobe Photoshop on which program was going to handle scanned images.
    The HP printers are great. Hower, in my opinion, their software leaves much to be desired.
  • HP Master
  • 419 Answers
That sounds a lot like the driver software is unsuccessful in installing or you have something like anti-virus or anti-spyware that is stopping the installation from completing all it's stages successfully.
Try downloading the latest version of the software then disconnecting from the internet before temporarily disabling your anti-virus and anti-spyware software and THEN installing the driver again.
As a general rule it's better to have the printer unplugged from the computer while you do this and then plug in when prompted...
The computer will want to reboot and finish the install so do this when prompted and make a note of any errors you receive if you get any.
Hope this helps.
Posted on Feb 17, 2009
  • Martin Smallridge
    Martin Smallridge Feb 20, 2009
    LOL... You're not wrong about the software... I find myself desiring a clue stick and the opportunity to apply it to their software developers... Glad it helped.
How do I align heads on my Canon MG2200
Step 1 Ensure the printer and computer are turned on and connected.
Step 2 Locate the printer utility program by clicking on the printer's desktop icon if present. If it is not, click Start and type the printer make or model into the search box. When the printer utility program is displayed, click the program name to open the utility dialog box.
Step 3 Locate the "Maintenance" tab at the top of the printer dialog box and click to view contents. If the tab cannot be found, the maintenance screen can be accessed by clicking on various buttons (Advanced, Tools or Properties) and subsequently searching the dialog boxes to locate the maintenance button or tab.
Step 4 Click "Align Print Heads" or a similarly-phrased button.
Step 5 Click "Print Alignment Page" to yield a test page printed with a numbered series of vertical bars in various colors. Click "OK" or "Finished" to open the next instructional dialog box.
Step 6 Inspect the page, choosing bars from each color group with the sharpest image, and enter the corresponding numbers into the text fields for each color. Click "OK" or "Finished" to begin the automated alignment procedure. The printer adjusts cartridges based on the numbers you've entered. When the process is completed, you may click "Finish" to close the window and process, or print a test page featuring detailed shapes and lines of varying colors to further inspect. Click "Finish" to exit or "Repeat Alignment" to further adjust cartridges.
Jan 31, 2015 | Canon Office Equipment & Supplies
How do i do a print aligennment on a hp deskjet 6540
The printer automatically aligns the print cartridges after a new print cartridge is installed. You can also align the print cartridges at other times to ensure optimal print quality.
To align print cartridges:
1. Load letter-size or A4-size plain white paper in the In tray.
2. Open the printer Toolbox.
3. Click Align the Device.
4. Click Align , and then follow the onscreen instructions
Here are directions for how to open the printer Toolbox, in case you don't know:
The printer Toolbox contains a number of useful tools to enhance the printer performance.
Use the printer tools to perform the following tasks:
• Set the Auto-off function
• Clean the print cartridges
• Align the print cartridges
• Calibrate color
• Print a test page
• View estimated ink levels
To use the tools, open the Printer Properties dialog box, click the Services tab, and
then click the Service this device button.
AND, in case you don't know how to open the Printer Properties dialog box, here you go! :
The Printer Properties dialog box is also referred to as the Printer Preferences dialog box.
Opening the Printer Properties dialog box
Follow these steps to open the Printer Properties dialog box:
1. Open the file that you want to print.
2. Click File , click Print , and then click Properties or Preferences.
Good luck to you! I hope this helps.
Aug 07, 2014 | HP DeskJet 6540 InkJet Printer
Canon ip4500 problematic with win 64bit - seeking solution
Go to a 64-bit machine on the network and copy the 64-bit driver files to the machine
From the 64-bit machine, open Windows Explorer and browse to the 32-bit server
Open the Printers dialog seen via Windows Explorer.
From the Menu bar, select File > Server Properties, select the Drivers tab and click the Add button.
In the Add Driver Wizard, tick the x64 Processor checkbox, and untick the x86 checkbox.
Click Next, then click Have Disk and browse to the 64-bit driver on the local 64-bit machine.
Complete the Add Driver Wizard.
for more help visit CBR Tech Solutions
Dec 07, 2012 | Canon Pixma iP4500 InkJet Printer
Printer is not scan but some problem she has. Error in scannor Turn off scannor and follow instructions ni manual. Scannor drive will closed. Code : 61,213,0 I want to new setup Canon PIXMA MP160...
  1. Select 'Program' (for Windows 2000/Me/98), or 'All Programs' (for Windows XP) from the Start menu.
  2. Select the name of the printer model to remove and select 'Uninstall.'
  3. When the MP Drivers Uninstaller window is displayed, click 'Perform.'
  4. When the confirmation window is displayed, click 'Yes.'
  5. When the Uninstallation Complete window is displayed, click 'Complete.'
  6. Reinstall the drivers.
Reinstall the Drivers
Note:
  • The MP drivers can be installed using Easy Install or Custom Install.
    Easy Install automatically installs the software which is in the CD-ROM.
    This method is recommended for first-time users.
    Custom Install allows you to select the software programs from MP Drivers, Application Software, and On-screen Manual.
  • Login as a user with Administrator privileges to install on WindowsXP/2000.
  • Close any antivirus software that may be running prior to installing the drivers.
  1. Turn off the printer and disconnect the cable connecting the computer and the printer.
  2. Insert CD-ROM in the computer. (The CD-ROM will start automatically and the following window will be displayed on the screen.)
    1. If setup does not start automatically, click 'Start' and then 'Run'.
    2. At the Run window, type x:\msetup4.exe (where x is your computer's CD drive) in Open box and then click 'OK'.
  3. At the main installation window, click 'Easy Install' or 'Custom Install'.
    When selecting Easy Install:
    (A) Click 'Easy Install'.
    (B) Click 'Install' in the following window.
    * Display varies according to the printer model.
    When selecting Custom Install:
    (A) Click 'Custom Install'.
    (B) When the following window is displayed, click 'MP Drivers' and the application software to be installed, and then click 'Next'.
  4. When the License Agreement window is displayed, read the content carefully and click 'Yes'.
  5. The installation will start.
    Messages may be displayed during the installation of the application software.
    Follow the instructions on the window and continue the installation.
  6. When the Printer Connection window appears, connect the printer to the computer and power on the printer.
    Note: If the installation cannot proceed even after 2 minutes, stop the installation by following the procedures below and start from the beginning again.
    1) Click 'Cancel' at the Printer Connection window then click 'Start Over' at the Installation Failure window.
    2) At the window to install the driver / applications appears, click 'Back' then click 'Exit'.
    3) Restart the computer.
    4) Install the printer driver again.
  7. For Windows XP, at the Welcome to the Found New Hardware Wizard dialog box, confirm Install the software automatically (Recommended) is selected, then click 'Next'.
    Note: The Welcome to the Found New Hardware Wizard dialog box may be behind the Printer Connection window.
    In this case, click 'Found New Hardware Wizard' button on the task bar to display the window.
  8. After the files are copied automatically and the dialog box Completing Found New Hardware Wizard window appears, click 'Finish'.
  9. If the Welcome to the Found New Hardware Wizard dialog box appears again, click 'Finish' again.
  10. At the Print Head Alignment window, click 'Execute'.
    Note:
    * The Execute button may not appear for all models. In that case, skip to step 13.
    * The Print Head Alignment can also be done after the installation of the printer driver.
  11. When the Start Print Head Alignment window appears, load one sheet of A4 or letter size plain paper in the sheet feeder and click 'Print Head Alignment'.
  12. At the Do not start another operation until current one has finished dialog box, click 'OK'.
  13. When the pattern is printed, click 'Next' at the Print Head Alignment dialog box.
  14. At the Installation Results dialog box, check the content then click 'Next'.
  15. At the Installation completed successfully dialog box, click 'Exit'.
    Note: When the Restart button appears, confirm that Restart the system now (recommended) is checked then click 'Restart'.
Dec 04, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Status Monitor isn't hihglighted so I can't check
This can only be done by getting a new status monitor software . Follow my instructions:- STEP 1 - Install the Epson StatusMonitor software. This program comes on the CD included with the printer. It can also be downloaded from the Epson Web site ( http://download.cnet.com/Epson-Status-Monitor-2/3000-2116_4-10024738.html ).
STEP 2 - Open the Epson StatusMonitor program in any application (such as wordprocessingmag-glass_10x10.gif, spreadsheets or Web browsers) that allows you to print. Click on the "File" menu tab in the control bar of the application.
STEP 3 - Select print or page setup from the "File" menu. A dialog box will open. In that box, click on the "StatusMonitor" icon, which will open the "Epson StatusMonitor" dialog box. Also, you can click on the "Utility" icon and then the "Epson StatusMonitor" button from the "Utility" dialog box.
STEP 4 - Click on the "Update" button to update the display (if you do not think these levels are accurate) when the "Epson StatusMonitor" dialog box displays the relative ink levels for each cartridge in the printer.
STEP 5 - Go back to the "Print" dialog box to change the way that the StatusMonitor utility monitors your printer and ink levels. Click on the "Utility" button again.
STEP 6 - Click on the "Configuration" button in the "Utility" dialog box. The open "Configuration" dialog box will let you adjust settings such as ink level warnings and ink level monitoring before each printing.
Aug 13, 2009 | Epson Stylus Photo R200 InkJet Printer
Name some common dialog boxes and mention its uses.
There are numerous common dialog boxes in windows, please note i am very specific to windows (and not VB since VB has difference nominclature for common dialog boxes)
following are some windows common dialog boxes:
  1. UserInput dialog box: to fetch user input.
  2. Alert dialog box: to display some alert information to the user.
  3. File Open Dialog Box: to browse and open file from selected filesystem.
  4. FileSave dialogbox: to save a file to a filesystem on selected path.
  5. Print dialog box: to setup printer preferences and print setting commands routing to printer.
Thanks.
Mar 07, 2009 | Acer Computers & Internet
Scanner suddenly disappeared from the Applications folders.
First unplug scanner, turn off mac, remove mac battery and unplug adapter, plug everything back , restart and reconnect.
If that did not work, then do the following:
Unplug scanner usb and reinstall scanner/printer software again on your MAC.
Oct 14, 2008 | Canon MP970 Photo All-In-One InkJet...
HP 7210 OfficeJet - unnecesary cartridge messages
We had the same problem - after 2 1/2 years suddenly the dreaded dialog boxes appeared out of nowhere! We had tech support on the phone for at least 30 minutes to no avail. Finally we uninstalled and reinstalled the printer and all software and it disappeared.
Good Luck!
Apr 05, 2008 | HP Officejet 7210 All-In-One InkJet...
Disabled internal mic on toshiba satellie A200
I've just had this problem and fixed it.
Right click anywhere in the "Recording" tab of your sound options. (the place where you disabled this mic) and click "show disabled devices".
Then simply enable it. Hope this helps.
Feb 11, 2008 | Computers & Internet
HP Officejet Pro L7680 All-In-One Printer Logo
64 people viewed this question
Seeker5211
Seeker5211
